The "Official" Denon AVR-3808CI Thread - Page 646 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 03-09-2012, 08:16 PM
nintari's Avatar
Quoted: 12 Post(s)
Really enjoying this setup so far but running in to a problem with the 3808ci and my htpc during blurry playback where If I pause skip or ff I lose the audio when I go to play again? If I mess with the receiver it re-syncs and plays again. I did end up having to swap my gtx 470 with a 6950 I had in my sons computer since the 470 will not pass dtshd or truehd
Setup:
Paradigm studio 60 v2 left right
Paradigm cc-370 center
Jbl control 5 surround
Outlaw audio lfm-1 plus
Denon avr-3808ci
Mitsubishi 65" Dlp
Gaming htpc
Watching star wars episode IV on Bluray right now
nintari is offline
Old 03-10-2012, 01:23 AM
blairy's Avatar
Quoted: 51 Post(s)
Liked: 29
Originally Posted by JefCon View Post
Cool. I set the speakers to Small, x'd-over @ 60Hz yesterday. My immediate impression is that the Sub is doing too much now. Not overloading or anything like that. It just seems more noticeable that there is a sub in the system. I'm going to let it stay this way for several more movies and see if it is just my ears that need adjusting.
On the plus side, I finally got my amp to turn on and off using a 12v trigger. It had nothing to do with the Denon. My amp is setup to daisy chain the 12v signal and requires a dummy plug in the spare jack. I wish I would have read that more carefully 10 years ago because it never worked with my Lexicon either. For 10 years I've been doing it manually.
I have a question about playing CDs through a Blu-Ray. Right now I just have HDMI coming to the receiver from the Blu-Ray player. In my last system I only had the optical cable for audio... So I set up a virtual "CD" source using the optical audio input from the Blu-Ray - so it could have different surround processing assigned to it when I wanted to hear a CD.
I tried to do the same thing with the Denon, but there is no HDMI choice for audio on the CD source (or I wasn't looking in the right place). But, looking into it further, it looks like the Denon will 'remember' what I last used for each "signal type" and will auto-magically use it for that signal type every time until I change it? So, if I'm understanding this right, there is no reason to set up a virtual "CD" source for playing CDs through the Blu-Ray unless I want to assign a different audio source (optical, analog) for CDs?
Yes the 3808 will remember your choices for each signal type over the same input. This is known as the Personal Memory Plus function. Very handy.
Having said that, there are some benefits to setting up another digital/analogue connection for CD's.
If playing CD's, you probably don't want the TV on. Some BD players via HDMI have difficulty with the TV being turned off. HDMI handshake or HDCP protocol or some such thing.
Playing via optical/SPDIF or analogue avoids this issue.
Also, signals input to the 3808 via HDMI cannot be passed to a second zone. So if you wish to listen to your CD's in another zone with separate speakers you'll have to use optical or analogue (or SPDIF).
Cheers
blairy
blairy is offline
Old 03-10-2012, 01:49 PM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Ok - any advice on this: I've connected my PS3 (Fat - older version) to the AVR via HDMI and the output goes to my 3D projector. I have turned up the AVR's upscaling (no A-H or H-H turned on) and yet the PS3 does not see my projector as 3D ready. really frustrating. I even tried 3D demo PS3 games that are in 720p 3D and it says it can not locate a 3D display.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
Old 03-10-2012, 02:49 PM
Browninggold's Avatar
Liked: 37
3808 is not 3D capable receiver....@ least I hope it isn't that's one of the reasons I upgraded to the Denon A100
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
Old 03-11-2012, 08:18 AM
mrcarnut's Avatar
Quoted: 25 Post(s)
The 3808 is not 3D capable as it is but if you had a Blu Ray player that outputs dual HDMI such as the Oppo 93 you could have 1 HDMI to the projector and 1 to the 3808. That is how I would go instead of changing the receiver.
mrcarnut is offline
Old 03-11-2012, 08:23 AM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
As previously mentioned, although only a few 3D formats will pass through the 3808CI, success also depends on the display ... some work others don't.
jdsmoothie is online now
Old 03-11-2012, 08:46 AM
Liked: 37
I was answering the post above mine as his was not working as jdsmoothie said there are a lot of variables also mrcarnut as you mentioned
Old 03-11-2012, 08:51 AM
Liked: 37
That's why I said one of the reasons. There's a few more... I did enjoy my 3808ci though no problems with it whatsoever. My son has that now in his BR. Lucky boy. With that being said I am very glad I upgraded to the A100. I guess I am a happy and proud owner.
Old 03-11-2012, 09:23 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Next weekend I'll try my prior 'work around' since it's not seeing 3D through the 3808 from my PS3. I'm going to unplug the HDMI from the AVR, schlep the PS3 w/the HDMI plugged into the back of it over to the projector; plug the HDMI directly into the Projector; XMB the video options so it sees 3D connected; then unplug it from the Sony, plug it back into the AVR (without unplugging the HDMI from the back of the PS3) and see if that works. THat's what I had to do before to get 3D through the AVR when I had it connected to my Mitsy 3D TV. I have a Panny 3DBD player w/dual HDMI out's that I use for 3D movies: I want to use the PS3 for 3D games.
Wryker is offline
Old 03-12-2012, 10:13 AM
irmoballen's Avatar
This may be a stupid question: but if I'm not using 3d, does this receiver still hold up well? I have a chance to buy a used (but in perfect condition) 3808 for $300 and am wondering whether I should do that compared to buying a brand new Denon 1611 for a little less money?
Thanks for any help/advice!
irmoballen is offline
Old 03-12-2012, 10:24 AM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
If you don't need 3D it's a great option.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 03-12-2012, 10:31 AM
irmoballen's Avatar
Originally Posted by batpig View Post
So I take it you did not read the series of posts immediately before yours?
I made sure to read the last few pages before I posted
I guess more specifically my question is whether the sound quality of the higher end 3-4 year old models would be better than the brand new budget models....I would assume it would be better, but I just wanted another opinion before I made the final decision.
Old 03-12-2012, 10:34 AM
batpig's Avatar
Liked: 3420
Sorry I misread your post. I thought you said if you do use 3D. Couldn't edit fast enough.
The 3808 will blow away any newer entry level models.
Setup Guide and FAQ
batpig is offline
Old 03-12-2012, 10:39 AM
irmoballen's Avatar
No problem, thanks for the input!
Old 03-12-2012, 12:12 PM
jdsmoothie's Avatar
Liked: 5548
That's actually a great price! Check with the seller to see if the unit has the $100 feature pack upgrade, otherwise, you may want to consider buying and installing it.
http://usa.denon.com/US/Support/Pages/upgrade.aspx
Old 03-12-2012, 12:25 PM
longbow's Avatar
The 3808 is a wonderful receiver. I have 2 of them and they are great. The 1612 is a much lower quality model.
EricN"You are in a maze of twisty passages, all alike" HT: Denon 4311CI, Oppo BDP-105D, M&K S-150's LCR & ss-150's SL & SR, SVS PB12+, Epson Home Cinema 1080, Stewart StudioTek 130 92"
longbow is offline
Old 03-12-2012, 04:56 PM
dirk1843's Avatar
Quoted: 12 Post(s)
I say go for the 3808, you can't beat it for that price.
I've seen things you wouldn't believe. Attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the dark near the Tannhauser gate.
dirk1843 is offline
Old 03-12-2012, 05:03 PM
Liked: 37
Get the 3808... Great power. I still like mine
Old 03-12-2012, 05:11 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Mine just keeps on working but I don't think I've touched it in about four years. Well maybe just the duster.
Gary J is offline
Old 03-12-2012, 06:17 PM
Liked: 37
Time to upgrade Gary to the A100 or 4311.
Old 03-12-2012, 06:48 PM
uforia's Avatar
Thanks to the previous replies, just wanting to check I have everything connected and setup for best audio quality.
I have connected my front speakers to a NAD stereo amp which has Main-In rca's (acting purely as a power amp) I connected the Denon 3808 front speaker rca outputs to the main-in on the stereo amp. I had to play around with the Amp assign in the Denon - is Zone 2 correct? Any other denon settings i should change/update?
Basically I just want the receiver to treat the front speakers as an extention of my other surround speakers - allowing it to work as normal in 5.1 with auddsey or only the fronts with pure direct. I have a PS3 connected to my receiver via HDMI for music and movies if this makes any difference thanks.
uforia is offline
Old 03-12-2012, 08:22 PM
batpig's Avatar
Liked: 3420
amp assign is irrelevant -- that controls the assignment of the *internal* amps of the Denon, and then only the last two (which you aren't using). So just leave it on Zone 2, won't hurt anything.
You don't need to change anything at all to use external amps, just hook it up, RCA from the FR/FL pre-outs on the 3808 to the inputs on the external amp.
next run test tones (Manual Setup > Speaker Setup > Ch Level) to confirm output is still good. You might also want to make sure the NAD amp is configured properly, sounds like it's an integrated amp and there may be a switch that allows it to convert to "pure" amplifier mode. Set the NAD to a fixed volume (check the manual if possible as there may be a specific volume setting that is "unity gain" for use as an amp).
Once you have confirmed a "good" hook-up, re-run Audyssey and off you go!
Setup Guide and FAQ
batpig is offline
Old 03-17-2012, 04:38 AM
kerenlaser's Avatar
Hi everybody, this is my first post in this forum.
I plan to back up some of my vinyl collection as hi-res files in an HDD. I plan to use the "Pure Vinyl" software, which is best used with a good external audio interface ("sound card"). I thought that before I spend money on the external device, I might try to harness the 3808ci built-in ADC and DAC capability. I assume they are good for 192/24 conversions. I read the manual, but could not figure out how to send the ADC output over to the computer, which will probably be a Mac Mini.
My idea is to feed the cartridge through the line input, and perform the RIAA eq and click-pop reduction in the PV software.
Your help will be greatly appreciated.
Best regards, Eli
kerenlaser is offline
Old 03-18-2012, 09:11 PM
xb1032's Avatar
Liked: 26
I'm guessing this answer is no but is it possible to control the user interface for the 3808CI over TCP/IP using an ipad? I am assuming I'll have to use IR for this one.
xb1032 is offline
Old 03-19-2012, 12:09 AM
blairy's Avatar
Quoted: 51 Post(s)
Liked: 29
Best regards, Eli
There is a section in the manual about recording. Check that for starters. It's pretty complex from memory.
Blairy
blairy is offline
Old 03-19-2012, 05:03 AM
nintari's Avatar
Quoted: 12 Post(s)
xb1032: you can control the receiver via iPad, not sure if you can call up the menu on the TV screen and control it that way though, I can look next time I get a chance.
I started a thread on the Denon series iOS / Android control apps, feel free to add to it http://www.avsforum.com/avs-vb/showthread.php?t=1397073
Havent updated it recently with any info as I have been really sick over the past week and a half!
nintari is offline
Old 03-19-2012, 06:41 AM
jdsmoothie's Avatar
Liked: 5548
Yes, there are a couple of iPhone/iPad REMOTE apps: DeRemote and DenONOFF.
Old 03-20-2012, 01:45 AM
blairy's Avatar
Quoted: 51 Post(s)
Liked: 29
Is you AVR on your network? Use the iPad, open a browser and point it to your AVR's IP address.
Hey presto, control of your receiver.
Regards
blairy
blairy is offline
Old 03-22-2012, 07:42 PM
xb1032's Avatar
Liked: 26
Regards
blairy
I'll connect a patch cable from my Denon to my router and give it a shot as soon as I get the time. I'll check out the app thread as well. Thanks for your help all!!!
xb1032 is offline
Old 03-22-2012, 07:53 PM
hhglcyes7's Avatar
When is the 875 due out? Price? Also other then the video scaller difference what are some of the other major differences between this and the 3808? Links to a full spec sheet
hhglcyes7 is offline
Denon Avr 3808ci Receiver
