"The" Onkyo TX-SR805 Thread - Page 776 - AVS | Home Theater Discussions And Reviews
 31Likes
post #23251 of 23259 Unread Yesterday, 07:21 AM
goldark's Avatar
Quoted: 63 Post(s)
Originally Posted by NorthSky View Post
You are listening to stereo music in your small bedroom with these magnificent hi-end loudspeakers, and you're going to power them with a receiver like the Onkyo 805?
Power wise no problem; but if I was you I would give them dignified/refined/clean amplification, like say from a Bryston stereo amp. Then you'll have the lowest distortion and the cleaner bass, midrange and highs articulation and resolution.
www.bryston.com/products/power_amps/4BSST-2.html
Haha, yeah. Unfortunately, I don't quite have the funds for a high-end amp and just need something with enough power to do the speakers some justice. I bought them used and got an amazing deal on the Mozarts so couldn't pass them up. I've been reading up on 2 branches of thoughts here - that given enough clean power (and you're not pushing the amp in any way), that amps should sound the same? And then the other opinion is that amps sound different, even when operating comfortably within spec.
I know the 805 has enough power for my needs and listening levels. In your opinion, by upgrading to a high-end emp, would the audible improvements be significant enough to justify the additional cost?
goldark is online now
post #23252 of 23259 Unread Yesterday, 11:58 AM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East
Quoted: 4378 Post(s)
Liked: 1703
If you get a quality amp like the one I just suggested in that link; you would notice. ...Your loudspeakers are high enough resolution for you to discern between several amps and their characters.
Don't take my word for it, experience it for yourself; that is the least your speakers deserve, and in the name of the love for ♪ music.
...Both from the amp and the preamp, or a quality integrated amp, for two components in one (simplicity & space).
Also, the fact that you got your Mozarts for a good price (deal) don't mean you need to match them with a receiver that you got for a good price as well.
I'm sure you can get a good deal on a second-hand stereo integrated amp from Bryston. ...That seems more like it to me.
NorthSky is offline
post #23253 of 23259 Unread Yesterday, 04:38 PM
Augerhandle's Avatar
Quoted: 232 Post(s)
Liked: 156
And if you don't have a stereo preamp, Bryston also makes integrated amplifiers.
The Onkyo 805 has pre-outs, so no pre-amp is necessary.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_________________________________________________
Augerhandle is offline
post #23254 of 23259 Unread Yesterday, 04:43 PM
Quoted: 232 Post(s)
Liked: 156
Yes, that is the question. Is the audible difference worth 4-5 times the cost of the Onkyo?
post #23255 of 23259 Unread Yesterday, 05:00 PM
NorthSky's Avatar
Liked: 1703
I was thinking of a stereo preamp; for purists, like the OP with his Mozart loudspeakers.
And only him can evaluate performance/value ratio wise. ...Nobody else.
NorthSky is offline
post #23256 of 23259 Unread Yesterday, 07:13 PM
Quoted: 232 Post(s)
Liked: 156
Agreed.
post #23257 of 23259 Unread Yesterday, 07:16 PM
NorthSky's Avatar
Liked: 1703
...And I was simply sharing my own thought. ...But sure, the 805 has ample power for his speakers; no problemo here.
NorthSky is offline
post #23258 of 23259 Unread Today, 08:06 AM
KMFDMvsEnya's Avatar
Quoted: 51 Post(s)
Liked: 136
I have owned this receiver since 08 and after doing the firmware update with the jig and one version of the DTS bomb fix the unit has been pretty rock solid with extensive usage over the years.
Alas there is a problem becoming more common overtime, it is increasing in regularity with at least one of my optical inputs. Specifically with the optical connected from my TV the audio stutters for a while but it will eventually self-correct. Originally it seemed to help to turnoff the unit or switch inputs to fix the issue but now that no longer does anything so I have to wait, if it occurs.
Plus it has happened with at least one of my HDMI inputs that is connected to my PC so it is not solely isolated to that optical input.
Guess my 805 maybe hinting at giving up the ghost.
I have been debating on getting a Denon 4520ci refurb but it seems a lot of folks have been mentioning issues with those units from A4L recently. My budget is limited and 1,000 is the upper limit for now. If I have to seek out a replacement does anyone of have some advice?
KvE
Politics is like a corral, no matter where you are you'll always be shovelling it.
KMFDMvsEnya is online now
post #23259 of 23259 Unread Today, 12:10 PM
WERA689's Avatar
When my Onkyo died, I replaced it with a Denon AVR-X4000. Now that the newer models are out, you should be able to find one within your budget. It's been outstanding so far!
WERA689 is online now
