"The" Onkyo TX-SR805 Thread - Page 748 - AVS Forum | Home Theater Discussions And Reviews
 123Likes
post #22411 of 23768 Old 04-14-2012, 02:15 PM
MonkeyGoD's Avatar
Originally Posted by MonkeyGoD View Post
Found a new prob w/ my 805. Maybe I never noticed it till now but the balance is biased to the right side whenever I use the receivers DAC to listen to music. Vocals sound more like its coming from the right side; sounds more noticeable with headphones. Source is mp3 from the computer through SPDIF and playing a CD on my PS3 through HDMI. However, when playing through Multich (not using DAC), the sound is balanced, so I dont think its a problem with the amp circuitry, so it has to be related to the DAC or DSP. Anyone else have an issue like this?
Solved it. Just had to do reset all my settings.
MonkeyGoD is offline
post #22412 of 23768 Old 04-19-2012, 05:16 PM
okiebirdnerd's Avatar
Hello, We have the 805 and the sound and picture keeps flashing on and off.It started out with just the sound and now the picture blacks out. Now it is doing it all the time. I had Cox Cable come look at or box and they said it was the Onkyo. He checked the HDMI cable to and it was fine. I had him go ahead and replace our box since we'd had it a while. I did a reset hoping that might fix it but no luck.
My question is, what is causing it and is it worth fixing? And what might the cost be?
Thanks in advance for your help and suggestions.
okiebirdnerd is offline
post #22413 of 23768 Old 04-19-2012, 05:19 PM
baniels's Avatar
Quoted: 208 Post(s)
Liked: 318
It sounds like the HDMI is failing. Not too uncommon in later years. Scan the last several pages, you'll see you're not alone.
Not sure what the options are.
baniels is online now
post #22414 of 23768 Old 04-19-2012, 08:57 PM
I didn't see anything on how much it costs to replace the hdmi. thanks
post #22415 of 23768 Old 04-19-2012, 09:01 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
$500 or more if you send it to Onkyo or to a certified repair center. The only cheaper way is to buy a used broken 805 with a good HDMI board.
Secret Squirrel is online now
post #22416 of 23768 Old 04-20-2012, 09:01 AM
golffnutt's Avatar
Quoted: 85 Post(s)
Originally Posted by caesar1 View Post
I have the Dragon Blu-ray. Did not hear any issues.
Great looking theater caesar1!!!!!!!!!!
Thank you.Golffnutt"GO DAWGS" !!!!!!!!!!!!!!Panasonic PT-AE 8000U Projector with 10' Screen // Samsung 65" TV UN65KS9500F // Denon X6200W Receiver // Oppo 203 4K Player // Pioneer Elite BDP-05FD Blu-Ray Player (Great CD Player and Excellent Blu-Ray Player) // PSB 9.2 speaker setup with 2ea. M&K 12" Subs // Panasonic Surge Protector // Monoprice Premium Cabling
golffnutt is offline
post #22417 of 23768 Old 05-05-2012, 04:09 PM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 40 Post(s)
Liked: 32
ADDED 051012: well, haven't done the upgrade yet but another CD showed up yesterday. Anybody want one?
Took a month, but the CD showed up. Plan to do the upgrade next week.
Not my president!
grubavs is offline
post #22418 of 23768 Old 05-14-2012, 11:26 AM
Mr. Tao's Avatar
Quoted: 12 Post(s)
Just trying to confirm info I got from one AVS member awhile ago. I have a yet to be connected 310 that I purchased because I have an older HDMI receiver an Onyko 805. I was informed that the 805 will pass a checkerboard 3D image to my Mits. 73883? Is this correct information? I bought the 310 thinking I would need the 2 HDMI's, one each for video and audio, which is correct?
Mr. Tao is offline
post #22419 of 23768 Old 05-14-2012, 11:42 AM
Quoted: 44 Post(s)
Liked: 39
Yes. If you want true 3D you need a BD player with two HDMI outs.
post #22420 of 23768 Old 05-14-2012, 09:44 PM
lkstaack's Avatar
There must be a TX-SR805 God that can answer this HDMI question: why doesn't my 805 always detect my HTPC HDMI signal? What can I do to get the 805 to always recognize the signal?
I run HDMI out from my Win7 home theater PC (HTPC), through my 805, and to my Sony XBR4. Sometimes the 805 doesn't pass the audio/video through; the "HDMI" light flashes like it is trying to ID the signal, then it stops and displays "No Signal". I am able to get the 805 to detect the HTPC HDMI signal again by pressing a different input button, and then the button my HTPC is associated with. Sometimes it takes several button presses.
I'm guessing that the 805 is getting confused by the flavor of HDMI my HTPC puts out; my motherboard is recent technology. However, I am not savvy enough on HDMI versions and how they are supposed to respond. Is there anything I can do to get it to work 100% of the time? Thanks!
Lars
lkstaack is offline
post #22421 of 23768 Old 05-17-2012, 10:27 PM
BasicBlak's Avatar
One option you might try is a review of your switching order. The 805 can be somewhat quirky in that way, although no more so than any other early HDMI v1.3a-equipped component.
For instance, with my Toshiba A35 HD DVD player as the source, the proper switching order with my setup is crucial for consistent performance. With TV already on (a Sony A3000 SXRD, in my case), I have to: Turn on HD DVD player => Switch TV to video input in question => Switch 805 to HD DVD player. Any other order will cause my 805 to not recognize the player. However, the switching order with my PS3s (Fat & Slim) is a non-issue--the 805 consistently recognizes them regardless.
If I had to take a stab at the cause, I would have to guess that the 805's source-component EDID acknowledgment varies from source to source. Therefore, it stands to reason that even a modern HTPC or desk-/laptop could be succeptible to this. (My Win7 laptop happens to work without fail via the 805.)
In any event, one's mileage clearly varies, but experimenting with your switching order is certainly worth a try.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
post #22422 of 23768 Old 05-17-2012, 11:29 PM
Archaea's Avatar
Quoted: 2840 Post(s)
Liked: 2420
The SR805 at current ebay prices of ~$300 is about the best receiver deal going because of the incredible amp section and support of all modern features except 3d. Is there anything else comparable at these price levels on the used market? A friend of mine is asking and I really enjoyed my SR805 so I directed him to checked out a used Onkyo SR805, or SR875, or NR905 first. But any other strong contendors? I can't really imagine getting much more for $300. At his point it's a THX Ultra 2 rated receiver with more power than advertised, and isn't missing a single feature over the newest receivers outside of 3d and being shy a bit on HDMI ports with only 3. However - at $300 - what a steal!
Archaea is online now
post #22423 of 23768 Old 05-18-2012, 06:55 AM
mcsoul's Avatar
Quoted: 16 Post(s)
I would be slightly fearful of an ebay TX-SR805, but you can get lucky.
I have an 805 and a Samsung Blu-ray player that has 2 hdmi inputs. That's like having an 805 with 5 hdmi inputs.
mcsoul is offline
post #22424 of 23768 Old 05-18-2012, 06:50 PM
lkstaack's Avatar
Thank you for your suggestion. Yes, moving the switching order and adding a delay before the switch was the first thing I did. It seemed to work out most of the time. However, the problem seems to be getting worse. I have to manually switch from cable/sat to DVD (where my HTPC is routed to) every time I power up in order for the 805 to recognize the HDMI. Sometimes I have to do it several times to get it to work.
I was wondering if a firmware upgrade would help?
Lars
lkstaack is offline
post #22425 of 23768 Old 05-18-2012, 10:03 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
It's a good possibility that your HDMI board may be starting to fail...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #22426 of 23768 Old 05-19-2012, 11:59 PM
BasicBlak's Avatar
Might want to verify which HDMI firmware version you have, Ikstaak. The 805 shipped initially with v1.01. I and several others here performed the v1.02 update a few years back. 1.03 is also available and out in the wild but requires an updated HDMI board. So unless you know for sure you have it or one of the last (read: most recent) batches shipped from the factory, I wouldn't concern myself with it, as you could end up bricking it the whole enchilada.
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #22427 of 23768 Old 05-20-2012, 08:33 AM
lkstaack's Avatar
Your kind response prompted me to read through some earlier HDMI firmware posts. Since v1.02 solved some Panasonic projector issues, do you think it might resolve my intermittent hand shake issue? I'm reluctant to upgrade firmware on anything unless I have an issue it will solve.
I saw rspeeders firmware link. I saw some references, to dongles and computer serial outs. Please confirm that I can upload firmware via CD optical out (DVD probably won't work)?
Lars
lkstaack is offline
post #22428 of 23768 Old 05-20-2012, 01:13 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Only the DSP firmware can be updated via CD optical... The HDMI firmware has to be updated using the RS-232 or a connector port.
Jon S is offline
post #22429 of 23768 Old 05-20-2012, 03:57 PM
lkstaack's Avatar
Thanks for the information. A RS-232 is a regular serial cable, right? What is a connector port; is it a serial port?
Lars
lkstaack is offline
post #22430 of 23768 Old 05-21-2012, 07:13 AM
golffnutt's Avatar
Quoted: 85 Post(s)
Does anyone happen to know if the HDMI circuit board from an 805 will work in a TX-SR 876?
I think mine just went out. I turned it on got a picture for about 2 minutes and then the picture turned into a half and half screen, half green and half dark gray. It does this on my Sattelite picture and all 3 blue ray players I have hooked up to it. Thanks so much for your help.
post #22431 of 23768 Old 05-21-2012, 01:13 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
the onkyo used a special jig to plug into a connector port in the back of the 906/876 models... not sure if the 5 series had it... But the RS232 port uses a straight serial cable, not a cross cable. You will need to find a computer that has a serial port. Most USB-Serial adaptors do NOT work.
Jon S is offline
post #22432 of 23768 Old 05-21-2012, 01:13 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
It will not... you will need a HDMI board from another 876 or a 906...
Jon S is offline
post #22433 of 23768 Old 05-21-2012, 04:18 PM
riverwolf's Avatar
Liked: 24
The x05s used a standard serial connector. However, for receivers with a bootloader before a certain version, you needed a "jig" with wiring that was not RS232 standard. Once the bootloader is updated, one can then use a standard RS232 interface for f/w updates. I would be surprised if later Onkyo models, such as the x06 lineup, reverted back to a non-standard serial port. Full details for the jig/dongle and bootloader requirements can be found by searching this thread or the Onkyo firmware update thread.
I also wouldn't be so quick to use "most" when saying USB-serial adapters don't work. Yes, there have been some reports. However, I had no trouble with the cheapest adapter I could find...a $10 job from Monoprice back in the day. It's hard to separate user error from hardware incompatibility when two people claim to be using the same adapter, but one says it doesn't work and the other said it does.
-Brent
riverwolf is offline
post #22434 of 23768 Old 05-21-2012, 10:51 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I work in IT... We have some old serial port equipment. We tried a number of RS232 to USB connectors and the equipment did not register info correctly. We are desperately maintaining some old computers just to communicate to the old equipment...
Jon S is offline
post #22435 of 23768 Old 05-22-2012, 06:23 AM
baniels's Avatar
Quoted: 208 Post(s)
Liked: 318
According to my Amazon receipt, I used a "Keyspan High Speed USB Serial Adapter ( USA-19HS )" back in 2008. It worked for me.
post #22436 of 23768 Old 05-22-2012, 04:13 PM
sedavis76's Avatar
After a couple of power outages recently I discovered that when my TX-SR805 loses power, it resets everything to the factory defaults. I have to set it all back up again, including the speaker calibration, etc.
Anyone else have this problem? I was hoping it might be something simple like a a bad backup battery (similar to what would be in a PC).
sedavis76 is offline
post #22437 of 23768 Old 05-22-2012, 05:25 PM
riverwolf's Avatar
Liked: 24
So you actually have no experience using a USB->serial adapter to update the firmware on an 805 when you make the definitive statement that "Most USB-Serial adaptors do NOT work." ? How large a sample size is "..a number..."?
I'm not surprised you found "a number" of adapters that didn't work doing what sounds like real time data acquisition. IME, that's a very different type of fruit than the x05's firmware update.
BTW, why don't you simply install PCI serial cards in a current PC instead of clinging to that old hardware and putting your business' uptime at risk?
-Brent
post #22438 of 23768 Old 05-22-2012, 05:40 PM
riverwolf's Avatar
Liked: 24
This has been mentioned a few times in the past year or so by other owners. I had the same issue after about 8 years with a non-Onkyo preamp and learned that its memory backup was maintained by a slow discharge capacitor. Assuming the 805 uses a similar approach, it sounds like a few, including yours, appear to have reached their useful life on the short side of the MTBF curve. Not sure why a/v equipment uses a slow discharge cap instead of a watch battery like a computer; maybe cost? The replacement cap would likely be a less than $10 part, but the trick is identifying the circuit or getting a copy of the service manual.
-Brent
post #22439 of 23768 Old 05-23-2012, 03:35 PM
sedavis76's Avatar
That's the trick. I'd have no problem replacing the part myself if I knew which one it was. Don't suppose anyone has a schematic for this thing?
post #22440 of 23768 Old 05-25-2012, 06:05 PM
riverwolf's Avatar
Liked: 24
Agreed. Would be nice if someone could get their hands on a service manual and identify the memory circuit and replacement cap size. If you have an Onkyo service center nearby, you might could sweet talk them into showing you their manual. There also is/was an Onkyo tech or two in the xx6 HDMI cap replacement thread, IIRC. Maybe a PM to one of them might yield some results.
An alternative would be to run your 805 through a cheap UPS. I'm thinking one of the APC Back-UPS sized units that can be had for <$50.
-Brent
