The "Official" Denon AVR-3808CI Thread - Page 675 - AVS Forum
post #20221 of 20226 Old 06-27-2014, 12:11 PM
venon1313's Avatar
Recently I bought a Dune HD base 3D media player. I connected it to my Denon 3808 through HDMI and image quality was good, but not as good as my Denon dbt 3313.
I have found that Dune has deep color settings. Mine was 8 bit default, so I changed it to 10 bit and the image improved a lot. Then I tried 12 bit but Denon 3808 seems not to accept this setting. The image appears and disappears constantly. Reading the manual, somewhere is said that Denon 3808 supports 12 bit deep color. Connecting Dune direct to the TV I can use 12 bit deep color without any issues. Anyone knows how to solve this? Thanks.
venon1313 is offline
post #20222 of 20226 Old 06-28-2014, 05:39 AM
CHuntMD's Avatar
The 3808 does not allow 3D pass through. For my WD TV Live! I run the HDMI to the TV and the optical audio to the 3808. I do the same with the 3D BlueRay.
CHuntMD is offline
post #20223 of 20226 Old 06-28-2014, 07:50 AM
AVS Club Gold
aaronwt's Avatar
Quoted: 200 Post(s)
Liked: 578
The 3808 has no problem with 2D 12bit Deep Color.
aaronwt is offline
post #20224 of 20226 Old 06-29-2014, 07:36 AM
venon1313's Avatar
If I set the video output of the Dune in 1080i/60 instead of 1080p/60 it works.
post #20225 of 20226 Old 06-29-2014, 09:20 AM
AVS Club Gold
aaronwt's Avatar
Quoted: 200 Post(s)
Liked: 578
If it is 2D and you need to drop it down then I would try a different HDMI cable.
aaronwt is offline
post #20226 of 20226 Old 06-29-2014, 11:45 AM
venon1313's Avatar
Thanks. It's 2D. 3D is disabled on Dune because my Tv is 2D. I had imagined that the problem could be the cable. Then I used the cable that runs from 3808 to the TV to connect the Dune directly on the TV. IT worked fine at 1080p and 12-bit deep color. Very strange.
Denon Avr 3808ci Receiver
