8mm toslink cable??? - AVS | Home Theater Discussions And Reviews
post #1 of 3 Old 05-01-2007, 09:11 AM - Thread Starter
GoldenD's Avatar
I recently ordered an 8mm toslink cable thinking it was just a thicker cable but would have a "standard" connector. When I received it I found that the connectors are larger than the ones on the back of my dvd player and receiver.
2 questions:
What is an 8 mm cable for?
Is the 5 mm the "standard" that will fit in most dvd pl;ayers, receivers, etc.
GoldenD is offline
post #2 of 3 Old 05-01-2007, 10:24 AM
whoaru99's Avatar
Liked: 68
Dunno that a 8mm cable, or 5mm cable for that matter, is for anything specific - other than what the type of connector mates with.
There are a number of different optical connectors, JIS F05 (aka TOSLINK) being the common one for home audio connections.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #3 of 3 Old 05-03-2007, 11:26 AM - Thread Starter
GoldenD's Avatar
my bad...it is the same connector. There is a small plastic protector on the end that looks integrated so I thought it was part of the connector and it is just large enough to prevent it from being inserted into the unit.
thanks
GoldenD is offline
