"The" Onkyo TX-SR805 Thread - Page 767 - AVS Forum
 14Likes
post #22981 of 22996 Old 08-17-2014, 07:35 PM
ricknoberts's Avatar
Haven't tried it w/ the other inputs. Everything is either passed through or upconverted to HDMI with a single cable going to the television.
Isolating the issue surely seems like the next sensible step given that it doesn't appear like a common bug.
ricknoberts is offline
post #22982 of 22996 Old 08-17-2014, 10:59 PM
JChin's Avatar
Quoted: 78 Post(s)
Liked: 129
Suggest trying the other two component inputs and passing it through Component Out to see what result you get.
JChin is offline
post #22983 of 22996 Old 08-18-2014, 02:29 AM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 726 Post(s)
Liked: 252
Originally Posted by tanman View Post
The Onkyo 838 had a favorable review in the Sound and Vision Magazine. It does have the power and a few future proof items for a good list price.
AccuEQ. ...Not EQuing the two front mains, very unfortunately. ...But Dolby Atmos Ready.
NorthSky is online now
post #22984 of 22996 Old 08-18-2014, 02:49 AM
NorthSky's Avatar
Quoted: 726 Post(s)
Liked: 252
Did you read your manual in the Component Video Connection and Video Setting sections? ...Pages 28-29, and 50.
Some good tips there, and useful info regarding THX settings for best picture quality.
Take your time, read, and set all the proper adjustments. ...It's a complex machine with many settings.
And make sure you disable the CEC Control feature, even if it's for HDMI (page 99).
* Are you from North America or the UK? ...Page 60 in your manual (NTSC/PAL setting).
{Troubleshooting: The picture is distorted, @ page 115 in your manual.}
post #22985 of 22996 Old 08-24-2014, 02:45 AM
olinda cat's Avatar
Question for my fellow 805 owners about running 2 subwoofers that are different models.Using a Y adapter for connection ;what is the best way to adjust a left front corner existing sub (M&K 350 Thx) in a 7.1 configuration adding a PSA XS15se in a near field,right rear?I have been running the built-in Onkyo set up adjustments which do not allow for a second sub and of course my ears.My theater is modest in size 16'deep and 15.6' wide with a riser for stadium seating.The new sub will be positioned next to the right rear seat for a near field effect.???
olinda cat is offline
post #22986 of 22996 Old 08-24-2014, 08:30 AM
Smarty-pants's Avatar
Quoted: 105 Post(s)
Liked: 129
Hook up both subs with the Y cable so they are running as one.
Then, turn off one of the subs, and calibrate the other one as you normally would.
Then, turn off the one you just calibrated and turn on the other one and calibrate the second one as you normally would.
Now that both have been calibrated individually, turn them both on and calibrate them as one, making tweaks where necessary.
Do it that way for any setup, but if you are going to use Audyssey, do it before running your Audyssey calibration.
Be sure to keep the volume of the subs turned to a nice level that Audyssey can handle.
Most people make the mistake of turning the subs up too high which will trigger an error in the Audyssey.
For your subs that'd probably be between 9 o'clock and 12 o'clock on the subs dial.
A good calibration will put the sub volume in the 805 right in the middle of it's volume range after you have calibrated both subs together.
If the 805's volume range goes from -10 to +10, then a good final volume would be -0-.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
post #22987 of 22996 Old 08-24-2014, 02:22 PM
riverwolf's Avatar
The 805 is best used as a pass through device for all video, except maybe 480i via RCA. The 805 has a relatively weak, even for its time, video processor. It actually downscales 1080i/p component to 720p HDMI when used for component->HDMI conversion. Chances are, the tearing you're seeing is a function of the 805's scaling munching the signal...either the 805 ends up outputting a bad signal or the signal it does output can't be properly interpreted by your particular display. Either route componenent in->component out->display or pick up an HDMI switch from someone like Monoprice to increase the number of HDMI ports as was recommended earlier.
If you search back in this thread, most of the limitations of the 805's chip have been discussed ad nauseum. IIRC, another relatively major issue was incorrectly interpreting the anamorphic flag on 480i/p 16:9 material. Source material would end up letterboxed *and* pillarboxed when output.
-Brent
riverwolf is offline
post #22988 of 22996 Old 08-24-2014, 02:38 PM
riverwolf's Avatar
Originally Posted by tonyv138 View Post
Hello, a follow up... I have set up my 805 with PS3 (HDMI out of PS3) and Epson Projector also HDMI connected. So when I attempt to play music on PS3, I have to turn the on projector on to activate a sound, after that I can turn the projector off. Cant figure out why. The HDMI settings seem to be correct. Any suggestions for further investigation would be appreciated.
{snip}
Thanks, Tony
Tony, if you're still around, the problem might simply be the PS3 is looking for an "ack" from the display before it will output HiRes. As I recall, PS3s (Sony) were particularly bad about strict copy protection. You could try the "HDMI Out" button behind the drop down panel. "Off" makes the 805 become the end of the HDMI chain. I use this when I listen to DVD-A/SACD sources via an older OPPO DVD player. With the OPPO, I can't remember if the 805 will recognize the HiRes audio with HDMI Out = On and the HDMI display off...I just do it to avoid having to fire up the front projector for musics discs and instead route video to an RCA monitor for disc navigation.
-Brent
post #22989 of 22996 Old 08-25-2014, 06:56 AM
HDgaming42's Avatar
Quoted: 68 Post(s)
I've searched this monstrous thread with terms like 10dB, LFE PCM, etc and found a number of mentions, but no answers, so here it is:
Does the 805 suffer from the "no boost on PCM" issue? Here's the problem I'm encountering trying to tune my system with Room EQ Wizard (REW).
Both my main monitors and sub are powered, so I set all speaker trims within the receiver to 0.
Using a channel 1 (left speaker only) pink noise test tone over HDMI with REW I calibrate my left channel to 75dB with the SPL meter. I then engage the sub, disable the speaker and calibrate the sub to read 75dB. I re-enable my left monitor and do a L+Sub sweep. It looks and sounds correct. The 805's listening preset was "stereo".
Now switching sources to play a CD with 2 channel PCM the sub is barely active. You can't hear it. If I boost the sub channel by 10dB it sounds correct. But then when I play something DTS or DD the sub is way too hot. Again with "stereo".
I thought the LFE PCM "bug" was only for multichannel material where there is a literal LFE channel coming in over digital? I shouldn't be seeing this when using straight 2 channel PCM (listening in "stereo" mode with sub active and crossover at 80Hz) should I?
Even more confusing is if I calibrate with REW and then check with the 805's internal calibration sound, the sub appears to be 10dB low...I have no idea why that is.
How do you strike a balance between "encoded" vs raw PCM formats for the sub channel? Is the solution to manually bump the LFE channel by 10dB, and then use the 805s LFE menu setting to drop every format BUT PCM down by 10dB? Can that really be the solution?
I've gone around in circles on this so many times I'm lost. I could really use a hand as I suspect I'm missing something simple.
I also have Spearrs & Munsil 2nd Edition available to assist in nailing this down, but I thought REW would be plenty enough with such easy access to channel specific test tones over HDMI...
*if this has been covered extensively in the thread I apologize, and would really appreciate a link to that discussion as I can't seem to dredge it up...
HDgaming42 is offline
post #22990 of 22996 Old 08-25-2014, 08:12 AM
HDgaming42's Avatar
Quoted: 68 Post(s)
Doing further reading, it seems I'm using subwoofer and LFE interchangeably, which isn't correct.
I guess using the PC running REW to play out 2 channel music over HDMI would be the most appropriate next troubleshooting step, no?
Bass management--my head is spinning! Playing out pink noise to the left channel as PCM and listening in "stereo" mode, calibrating both the left speaker and the subwoofer with pink noise (using frequency limited for the sub), then engaging the crossover SHOULD result in music seamlessly moving between monitor and sub, correct?
What am I missing here? The format of the test tones I send and the CD music I play is the same--PCM 44.1kHz. The listening preset is the same.
The only difference is the input! One is on HDMI 1 while the other is HDMI 3.
I guess I'll try CD music from the PC tonight. Anything else to watch for / try? Thanks!
post #22991 of 22996 Old 08-25-2014, 04:41 PM
AVS Club Gold
seggers's Avatar
Quoted: 16 Post(s)
Liked: 24
To the people who PM'ed me about the DSP and FW update files. My very bad for taking so long. I sent them to you within the last hour.
Seggers
Mits 73835, Denon X4000, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, the internet, a NAS drive, a TiVo Series 3 and an Oppo 103 (bye bye PS3). There's also a Wii, but we don't talk about that...
seggers is offline
post #22992 of 22996 Old 08-25-2014, 08:42 PM
NorthSky's Avatar
Quoted: 726 Post(s)
Liked: 252
The Audyssey Setup Guide tells how to set your subwoofer before calibration, and after if it needs to be lower in its Gain control.
Very simple, very straightforward. ...And it tells you which simple tools you need (mic stand and Radio Shack SPL meter and disc to use).
And all the proper settings in the Onkyo speaker and subwoofer (LPF of LFE) menus.
* Because your system is more complicated; LFE integrated into your main speakers, and the sources you are using, PC, PCM, REW, ... you'll need to dig into the Guide, as it is also indicated.
It would take me few hours @ least to help you out with your particular situation, but time is running out for me; I am much older than I used to be.
Best of luck. ...Fellow Canadian from Alberta.
grubavs likes this.
post #22993 of 22996 Old 08-26-2014, 09:51 AM
HDgaming42's Avatar
Quoted: 68 Post(s)
Thank-you! I will (re) read the Audyssey setup guide and see what progress I make. I am not yet ready to run Audyssey (it is disengaged), but assume you're referring to the general principles found in the article...
My current line of thinking is that the 805's test signal for my sub ends up having me set it 10dB hotter in comparison to REW's test signal. This seems to be borne out with a frequency sweep. The 805 appears to be pushing a louder bottom end. I used both a UMIK-1 (with calibration file) and a stand-alone...ummm...iphone SPL meter (SPLnFFT). Although they were not in total agreement, the ratio with which they changed was consistent.
I'm unsure if this is a problem with the 805, REW or my usage of both. I've taken some measurements comparing my AVR to REW and posted the process over here:
Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
I suspect the other thread is a better fit at the moment, until (if) I determine the 805 is the issue...
post #22994 of 22996 Old 08-29-2014, 10:26 AM
Liked: 0
-Brent
Thanks Brent, I'll give it a shot.
-tony
tonyv138 is offline
post #22995 of 22996 Old 08-29-2014, 10:27 AM
Liked: 0
Seggers
Seggers, got your PM, and responded,
Thanks, Tony
tonyv138 is offline
post #22996 of 22996 Old 08-29-2014, 02:03 PM
Liked: 0
-tony
With HDMI Out set to yes - no play until I turn my projector on, with HDMI set to no, the pay stutters.
Thanks, Tony
tonyv138 is offline
User Tag List
