Is anyone familiar with Sherbourne amps? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 08-18-2010, 02:25 PM
listenphile's Avatar
Originally Posted by Hans Gruber View Post
I disagree with some of what you say. I think the most important item in a home theater is the amplifier. A good amp will make bad speakers sound good. The pre/pro's are a different story because a lot of the top pre/pro's use the same DSP chips.
So if a good amp will make bad speakers sound good, then what does a good amp do for great speakers? I would argue that the gain is greater when resources are allocated to the speakers if there are not enough to buy both great speakers and a good amp. The quality of the amplifier does make a difference, but it is arguably less of a difference than a set of good speakers. I know someone else already mentioned this, but I will second it - focusing on a good set of speakers and a good DAC will deliver more benefits to the sound than just buying a good amplifier.
As far as the thread is concerned. I own a Sherbourn LDS 12/900 and it is wonderful sounding. I'm very impressed with it. I'm using a Rega Planet CD player, Anthem AVM20, and 100db @ 1w/1m full range single driver speakers. Because of their efficiency, I can hear ever detail in the system. It makes it easy to hear differences in gear changes, and interconnect quality. Shortly after getting the speakers, I tossed the Monster Cable interconnects and replaced them with solid silver ones. It was as audible as getting a new piece of gear- specifically in the vocal frequencies. I gained more range on the lower vocal frequencies instantly. I considered that I could be just imagining it, but my parents can hear it and they are approaching 70yrs old. Consequently, my mother commissioned me to do the same for her audio system. My point is this... with the ok speakers that I had prior (Kef q80's), I could hear the difference, but with my new set of speakers, it was entirely obvious. With a poor set of speakers, I suspect that the difference would be less obvious - even with a good amplifier. Because the difference is so audible, I have since constructed all of my own interconnects using silver wire, in addition to making my own power cords as well. It really makes a difference and that difference is audible with good speakers.
listenphile is offline
post #32 of 34 Old 08-18-2010, 02:42 PM
mjt5282's Avatar
Quoted: 16 Post(s)
I bought 1 7/2100A new from a CT dealer near New Haven a few years ago, and as I accumulated pre-pros, I bought 2 used 7/1200's from audiogon and ebay as they popped up. I figure they haven't given me any trouble over the years and the are built (and weigh!) like a tank,as a previous poster has said.
mjt5282 is offline
post #33 of 34 Old 02-01-2013, 06:43 AM
Stewy04's Avatar
Silly question for all. I have two Sherbourn's ; 7x 150 and a 2x160. The blue lights on my 2x160 are much brighter then the lights on the other amp. Is there a way to turn down the brightness of the lights. I do know that I can turn off the channel lights (not the power light)
Stewy04 is offline
post #34 of 34 Old 07-19-2016, 01:11 PM
Liked: 0
Old post, but just to chime i with a massive plus one for these amps.
I just stripped and serviced a SHERBOURN AUDIO LDS-1645 16 CHANNEL which has been powering 8 x BOSE 251 in our leeward shore beach bar (Caribbean heat, humidity, salt and sand) for the last 7 years... we only just lost one stereo channel out of 8. Took an inch of sand out, salt build up on the PCB was horrific. I'm not joking when I say this bar has seen at least 1 hardcore party per week for last 7 years with staff cranking this thing, blowing an occasional speaker, throwing drinks around (i'm sure it must have been soaked a few times).... this thing is still running like a champ....
stripping it for cleaning, the construction is unreal - seriously hardcore. Each channel has a sub amp board, so the above isn't even a huge issue, as we have just pulled the fuses and used a different channel (each sub board has a separate fuse per L+R channel as well as the main fuses).
Very impressed, I can't recommend more highly.
Dom
boma23 is offline
