The "Official" Denon AVR-3808CI Thread - Page 648 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #19411 of 20654 Old 04-13-2012, 04:28 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
There should be no issue with drives up to 2TB as long as they are formatted in FAT32.
jdsmoothie is offline
post #19412 of 20654 Old 04-13-2012, 07:27 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
My cable box seems to have a lower volume than BR, any way to tweak the levels to get them closer. I usually listen at -15MV.....
In other words i would like to match the levels so -15 sounds kinda the same out of both....
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #19413 of 20654 Old 04-13-2012, 08:55 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
yes, each input has a SOURCE LEVEL control that is variable +/-12dB.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #19414 of 20654 Old 04-13-2012, 09:05 PM
CynKennard's Avatar
The input level of each source can be set on the input source menu. See page 38 of the owner's manual for a description of source level.
Cynthia
CynKennard is offline
post #19415 of 20654 Old 04-13-2012, 09:54 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Thx ladies and gentleman..... That was easy
post #19416 of 20654 Old 04-14-2012, 05:21 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
I find that concert BR's need a little balancing to get them right, is there a way to one button my way back to the default Audyssey settings as to levels ?
post #19417 of 20654 Old 04-14-2012, 10:40 AM
cfraser's Avatar
Quoted: 128 Post(s)
Liked: 72
^ Probably the easiest way is to save a particular setup in a Quick Select button. This isn't exactly what you want, but you might be able to come up with something using them that's at least a little more convenient.
I have also wished that there could be preset master volume levels you could quickly return to. Kind of like the different muting levels, but for master volume and one-button. I can surely see the "danger" of this too, along the same lines that Denon locks you out of the menu if muting is on (that's slightly annoying too).
cfraser is offline
post #19418 of 20654 Old 04-14-2012, 12:57 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
3808ci owner, looking to upgrade to a receiver that has 3D passthrough such as the 3812ci, was curious if anyone has opinions on if there are any negatives in upgrading from 3808ci to 3812ci such as if Denon cut corners on this line as it progressed.
WynsWrld98 is offline
post #19419 of 20654 Old 04-14-2012, 01:04 PM
batpig's Avatar
Liked: 3415
There is no 3812ci. There is a 3312ci which is a step down from the 3808ci. The best "upgrade" would be a 4311ci.
Setup Guide and FAQ
batpig is offline
post #19420 of 20654 Old 04-14-2012, 01:05 PM
jdsmoothie's Avatar
Liked: 5502
There is no 3812, rather the current successor to the 3808CI is the 4311CI with Audyssey MultEQ XT32 soon to be replaced by the 4520CI in Sep. The 3312CI is the successor to the 2809CI and uses the same version of MultEQ XT as does the 3808CI.
post #19421 of 20654 Old 04-15-2012, 03:28 AM
blairy's Avatar
Quoted: 48 Post(s)
Liked: 29
Thanks jdsmoothie, helpful info. Presuming 4520 isn't a typo (and I'm sure it's not) what's happened to the standard numbering sequence for Denon AVR's?
In the past the last two digits have referred to a calendar year; eg nn08 referred to AVR's for 2008 (although typical these were available in the latter half of the prior year).
cheers
blairy
blairy is offline
post #19422 of 20654 Old 04-15-2012, 03:46 AM
jdsmoothie's Avatar
Liked: 5502
Due to a shortage of parts, Denon has discontinued the previous "flagship" models 5308CI and AVP. The 4520CI will be replacing both the 4311CI and the 4810CI and will become the new "flagship" model. Unsure as to why they changed the number convention.
post #19423 of 20654 Old 04-15-2012, 12:53 PM
dirk1843's Avatar
Quoted: 12 Post(s)
I would guess for a longer perceived life cycle....some folks might be adverse to dropping the money for a 5308 when just the name says it is 4 year old tech.
This unit won't be tied to a year of release.
Just my .02 cents.............
I've seen things you wouldn't believe. Attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the dark near the Tannhauser gate.
dirk1843 is offline
post #19424 of 20654 Old 04-15-2012, 01:06 PM
jdsmoothie's Avatar
Liked: 5502
4 years old yes, but there's currently a $1000 upgrade that brings 3D and Audyssey MultEQ XT32 to both the 5308CI and the AVP.
post #19425 of 20654 Old 04-19-2012, 07:47 PM
Jay O'Brien's Avatar
My wife alerted me, and I confirm that only our front speakers are working. Can someone point me to a web page that will help me diagnose the missing speakers that used to work fine on my 3808CI? The Denon manual is ZERO help.
It would be great if there was a way to send audio of some kind to only one set of speakers, if only for test.
Thanks, Jay O'Brien, Folsom, California
Jay O'Brien is offline
post #19426 of 20654 Old 04-19-2012, 08:17 PM
hansangb's Avatar
Most likely, you accidentally activated the pure direct, or Direct Stereo mode. There are two buttons when you open the front panel. If that's not it, you can try using Audyssey to generate the tones to see if the speakers are recognized.
good luck.
hsb
Hansang
hansangb is offline
post #19427 of 20654 Old 04-19-2012, 08:52 PM
kevinwoodward's Avatar
Quoted: 22 Post(s)
good luck.
hsb
A quick check would be to run 5/7 channel stereo option
kevinwoodward is offline
post #19428 of 20654 Old 04-20-2012, 02:17 AM
jdsmoothie's Avatar
Liked: 5502
What does the front panel display when audio is playing? As others have noted, you're likely in STEREO mode.
post #19429 of 20654 Old 04-21-2012, 03:41 PM
good luck.
hsb
Great idea, but that isn't the problem. I had forgotten about those two buttons. Thank you!
post #19430 of 20654 Old 04-21-2012, 03:43 PM
How can I do that? The audio comes from my ATT U-Verse box if that makes any difference.
Thank you!
post #19431 of 20654 Old 04-21-2012, 03:49 PM
It says TV/CBL Direct. It is getting TV and audio from my U-Verse box.
Jay
post #19432 of 20654 Old 04-21-2012, 04:25 PM
jdsmoothie's Avatar
Liked: 5502
Jay
If the mode is DIRECT as you indicate that is indeed your issue. You need to get into a STANDARD mode (via STD button) and select DD PLII - Cinema.
post #19433 of 20654 Old 04-21-2012, 06:08 PM
I was able to hit the Standard button and then was able to get to 5CH Stereo, which now turned on the other speakers. Hooray!
You say to select DD PLII - Cinema; how do I do that, and what will it get me?
Thank you for your much appreciated help! Now, what did I do, and where can I learn (again) about what just happened. I was really up on the Denon several years ago, but it has just been used to watch TV recently and I am embarrassed to see how much I have forgotten, leaving the Denon alone to its own devices (helped by humans, I'm sure).
Jay
post #19434 of 20654 Old 04-21-2012, 06:42 PM
jdsmoothie's Avatar
Liked: 5502
While playing a SD channel (ie stereo audio), you should be able to select DD PLII - Cinema while cycling through the various STD settings. This mode takes the PCM 2.0 signal and will simulate 5.1 surround sound. The 5 CH Stereo mode simply replicates the FL/FR speaker stereo to the SL/SR speakers as well as mixes to the center speaker (ie. not true surround).
post #19435 of 20654 Old 04-21-2012, 07:12 PM
The closest I can find is Dolby PLII music. I find, however, that Jazz Club sounds the best to me, but I would like to raise the back and side channel levels a bit.
Obviously I need to learn more about what is available, can you suggest where I sould start?
In the meantime, thanks to your guidance, it sounds much better with the back and side channels now doing something!
Jay
post #19436 of 20654 Old 04-21-2012, 07:20 PM
jdsmoothie's Avatar
Liked: 5502
Surround modes listed on pp. 41-42. You can change from Music --> Cinema using the Parameter menu (p. 42).
post #19437 of 20654 Old 04-21-2012, 07:52 PM
My surround modes starts on pp.40, and I don't see where to change from Music --> Cinema in the Parameter menu that begins on pp.41. We must have different versions of the manual.
post #19438 of 20654 Old 04-21-2012, 08:10 PM
jdsmoothie's Avatar
Liked: 5502
Then download the manual from Denon's website in .pdf format which is what I refer to, although regardless you should be able to get the right menu location from MENU-->Parameter---> Audio ---> Surround Parameters ---> Mode.
http://usa.denon.com/us/Downloads/Pa...ionManual.aspx
post #19439 of 20654 Old 04-21-2012, 08:24 PM
I haven't been using the GUI, only pushing buttons. I now see what you mean, and when my wife (SWMBO) is through watching her Idol recordings (that she agrees are now better) I'll give it a try with the GUI.
Jay
post #19440 of 20654 Old 04-22-2012, 08:11 PM
Jay
In the GUI, I cannot get to MENU-->Parameter---> Audio ---> Surround Parameters. At MENU-->Parameter---> Audio ---> the selections are Tone, Room EQ, RESTORER, Night Mode and Audio Delay. The selection for Surround Parameters is not there. My manual does show many selections under Surround Parameters, but I can't get there!
What should I do now?
Jay
Denon Avr 3808ci Receiver
