D-Sonic custom Audio amps - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
Old 04-18-2014, 08:22 AM
Quoted: 108 Post(s)
Liked: 70
Originally Posted by d00m View Post
I have the M2-1500M (a pair of course) and it sounds awesome. I wouldn't worry too much. I'm pretty sure there are subtle changes between M2 and M3, maybe in the buffer stage? Just guessing. I've heard a lot of amps in all classes that I know of (A, AB, C, D, T) and to me the M2 is definitely one of the best I've heard. In it's price range it's no doubt the best.
Hello there, I am considering a new D-Sonic 5 channel amp, BUT I need some feedback first. My current amp is a 2008 rotel rmb-1095 ( 200w x 5 ) which sounds very good. My speakers are all large- PBN Montana's. Would this be an upgrade in performance? I would think so but would love to hear more from other d-sonic owners.
Deckard97 is offline
Old 04-18-2014, 08:52 AM
d00m's Avatar
Since I haven't heard that particular Rotel I really can't give you an honest opinion. Most Rotels I've heard perform really well in their price range. I wild guess though would be that the D-Sonic amps would be an improvement, based on my experience with various amps. smile.gif
Deckard97 likes this.
d00m is offline
Old 04-18-2014, 10:49 AM
dsonic's Avatar
Hello All,
The M2-1500M and M3-1500M are identical.
I originally went to the M2 designation to reflect new cosmetics, grounding and EMI/RFI shielding. The 6 Moons review was done at that time. After the review was published, I decided to change all of the newer technology amplifiers to the M3 designation to make a clean separation between the M2 and M3 series.
Dennis
D-Sonic Custom Audio
www.d-sonic.net
800-862-7998
81828384, Deckard97 and countryWV like this.
dsonic is offline
Old 04-18-2014, 12:57 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
What is the sensitivity of the speakers and the recommended amount of max power (WPC)?
Chris
Chris
countryWV is offline
Old 04-18-2014, 01:26 PM
asharris7's Avatar
All amps sound the same anyway ;)
(sarcasm) btw
asharris7 is offline
Old 04-18-2014, 01:53 PM
Quoted: 108 Post(s)
Liked: 70
Chris
Hi Chris, the speakers are easy to drive... -92.5db sensitivity. The recommended power is 150 - 500 watts per speaker. ( But I'm sure the Montana's could handle a lot more if needed;)
thx for your reply,
Bri
Old 04-18-2014, 01:55 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
I actually agree with you for the most part. As long as the speaker being driven has enough power to drive it effortlessly without running out of headroom there should be no audible differences, unless the design purposely intended to put there own sonic signature on the sound being amplified or the amp in question is broken.
It is when the amp starts clipping that breakup can occur. This breakup causes distortion which can lead to a perceived audible different sound.
Chris
Chris
Old 04-18-2014, 02:04 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
thx for your reply,
Bri
In this case 500wpc will drive your speakers better with less effort then 200 wpc the higher you turn the volume up and the more dynamic the source material being reproduced. You should notice that the speakers become more effortless.(faster tighter and more punchy) but the sound will not change. An amp should accept the signal, amplify that signal, and send it back out neutral with no color.
This amp should be more efficient then the rotel and not get as hot. Those are big pluses IMO. I've had/have a lot of amps this is by far my favorite total package amp. I have the M2 1500 it weighs less then 30 pounds yet puts out 500 wpc and never heats up. That is Awesome! smile.gif
Chris
Chris
Old 04-20-2014, 06:46 AM
Quoted: 108 Post(s)
Liked: 70
Good Stuff Chris! I think I am pretty dead set on getting the 5 channel M3 from Dennis. His prices are real good.......the Wyred 4 Sound Amps are VERY similar in design and performance, but more costly.
enjoy!
Old 04-20-2014, 06:50 AM
speedoflight's Avatar
enjoy!
You won't be disappointed.
speedoflight is offline
Old 04-20-2014, 06:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1236
Chris
Not quite all of the best questions. The best questions are:
(1) Efficiency of speakers?
(2) Speaker positioning whether along wall or in the middle of the room
(3) Preferences for SPL - if you don't know, get a SPL meter right now - they only cost $20-50.
(4) Listening distance
(5) Subwoofer yes or no, and the only reasonable answer is yes.
arnyk is offline
Old 04-20-2014, 07:32 AM
JHAz's Avatar
Quoted: 294 Post(s)
Liked: 253
Chris
I used to think this too. Actually when you are merely loud and using 5watts or less your speakers won't see or taste or smell the difference in potentially available power. The physical laws of the universe require that at any given voltage into any given speaker the current and therefore power have to be exactly the same. It's not a law like the speed limit it's like gravity. Always there and unavoidable. Increase the voltage (also called turning up the volume) makes things louder. At any spl that is within the audibly clean and linear band of an amp voltage and current have to be the same so power has to be the same regardless of remaining headroom in amp power.
Aside from intentional treble roll offs the most likely amp spec to make a sonic difference, assuming you are not distorting the amp, is output impedance. High enough output impedance into a difficult enough load can cause the amp to have frequency response peaks and dips that could be audible.
JHAz is offline
Old 04-21-2014, 02:15 PM
noah katz's Avatar
Quoted: 822 Post(s)
Liked: 281
Those laws do not require that all amps be able to deliver the current demanded by that voltage, in which case the voltage will of course drop.
Which is not to make any statement as to how likely this scenario is.
Noah
noah katz is offline
Old 04-21-2014, 02:41 PM
JHAz's Avatar
Quoted: 294 Post(s)
Liked: 253
Its called clipping. Basic premise remains. Didn't I say linear? Clipping isn't linear. If the less powerful amp clips audibly the 2 amps will sound different. Experience suggets that at lower distortion levels the clipping amp will sound better to many. Virtually guaranteed it will be perceived as louder. Distortion sounds loud. Also clipping implies some dynamic compression, raising average levels and sounding louder.
JHAz is offline
Old 04-24-2014, 06:43 AM
green giant's Avatar
Quoted: 61 Post(s)
Liked: 50
Basic question, are the D-sonic input stages modified now (or have they always been?) If they changed... where did that change occur. Seems like Wyred 4 Sound modifies for sure. Wasn't sure if D-Sonic does, and when that change happened.
In following through this thread, there seemed to be some mixed thoughts on that. Also, has anyone had any real experience listening to the M2 with the ice modules and the M3 with the new modules back to back? Just wondering where if/where they are different (low end, top end etc?)
How do the D-sonic's hold resale, has anyone sold theirs to upgrade etc?
There are not a lot of "professional" reviews out there, many are listed as M2, but not sure which modules that means they have as it sounds like a running change occured. Specifically interested in multi-channel also.
green giant is offline
Old 04-24-2014, 07:03 AM
pgwalsh's Avatar
Quoted: 387 Post(s)
Liked: 279
Dennis offers a 30 day in home trial, but I can't imagine you wouldn't be happy with them.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
Old 04-24-2014, 07:58 AM
I have real side by side experience with both versions of the amps. I previously had a original version 5 channel amp, then an M2 - 7 channel, and now have an M3 - 7 channel. I had the M2 - 7 channel and the M3 - 7 channel in my system at the same time as I was beta testing the M3 for Dennis before he released the M3. The M2s with ice modules are very good amps, very dynamic with good expression along the full range of frequencies. The M3 amps are a little more dynamic. The sound stage is a little deeper and sounds more like I'm in front of a live band. The mid and low range are a little crisper and the low end on the M3 amps seems to dig a little deeper with less effort than the M2. The upper mid range to the higher frequencies are a little more organic with the M3.
I can't comment on the resale value as I've traded mine in for the newer versions and paid an upgrade fee to Dennis on each one.
Both the M2 and M3 are very good Class D amps. You can't go wrong with either. Please note though, that any perceived difference that I hear in my theater, you may not hear in your system. The amp is just one piece of the puzzle and all of the parts work together to produce the final sound you hear. If you're looking for more theater use, and you have access to an M2 with the Ice modules, go for it. You won't be disappointed. If you're buying new, go for the M3.
Old 04-24-2014, 08:27 AM
Quoted: 108 Post(s)
Liked: 70
I am very confident that the D-SONIC amps will not disappoint. That being said, I'll be selling my rotel and going with an M3. I'm sure that the D amps are superior....well, 99.99% sure. wink.gif
conanb, pgwalsh and robcentola like this.
Old 08-18-2014, 07:22 AM
gregcss's Avatar
Quoted: 67 Post(s)
Liked: 24
Will there be a slim 5 channel model in the foreseeable future?
gregcss is offline
Old 08-19-2014, 11:13 PM
dsonic's Avatar
Greg,
A slim 5 channel is not planned at this time. With the present module sizes it is not possible to fit that many channels into a slimmer package. There are lower power, smaller modules that could be used to do this that would limit output to 175w/ch or less. The great majority of my customers prefer higher power in at least the front channels.
Dennis
dsonic is offline
Old 09-04-2014, 11:47 AM
pgwalsh's Avatar
Quoted: 387 Post(s)
Liked: 279
Dennis
I may have missed it, but I've read you're not using the ICE modules in these new amps, is that correct? If not, are you using Hypex or something else?
Peter
oneeyeblind likes this.
pgwalsh is offline
Old 09-04-2014, 12:00 PM
dsonic's Avatar
Originally Posted by pgwalsh View Post
Dennis
Peter
Peter,
I use ICEpower im the M2-1500-3 only. All other models use different technology, not Hypex.
Dennis
dsonic is offline
Old 09-04-2014, 12:08 PM
pgwalsh's Avatar
Quoted: 387 Post(s)
Liked: 279
Originally Posted by dsonic View Post
Peter,
Dennis
Cool. I have the original series and will need another multichannel amp for my new theater - still in the planning stages - since there will be many more speakers. I'm doing an Atmos theater with 2 rows of seats and sides and heights for each row. I have Acoustic Elegance TD12M's and SEOS 12's for mains and haven't decided on the surrounds. Contemplating on using series 3 for all. Thoughts?
pgwalsh is offline
Old 10-02-2014, 09:00 AM
HEPD85's Avatar
Liked: 2
Hi everyone,
I just received my M3-800S a little over an hour ago. It was instantly a night and day difference, but to be fair the 800S was replacing a humble Denon x2000 ($650 at the time of purchase). My biggest complaint against the Denon has always been the lack of definition in the vocals and other high frequency content. The 800S instantly fixed it, I played back some of my favorite (most familiar) concert recordings and movies and it changed my world. The highs were as good and smooth as people have been saying, and I'm not even using a real DAC, though I do plan on getting the W4S DAC2 DSD next month Needless to say they weren't even broken in, Dennis tells me they were freshly assembled right before they were shipped...
For those interested I'm using my Denon as a DAC/Preamp through its pre-outs, and I'm powering a pair of Aperion Verus Grand Towers. I've had a full Emotiva system before consisting of UMC-200 and XPA-3 Gen 1 prior to the Denon and based on memory, the Emotiva couldn't touch this...
Sincerely yours,
Mike
Semper Fidelis
HEPD85 is offline
Old 10-14-2014, 01:19 PM
Sam1000's Avatar
Quoted: 51 Post(s)
I'm interested in the new M3-1200-A amp from d-Sonic for stereo use in near term. However, I just got an original magnum 3500-7 amp from used market for HT and want to use it's balanced input. At the back of the amp, there's a warning that says there's a risk of electric shock if balanced inputs are used. Looks like the original magnums were not grounded. How concerned should I be about using balanced input given the warning?
Pioneer/TAD S-1EX, S-7EX, Ascend HTM200
Marantz 8802A, Devialet D400 L/R, NAD M27, Squeezebox
Sam1000 is offline
Old 10-14-2014, 09:57 PM
Sam1000's Avatar
Quoted: 51 Post(s)
Very good customer service from D-Sonic/Dennis. After I posted a question here, I had sent an email to Dennis asking the same question. He responded very quickly to that email, even if I'm not his direct customer.
Sam1000 is offline
Old 10-15-2014, 09:08 AM
dsonic's Avatar
The warning refers to connecting the outputs to an external ground, not using them with cables and wire. This is why the European standards mandate an insulation shield encapsulating the entire speaker post, usually a clear plastic, so you can see polarity stripes and colors. There is a separate slot in them for a spade lug.
If you were to touch any conductive surface on the chassis and the bare speaker post simultaneously, you could get your hair restyled.
Dennis
dsonic is offline
Old 11-26-2014, 05:01 PM
don480's Avatar
Quoted: 53 Post(s)
Hi guys I just received my D-sonic M3-1500m for my Dynaudio C4 MKII. I just hooked it up and powered them on and noticed a slight poppy sound. This has never happened with any of my previous amps including other class D amps like Bel Cantos and Wyred 4 Sound. I decided to unplug the XLR connection from my preamp and power them on and still a slight popping sound from each speaker. I have upgraded cables and each plugged in my Monster power conditioner. Additionally, when I turn up the music to medium-higher volumes I can start hearing a slight ticking/popping sound when I adjust the volume up or down. Should I be worried? Is it damaging my speakers? I called Dennis and left a message waiting on reply from. Otherwise these little mono amps sound pretty impressive, especially in the lower frequency region. Tons of bass! My speakers sound even bigger and more powerful. I have had Mcintosh MC452, Parasound JC-1, BC Ref500m, W4S SX-1000 MKII, and so on. So far I feel these little amp are great minus the weird popping sounds. I need to burn these in more to see if they open up a little more on the upper frequency region. Anyone want to share there thoughts?
don480 is offline
Old 11-30-2014, 06:19 PM
tritiumglo's Avatar
Quoted: 366 Post(s)
Liked: 165
Unfortunate to hear about the noise issue. I would contact CS to see what they have to say.
Would you say this amp is as smooth as the Mcintosh? I am tempted by the D Sonic but I have heard some Class D offerings that were very bright and harsh. The last being red dragon. Those had some serious edge to them!!!
NAD M15 /NAD M25 / PSB STRATUS GOLD / PSB STRATUS 6C /DENON AVR 3300/CARVER TFM 45/35 - ANTHEM MCA3 / NAD T163
IMAGE DYNAMICS / INFINITY RS3 / POLK MONITOR 10/ALTEC 501 / INTEGRA 50.3/PARADIGM DSP 3400 / GOLDENEAR AON3 / HK AVI 200
An Observer of many philosophies, a slave to none.
tritiumglo is offline
Old 11-30-2014, 09:16 PM
don480's Avatar
Quoted: 53 Post(s)
Not at all harsh... Very smooth. If anything the highs are very tame. Tons of power on standby. I would recommend these amps. I spoke with Dennis today and said the slight popping noise on start up is normal and not to be concerned.
don480 is offline
