"The" Onkyo TX-SR805 Thread - Page 773 - AVS | Home Theater Discussions And Reviews
 28Likes
post #23161 of 23174 Old 02-17-2015, 11:21 AM
Quoted: 39 Post(s)
Liked: 3
Originally Posted by grubavs View Post
A. Just watched Fury last night... WOW, what a flick! Though it really does remind of Saving Private Ryan, the FX are way better. You can almost believe the death and destruction and sweating and dirt and human interactions.
B. Watched BD of Gone Girl (I usually watch ripped BDs/DVDs via a Mac) the other night and noticed the heat was really building up behind the 805... and I have 2x120mm fans on top. I upped their speeds a notch. Highly recommend you get fan(s) per other suggesters.
Thanks, I went and ordered the one I posted, hope this does the job and I get at least a couple of more years out of this AVR.
iluvwahoo is offline
post #23162 of 23174 Old 02-17-2015, 12:50 PM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 16 Post(s)
So, I just searched this thread for fans (to remind myself about my purchase 7 years ago) and found this, which seems to be the latest iteration of what I originally bought. As mine seem to be cr@ppin' out, I bought this from Amazon Coolerguys Dual Blower Fan Component Cooler with Manual Speed Control (Lite)
Product Description
We created this kit for use on components which have vents on the top of them, simply place the blower fans on top and it'll suck the warm air out of the device and shoot it out the back.
Works great to cool Receivers, DVRs and other media equipment.
This kit comes with:
2 Coolerguys 12v Blower Fans
1 500mA 110-12v AC-DC Power Supply
1 Dual 3pin Manual 12V DC Variable Speed Controller
Everything you need to power and control both blower fans to cool off your equipment.
Fan Specifications:
Dimensions: 120x120x25mm
Bearing: Dual Ball
Rated voltage: 12v
Operating voltage range: 8-12v
Rated Current: 0.18A
Lock rotor current: 0.16A
Rated Power: 2.16W
Rated Speed: 1000 RPM±10%
Air Flow: 17 CFM
Static Air Pressure: 5.6 mmAq(InchH20)
Noise Level: 19.8 dB(A)
Life Expectancy: 50,000 Hours @ 25C
SKU: 840556094326
Rem facias, rem
si possis, recte, si non, quocumque modo, rem.
grubavs is offline
post #23163 of 23174 Old 02-18-2015, 12:34 PM
aprice01's Avatar
I bought this one from Amazon: http://www.amazon.com/CabCool-Lite-C...+Home+Theaters
It has worked fine, and keeps the unit cool.
aprice01 is offline
post #23164 of 23174 Old 02-24-2015, 10:35 AM
smoorenc's Avatar
I was looking at getting the new 1030 Onkyo, but to make it a 7.1.4 I need an amp. Can I make my 805 into an amp?
smoorenc is offline
post #23165 of 23174 Old 02-24-2015, 12:06 PM
Augerhandle's Avatar
Quoted: 134 Post(s)
Liked: 114
Since the 1030 has pre-outs, yes. The 805 has multi-channel inputs. Set it to Pure Audio mode. This is also my plan for upgrading to a 3D/4K AVR.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
Augerhandle is offline
post #23166 of 23174 Old 02-24-2015, 01:34 PM
smoorenc's Avatar
Will the volume on the 805 (used as an amp) go up or down according to what the pre-out of the 1030 does?
I justed tested with my OPPO player, I have the 7.1 dedicated going to multichannel on receiver. I put the oppo to variable out and the volume went up and down on the Onkyo Thanks!!!
smoorenc is offline
post #23167 of 23174 Old 02-24-2015, 10:03 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 3515 Post(s)
Liked: 1221
Hey, best use from the 805; its amp section.
NorthSky is online now
post #23168 of 23174 Old 02-25-2015, 10:35 AM
Quoted: 134 Post(s)
Liked: 114
Just shows it's value. One doesn't replace it, one adds to it. If it was any other non-Atmos, non-3D receiver, it would be up on craigslist.
post #23169 of 23174 Old 02-25-2015, 01:54 PM
lkstaack's Avatar
After seven years of ownership, I'm planning on using my 805's Zone 2 capability. Now I find that only analog sources are compatible with Zone's 2 and 3. Most of my content comes through my home theater PC. What is a good work-around for getting digital content to play on Zone 2?
Lars
lkstaack is offline
post #23170 of 23174 Old 02-25-2015, 02:22 PM
NorthSky's Avatar
Liked: 1221
♦ ...Analog only. ...So, best to to connect your digital components with also analog connections. ...I'm sure you have tons of analog interconnects around.
post #23171 of 23174 Unread Today, 07:46 PM
Liked: 0
HDMI output
Hi
Sorry, I am sure it has been discussed but there are a ton of pages of messages about the 805. We purchased ours back in 2007 as part of our home theatre system. A couple years back the HDMI out quit working. We have been bandaiding it for the past few years (running the HDMI directly from projector to DVD player and switching to SAT receiver when needed) and using sound cords to the receiver for speakers. Not optimal but couldnt justify the expense of a new receiver.
I am not very technical so I probably dont have the best system but it works for our little family.
Our projector is a Sharp XVZ-12000 so it only displays up to 1080i. We purchased a new Sony receiver only to find out it wont work with our projector. So back to square one. I think I would just like to get the ONKYO fixed.
What solutions are out there for the HDMI out fix that these machines have had?
TIA!
Kari
mikebanders is online now
post #23172 of 23174 Unread Today, 07:58 PM
NorthSky's Avatar
Liked: 1221
I would simply get something newer. ...It's not worth the aggravation to search for repairs.
Yeah, get a new receiver with preouts (an inexpensive one to use as a pre/pro), and use your 805's internal amps. ...Some' like that.
And 2007 is eight years ago; that's a long time.
post #23173 of 23174 Unread Today, 09:18 PM
Quoted: 134 Post(s)
Liked: 114
Originally Posted by mikebanders View Post
...We purchased ours back in 2007...
...And 2007 is eight years ago; that's a long time.
Eight years old? That's 56 in dog years (...the same principle applies with electronics)
post #23174 of 23174 Unread Today, 09:42 PM
NorthSky's Avatar
Liked: 1221
...Even more so nowadays, with lifespan becoming shorter.
