Ohm'age and 504 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-07-2007, 10:23 AM - Thread Starter
Wozzer73's Avatar
I'm getting a set of Velodyne CHT front row's whose impedance is listed as:
"6 ohms (compatible with 8 ohm receivers)"
I'm thinking about pairing them with an Onkyo 504 since it's cheap, however on Onkyo's site it lists the 504 power output at 8 ohm and specs say it is NOT compatible with 6 ohm speakers.
Can I pair these successfully? Is there another receiver in the ~$200 range I should consider?
Wozzer73 is offline
post #2 of 6 Old 06-07-2007, 11:03 AM
steve71's Avatar
Quoted: 73 Post(s)
Liked: 37
If you do a search I've asked & answered this question a few times.
steve71 is online now
post #3 of 6 Old 06-10-2007, 08:21 PM - Thread Starter
Wozzer73's Avatar
I can't seem to find the threads you're referring to, would you mind pointing me in the right direction?
Wozzer73 is offline
post #4 of 6 Old 06-10-2007, 09:36 PM
steve71's Avatar
Quoted: 73 Post(s)
Liked: 37
Try a search for 'Onkyo' in post by 'steve71'. If that doesn't turn up anything, let me know.
post #5 of 6 Old 06-10-2007, 09:53 PM
Jakeman02's Avatar
The 504 will power the CHT's with no problem. Lots in the HTIB Alternative thread and putting together a budget combo have paired them together. For the price it's a great combo.
Jakeman02 is offline
post #6 of 6 Old 06-11-2007, 08:28 AM
JOHNnDENVER's Avatar
My brother in law has been running a refurbed 504 with 6ohm speakers for a looooong time now. No problems, and he has the thing cram'd in there, virtually no ventalation and these run pretty darn hot.
JOHNnDENVER is offline
