"The" Onkyo TX-SR805 Thread - Page 768 - AVS Forum
 15Likes
post #23011 of 23033 Old 09-19-2014, 08:39 PM
Smarty-pants's Avatar
Quoted: 142 Post(s)
Liked: 134
^hmmm, had the same problem before but it fixed itself?
That sounds like something in the power supply or the wiring itself might just be loose.
My first thought is that it got some kind of power surge and it got fried,
but saying it happened before and fixed itself, that says to me that it might be fixable.
However, I have seen the 805 going for like 250 on eBay last time I looked several months ago.
I dunno if it would be worth paying someone to fix it or not.
Me personally, I would take the top off and check for loose wiring or connections are the power outlet and power supply.
However, it's not wise to go poking around in there if you don't know what you are doing.
If you do though, make sure the unit is unplugged and and you are grounded so you don't give it a shock on your own.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
post #23012 of 23033 Old 09-26-2014, 07:36 AM
dogaza's Avatar
First off - Thanks to Cambrain for the great post on fixing the display out problem. I've had my 805 for a long time and the display went out about a year ago. I finally bought the resistors and took it to a nearby shop - don't trust my own hands. The tech was reluctant at first, but when I told him it was easily assesible and showed him the photos, he agreed to give it a try. Well, 15 minutes later i had a visible display. I asked what he wanted and he said $10, I gave hime $20 and a handshake. What a day.
I've put everything back together and am in the process of getting reaquainted with this baby. THANKS Again - what a forum.
I do have a quick question - Would using the dimmer (I leave mind on) help alleviate this problem?
Phil
dogaza is offline
post #23013 of 23033 Old 09-26-2014, 01:24 PM
laugsbach's Avatar
Quoted: 42 Post(s)
Liked: 130
Good question...I have always used the faintest setting due to being in a dark theater room and the display is going strong 7 years later. It can't hurt...
laugsbach is offline
post #23014 of 23033 Old 09-26-2014, 11:41 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 1255 Post(s)
Liked: 430
Phil
Yes, put the 'Dimmer' to its lowest setting. Your front panel display will last much longer.
But now that you changed/replaced/fixed the resistor by its appropriate value you shouldn't have any more issue with your display indicator lights.
- Onkyo misstepped on that one; and people using the bright front panel display with the volume control light around the knob were eventually experiencing a display failure (within a year). ...The solution was to use the lowest dimmer setting, for a long lasting front panel display indicator.
Happy reborn 805.
Bests, ~ Robert § (Bob)
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
NorthSky is online now
post #23015 of 23033 Old 09-28-2014, 01:57 AM
cambrian's Avatar
Phil
Glad to see so many people found my instructions helpful over the years. I'm glad to report that I have been running this amp since 2008. For over 6 years!. I think I will only upgrade to a new AVR when I switch to 3D. It is one of the most dependable and valuable piece of hardware I have ever own.
cambrian is offline
post #23016 of 23033 Old 09-28-2014, 02:03 AM
Quoted: 142 Post(s)
Liked: 134
Not really a need for that if you get the right player. Many disc players now have two HDMI outputs that can be used to pass audio to an avr,
and separate video to the display. This helps to bypass an avr that might not be compatible with 3D.
~Dave
post #23017 of 23033 Old 09-28-2014, 09:37 AM
AVS Club Gold
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Happy reborn 805.
7-years and counting, and I have not dimmed my display (LOUD knocking on wood!!!). I did early on add a pair of fans to the top-rear of the cabinet... I wonder if that has anything to do with it, or if I'm just lucky so far?
If more of us valued food and cheer above hoarded gold, it would be a much merrier world.
grubavs is offline
post #23018 of 23033 Old 09-28-2014, 11:13 AM
audio4life's Avatar
Liked: 141
Yeah, I've been running an 876 since 2008 and it's been flawless. I saw that resistor failure but never had the problem. I don't like the lit volume knob and never ran it lit up. As a matter of fact, I acquired a 906 in about July with non functioning HDMI board. I attempted the fix as outlined in a thread here, and the things been flawless ever since. The old Onkyos really do rock, but at the same time I'm getting sucked in by Atmos!
audio4life is offline
post #23019 of 23033 Old 09-28-2014, 01:56 PM
dogaza's Avatar
Thanks to all for response.
grubavs: If you don't mind, where did you get you fans? Just felt mine after running for 4+ hours - really hot. I have over 3.5" of overhead space.
dogaza is offline
post #23020 of 23033 Old 09-28-2014, 03:03 PM
NorthSky's Avatar
Liked: 430
Originally Posted by Smarty-pants View Post
Not really a need for that if you get the right player. Many disc players now have two HDMI outputs that can be used to pass audio to an avr, and separate video to the display. This helps to bypass an avr that might not be compatible with 3D.
Exactemente. ...Like the Oppo 103 for example ($399 refurb directly from Oppo).
And Sony has few models too, for approx $180 (street), with them two HDMI Outs.
* Like your new avatar Dave.
Smarty-pants likes this.
post #23021 of 23033 Old 09-28-2014, 03:06 PM
NorthSky's Avatar
Liked: 430
You have been 'locky' to not have experienced a failure with your display, so far, methinks.
* The fans have nothing to do with that resistor's wrong value.
post #23022 of 23033 Old 09-28-2014, 03:12 PM
NorthSky's Avatar
Liked: 430
Definitely put @ least one 4" fan on the top right rear corner.
* Just goggle around (Amazon, etc.); they are avail everywhere. Just go to your local computer department store; they have them there, and you just plug it into the rear AC outlet of your 805.
post #23023 of 23033 Old 09-28-2014, 04:25 PM
NWCgrad's Avatar
Quoted: 108 Post(s)
Liked: 103
Mine has been in constant use since I bought it new so long ago I cant recall the date. Its been literally around the world due to navy moves and still have not had any problems.
I am planning on getting a new receiver after the Christmas holidays. No idea what brand but with Onkyo dropping Audyssey it probably will not be an Onkyo.
Varibus Mari Victoria
NWCgrad is offline
post #23024 of 23033 Old 09-28-2014, 05:30 PM
NorthSky's Avatar
Liked: 430
Go with Denon, or Marantz.
post #23025 of 23033 Old 09-29-2014, 09:28 AM
AVS Club Gold
grubavs's Avatar
Look back in this thread to posts around # 2173 or so. That's not the ones I use, but the technology has changed quite a bit. Just check it out.
Coolerguys
I wasn't going to use fans at first, as I could see that the 805's fans were acting as designed... extra power output = fan speed increase and 2nd fan came on as appropriate, but changed my mind (luckily) after reading here that these fans were easy to use. In my opinion (as well as others') the sound level was most important since my 805 is right out in the AV room (and I still thought adding fans was an extra, but not necessary decision).
I got mine on ebay. They came as a connected pair with a long enough cord to spread them out, and with a power brick that I plugged into the switched AC outlet on the 805's rear panel, and a 5-speed controller (which allows you to decide between cooling amount and fan noise... I believe mine is set to the second from lowest speed). I've spread them so one is on the top right rear about 1 inch in from the rear edge and 2inches in from the side, and on the left rear about two inches in from the rear and two inches in from the side. I put a thermometer in various places on the top to determine where the most heat was... after reading in this thread that the main source of heat was the HDMI board (I think... again, a long time ago) and not the power supply board. So, 2 fans = cover both bases.
As I recall, the consensus here was that sucking air out the top was the easiest to do, and quite effective, method to cool.
grubavs is offline
post #23026 of 23033 Old 09-29-2014, 10:21 AM
Quoted: 142 Post(s)
Liked: 134
^ Yep, main heat source is the HDMI board, which I always thought was odd.
If you run the AVR without using HDMI, it doesn't even get warm.
~Dave
post #23027 of 23033 Old 09-29-2014, 03:49 PM
dogaza's Avatar
Just picked up an IR Thermometer this afternoon. I knew it was running hot, but never thought it was this HOT.
Here are my temps.(F) after 1 hour: FL = 95.3, FR = 100.7, RL = 103.1 & RR = 110.6.
after 2 hours: 101.9 109.7 107.9 119.3.
Sure got my attention. I also picked up a 4" fan at RS, but I need to get a plug so I can just plug it into the 805 outlet.
Is anyone surprised at these numbers, or is this the norm for Onkyo?
My old HT was with Adcom seperate amps and I had them stacked in an enclosed rack cabinet. Never got hot to the touch.
Phil
dogaza is offline
post #23028 of 23033 Old 09-29-2014, 04:08 PM
AVS Club Gold
grubavs's Avatar
Phil
47°C tops? Not abnormal. I no longer have my temp listings, but I'm sure I remember >50°C (I kind of remember ~60°C, but memory is always suspect).
grubavs is offline
post #23029 of 23033 Old Yesterday, 12:35 AM
NorthSky's Avatar
Liked: 430
The 805 definitely gets hot, real hot. ...And heat is bad for electronics. It needs @ least one fan on top, if not two, depending of the owner's own usage on average.
* From all the receivers I had over the course of my lifetime, the 805 was the hotter of them all.
...The price we had to pay for all that true power. ...But that heat @ the wrong place; on the HDMI board.
...Which is Onkyo's main achille heel.
post #23030 of 23033 Old Yesterday, 05:51 AM
asere's Avatar
Quoted: 33 Post(s)
Yep that is why I bought these fans and no hot issues now.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
asere is offline
post #23031 of 23033 Old Yesterday, 04:19 PM
Quoted: 142 Post(s)
Liked: 134
I know it gets hot... really hot... but the AVR really is designed in a way to handle the heat.
I don't know if I have ever even seen a post on here describing an 805 that broke because of overheating.
My brother also owns an 805, and doesn't know much about how to get the best out of his system.
He even has it in a cabinet that has a shelf too close to the top of the AVR, and should have more room to breath, and no external fan.
I told him that it need more room, but he didn't seem to care. To this day after this many years, his 805 still works like new.
I initially used mine for a while without fans, no problem... then I put a fan on it for about 6 months, and while it wasn't "noisy",
I could still hear it and it bothered me so I stopped using the fan. Did that for like a year and no problems.
Now I don't use the 805 with HDMI anymore, just with analog and basically use it as a power amp for all my surround channels. Still works beautifully.
Having said all that though, using an additional fan is good preventive maintenance.
~Dave
post #23032 of 23033 Old Yesterday, 09:11 PM
NorthSky's Avatar
Liked: 430
That, should have been supplied inside the box with the 805.
___________
@ Dave; my brother has my 805 (gift) and it is still working like new, with only one small 4" fan over the HDMI board, on top. He has the dimmer on the lowest setting and can see very clearly @ twelve feet from it.
I also told him to turn off all that CEC control crap, the onscreen display (for volume showing, etc.), and not use the video processor in it but pass thru. ...All good.
He uses only two HDMI inputs, as a video switcher, that's all,...works perfectly. ...Good enough.
But! I did not tell him about Dolby Atmos, yet.
post #23033 of 23033 Old Today, 12:17 AM
Quoted: 142 Post(s)
Liked: 134
^Atmos?... meh...
I think once Auro gets roots it will be much better than Atmos.
Still not even thinking about buying a new processor for at least a couple years though.
~Dave
User Tag List
