The "Official" Denon AVR-3808CI Thread - Page 679 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #20341 of 20651 Old 11-10-2014, 09:19 PM
outabounds68's Avatar
Thanks again JD. I also figured out how to turn off the volume display on the TV by getting to that menu.
Next question. How do you set a default station to come on when selecting Tuner? It always comes on an AM station when I turn on the Tuner.
Brett
outabounds68 is offline
post #20342 of 20651 Old 11-11-2014, 06:24 AM
jdsmoothie's Avatar
Quoted: 12076 Post(s)
Liked: 5499
See #2 in my previous post.
jdsmoothie is offline
post #20343 of 20651 Old 11-18-2014, 02:49 PM
hometheaterguy's Avatar
Does Denon have a firmware update for the 3808ci, for Dolby Atmos?
A veteran is someone who, wrote a blank check Made Payable to 'The USA, ' for an amount of 'up to and including their life.'
hometheaterguy is offline
post #20344 of 20651 Old 11-18-2014, 03:07 PM
jdsmoothie's Avatar
Liked: 5499
Hah! Funny guy. Atmos and Auro3D will only be available on the 2014 and newer models.
post #20345 of 20651 Old 11-18-2014, 03:57 PM
MTAtech's Avatar
Quoted: 14 Post(s)
Of course -- as soon as the firmware upgrade comes out for my 1975 Pinto that will give it fuel injection, anti-lock brakes and self-parking.
Seriously, the 3808ci is several generations old and if such models could be simply upgraded through firmware, the manufacturers couldn't sell new models.
MTAtech is offline
post #20346 of 20651 Old 11-19-2014, 09:35 AM
HighAltHD's Avatar
If I'm getting low output out of one speaker for multiple sources, is a microprocessor reset a step in the right direction? It seemed to me after searching and browsing through this thread, that a reset was a suggestion for similar problems.
I also just upgraded to the feature package upgrade and I can't believe I didn't do it five years ago. I have no idea what I was thinking.
HighAltHD is offline
post #20347 of 20651 Old 11-19-2014, 10:34 AM
jdsmoothie's Avatar
Liked: 5499
First swap the speaker with another speaker in the setup to ensure it's not a speaker issue.
post #20348 of 20651 Old 11-19-2014, 03:36 PM
MTAtech's Avatar
Quoted: 14 Post(s)
LOL, ur probaly the kind of guy, who drives a Pinto, ha ha.
Well, I did have one when I was a teen but not since.
MTAtech is offline
post #20349 of 20651 Old 12-06-2014, 08:08 AM
jsmiddleton4's Avatar
Quoted: 588 Post(s)
Liked: 199
Moving some stuff around as I'm doing an interim update of my home theater receiver and moving the 3808 to my office. In my office I still use vinyl and have dbx disk. What I had was an older legacy style receiver with a tape monitor loop in which was placed the DBX decoder-decompresser for my DBX vinyl. When needed it, just hit tape monitor button.
How do I set this up with the Denon 3808? I'm looking and obviously doesn't seem clear as I'd not need to ask.
Also did processor reset. Which wiped out some stuff but all my Audyssey settings were still in place, etc. What does processer reset "reset"?
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #20350 of 20651 Old 12-11-2014, 07:57 PM
Quoted: 588 Post(s)
Liked: 199
I still have not found anything in terms of being able to use a dbx disk decoder and a tape monitor loop. Not talking about setting up a cassette deck.
Only way I can find is to do phono preamp with dbx unit inbetween the preamp and the Denon. But that defeats the entire purpose of using the Denon with its included phone preamp section.
TT to preamp to DBX decoder to Denon. Can bypass the DBX encoder.
But then can't use it for Cassette.
I'd need two dbx decoders/compressors.
And that makes no sense.....
post #20351 of 20651 Old 12-11-2014, 08:02 PM
Quoted: 588 Post(s)
Liked: 199
Did find this but need a little help connecting the dots. Can the 3808 do this?
Modern home theater receivers usually include extra "zones". If your receiver has a fixed analog output for "zone 2" etc, then you can create a tape loop. Run the "zone 2" output to the tape deck's input, and the tape deck's output to your receiver's analog audio input. Assign the zone 2 output to whichever input you wish to record, and switch your main zone's input to whichever input the tape deck is connected to.
post #20352 of 20651 Old 12-12-2014, 06:13 AM
jdsmoothie's Avatar
Liked: 5499
The microprocessor reset should return all settings (including Audyssey) to factory default. Not sure why yours did not.
The configuration can be done yes, although not sure how it will sound.
post #20353 of 20651 Old 12-12-2014, 06:24 AM
Quoted: 588 Post(s)
Liked: 199
Good morning jd....
I've done multiple resets including the network reset with the up and down arrow buttons. And it could be most of the receiver is reset and the receiver might actually be reset. What isn't showing as if it is reset is the web interface. It didn't get a lot of attention before FW development stopped for it. Something in the display for the web interface isn't clearing. I cleared my IE cache, same with Google Chrome. Still showing old stuff. I'm not hooked to a monitor in my office. However when I cycle through the front menu options on the unit itself settings appear to be cleared.
I also noticed that via the web interface I only have two language options, English and French. But through the front display options there are quite a few options.
Either the web interface code is messed up some how or the couple of bugs it possessed never got squished.
It is clearly over kill for an office receiver. It is worth holding on to however.
Now to tackle the tape monitor loop thing by trying the Zone 2 option.
post #20354 of 20651 Old 12-12-2014, 07:47 AM
Quoted: 588 Post(s)
Liked: 199
I'm getting no signal at all out pre-amp zone 2. Regardless of source. I have Zone 2 set to the appropriate analog source by using the buttons on the front.
I have some setting wrong somewhere.
How do you use the pre-amp zone 2 outs?
post #20355 of 20651 Old 12-12-2014, 07:53 AM
Quoted: 588 Post(s)
Liked: 199
Got it. Had to set the volume output to 0db for Zone 2 setting. That changed the pre-outs to line out.
I'm listening to Gino Vanelli DBX vinyl. Nice.
post #20356 of 20651 Old 12-12-2014, 04:09 PM
samandnoah's Avatar
I'm having trouble performing the reset. I've looked at p58 in the manual, and it looks like it should be working, but no reset happens even after waiting for an hour. All of the input set up details are still there. I'm wondering if I'm waiting too long, too short, letting go of the buttons in the wrong order...
So here's what I'm doing:
1. I make sure the amp is off using the "big" button (which I think says standby and something else)
2. Then I turn off the "little button" <power>
3. Then I hold down the <Standard> and <DSP Simulation> buttons on the front panel, and simultaneously press the little <power>button.
4. I get the whole front panel lit up and flashing ~1/second which sounds like what it's supposed to do. So then I let go of buttons simultaneously, and then it seems to go to starting up as if no reset were taking place. It does go to the FM input, which was NOT the last input it was on. So it seemed almost as if it was starting. But nothing seems to be happening, even after waiting over an hour.
5. I have tried releasing several different button release sequences. Letting go of power first, letting go of the Standard/DSP button first, holding it down for a really long time (it eventually went into regular start up mode), holding it for a short time (just enough time to see it flash twice).
So what does a successful reset look like? Are there any tricks to the reset? Other ideas?
Actually, let me describe the issue in case there's another solution that I wasn't able to find while searching a 679 page thread. Basically, the set-up the for each source is not showing up on the left/source side. And changes are not retained when I go into the set up for each source. This all started after a lightening hit the house. But it all lights up and the FM input worked with static audible until I tried to start messing with the inputs. I guess it had been clear/unused before. I'm pretty much at a loss, and don't want to drag it/ship it to a repair center if there is something I can actually do here. And I've had this receiver since 2008, and have had it working this whole time. But maybe there is some newbie issue I'm forgetting given that I haven't played with a lot of the settings in a long, long time.
Thanks in advance for any advice.
Rich
samandnoah is offline
post #20357 of 20651 Old 12-12-2014, 10:52 PM
Quoted: 588 Post(s)
Liked: 199
"This all started after a lightening hit the house."
I'm thinking a reset is not going to fix anything.
post #20358 of 20651 Old 12-13-2014, 07:22 AM
samandnoah's Avatar
Yes, lightening, but it's still working in some cases...
Except that 1) it turns on/lights up, and 2) and some inputs like USB/Net where I hadn't done a set up in years (maybe ever?) ARE working and playing music. I was able to update the firmware successfully. I went to the browser interface and tried updating the inputs that way, but that didn't seem to make a difference -- though I may not be applying those updates correctly. I find that part confusing.
Anyhow, both the pre-amp and amp sections are working to some extent. And I'd assume that Denon would not use more than 1 piece of RAM to store all of the input settings. So that's why I feel like I've got a shot at solving this without going to repair.
Rich
post #20359 of 20651 Old 12-13-2014, 07:47 AM
Quoted: 588 Post(s)
Liked: 199
There isn't anything to "apply" in terms of how "Apply" usually works/looks for stuff like Windows. There is a "Set" for renaming stuff. Once you select the input option when using the web interface the unit changes to that option.
The web interface can be flakey. I suggest trying the menu via a display monitor.
I've not taken apart by 3808 but have cleaned it. So it could be there's a stick of ram in it somewhere. I've not seen anything that is user changeable in that regard. Everything is soldered to the PCB's.
There is some modular stuff and you might be able to do a plug n play kind of repair. But again that is based on knowing what might me impacted by the lightening.
I hope it works out for you. I'd not have my hopes too high.
There's only two resets. The power button with the standard DSP buttons you've noted. Then the network or LAN reset with is the power button and the up and down arrows.
post #20360 of 20651 Old 12-21-2014, 02:40 AM
Liked: 0
Exclamation Please wait....
Hi all.
I've been enjoying my AVR-3808ci for a few years now. It's been a wonderful receiver for all my needs. Unfortunately, I recently started getting an error msg when trying to use NET/USB. It now just hangs on "Please wait... AssigningNetwork" or it goes straight to "Network Problem". If I back out and check the info in network setup, it shows it's getting an IP address like normal but just wont let me past the "Please wait..." or "Network Problem".
Nothing has changed, everything is the same... i.e. router, etc. I have tried everything I could think of and have done all the hard reset procedures. Still no joy. Like I said, it's been working for years. I have a 1TB HD filled with my music that I have plugged into the USB that I access via the web browser. That no longer works because it won't go past "Please wait..."
So I'm thinking I have to send it in to get serviced but before I do I figured I'd give you guys a shot.
Any help will be greatly appreciated!
Rob
Rob Cosentino is offline
post #20361 of 20651 Old 12-21-2014, 06:17 AM
jdsmoothie's Avatar
Liked: 5499
Is the AVR wired directly to to the modem or connected wirelessly via a bridge modem? Have you rebooted the modem/router as well? Do you have another router you can try? Can you take it to a neighbor's house to test?
post #20362 of 20651 Old 12-21-2014, 09:51 PM
Liked: 0
Thanks for the reply.
It has always been hard wired to either a router or switch . I have tried multiple routers/switches, no luck. Like I said, it gets it's dynamic IP from the DHCP server, it just hangs on "Please wait...". I use this receiver everyday. It has done good for the last 4 years. Every other function still works 100%. I just think something is failing, probably an IC.
post #20363 of 20651 Old 12-22-2014, 03:22 AM
jdsmoothie's Avatar
Liked: 5499
Try using a static IP address.
post #20364 of 20651 Old 12-22-2014, 07:14 AM
davelr's Avatar
Quoted: 28 Post(s)
Probably a long shot, but while you're trying a static IP address, try an alternate DNS source. I'd suggest OpenDNS whose server addresses are 208.67.220.220 and 208.67.222.222 (secondary). Might not help, but can't hurt either.
davelr is offline
post #20365 of 20651 Old 12-27-2014, 08:08 AM
spiroh's Avatar
Quoted: 58 Post(s)
Hello Everyone,
Glad to see there are still several people using this AVR. I got mine when it first came out and have been extremely pleased with it. About a year ago we moved so I had it disconnected for about a year and I was just using the TV sound output. I decided to connect the AVR again so I can get output to my Axiom M80's and wow. Totally forgot how nice it sounded especially over the TV speakers. I have a problem and I was wondering if I can get some advice. Right now I have it connected by using an optical out cable from the TV over to one of the optical in of the AVR. I am trying to minimize the sound processing. If I have the surround mode to Dolby, Neural or Stereo I get sound. Whenever I choose Direct surround I get no sound even though the indicator lights turn on the AVR. The optical signal coming in from the TV is PCM. Does anyone have any idea how I can get Direct or Pure Direct to work in my configuration?
Thank you
spiroh is offline
post #20366 of 20651 Old 12-27-2014, 11:38 AM
spiroh's Avatar
Quoted: 58 Post(s)
Forgot to mention I just upgraded the 3808 to the latest firmware available and then I tried doing the steps published in the firmware thread. When I go to add new feature the Upgrade ID is not listed. I wanted to reach out to support to get the upgrade pack. Is there another way I can find my Upgrade ID? Thank You
spiroh is offline
post #20367 of 20651 Old 12-27-2014, 03:04 PM
spiroh's Avatar
Quoted: 58 Post(s)
Figured out both issues. I connected the AVR to the internet and after it failed it gave me the ID. I called support and they took the ID and someone will be calling me on Monday to get the upgrade enabled. In regards to the DIRECT mode. I first talked to chat support and they told me I have a defective AVR. They performed no troubleshooting steps. When I called support I spoke with another technician and it really didn't go anywhere and he came to the same conclusion that the AVR was defective. I didn't buy this as an answer so I connected my xbox one to the AVR and the Direct modes were working right away. Now that I knew the AVR was not defective I started troubleshooting a little further. I could not get the TV, Roku, or Fire TV to use pure mode withoptical or hdmi input but the Xbox One worked automatically with either option. I played around with the AVR settings and I went into option. I changed the AMP ASSIGN mode from 2CH to Bi-Amp or 7.1 mode and it worked! Extremely happy right now.
spiroh is offline
post #20368 of 20651 Old 12-27-2014, 03:12 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
What is the point of Pure or Direct with marginal sound signal from Roku, etc,?
Gary J is offline
post #20369 of 20651 Old 12-27-2014, 06:21 PM
spiroh's Avatar
Quoted: 58 Post(s)
Because I want minimal processing from the AVR coming to the speakers.
spiroh is offline
post #20370 of 20651 Old 12-28-2014, 05:03 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
That is what it does with high end audio ONLY. You will not hear a difference unless you convince yourself you do.
Gary J is offline
Denon Avr 3808ci Receiver
