The "Official" Denon AVR-3808CI Thread - Page 682 - AVS | Home Theater Discussions And Reviews
 8Likes
post #20431 of 20440 Old 04-25-2015, 04:19 PM
Larry M's Avatar
Quoted: 28 Post(s)
Liked: 44
Unlike more current models that have a Zone 2 HDMI monitor output that pass both HDMI audio/video by design, a main zone HDMI output can only pass audio if the setting is changed from "AMP" to "TV" (see p. 30 in your Owner's manual).
Well, that is extremely awful
I love this receiver because it does a lot of great things, but this and HDMI zone 2 not working kinda disappoints
Thank you for the help
I guess I'll just have to get Zone 2 going in that room, too bad because the speakers on that TV are actually pretty good
Larry M is offline
post #20432 of 20440 Old 05-21-2015, 06:05 AM
MrCreosote's Avatar
Liked: 0
Unhappy Front speakers not playing
The front speakers recently cut out on my 3808. I had been thinking it was something weird with
how the HDMI and optical inputs were working, but when I switched to a stereo source it was clear that it is just that the front L&R speakers are not working.
I did the factory reset and all that seemed to accomplish was deleting all my settings (GRRRR)
The Audyssey setup will not work because it does not see the left front speaker. When I go try the manual setup, I get no test tone out of the front L & R speakers. Also, it seems to be stuck in 5.1 mode even though I have a 7.1 setup.
Denon support said that if the reset did not help, then I have to take it in for service. I am hoping someone here can give me a clue what is going on so I don't have to go that route
MrCreosote is offline
post #20433 of 20440 Old 05-21-2015, 06:19 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4081 Post(s)
Liked: 2269
Try connecting another set of speakers to the FL/FR speaker posts to ensure the issue isn't with the FL/FR speakers themselves. If not, try unplugging the AVR for 10 minutes, then plug back in and do a series of microprocessor resets (at least 4-5). If still no joy, the amps are likely dead. Try setting the AMP ASSIGN to "Bi-Amp" and connect your FL/FR speakers to the SBL/SBR speaker posts which if it works, will drop you to a 5.1 setup but at least allow you to continue without servicing the unit.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #20434 of 20440 Old 05-21-2015, 07:36 AM
cdnscg's Avatar
Quoted: 104 Post(s)
I've had some crazy HDMI issues recently with my Pioneer SC25, although it may not be the same for you, try unplugging all the HDMI inputs, and use an analog input. At least that should let you know if it is the HDMI board in the avr. I would do this when the unit is cold.
cdnscg is offline
post #20435 of 20440 Old 05-21-2015, 05:22 PM
MrCreosote's Avatar
Liked: 0
An HDMI issue was actually my first assumption. Switching to an analog stereo signal is what got me to realize it was just the speakers not playing.
I'll give it another try though with my fingers crossed
post #20436 of 20440 Old 05-22-2015, 11:41 AM
MrCreosote's Avatar
Liked: 0
Red face Damn Lady Gaga
After some more investigation, it turns out the speakers are blown and the 3808 is fine.
My wife must have killed them listening to lady Gaga on the treadmill
I was able to rearrange the speakers to get down to 5.1 instead of 7.1 for now.
In my frantic searching through the receiver menus, I did find a volume limiting setting. You better believe it is turned on now!
Thanks again for the advice
post #20437 of 20440 Old Today, 01:37 PM
jwheeler's Avatar
So just purchased my first projector which has 3D and of course discovered my trusty 3808 wont pass along the 3D signal. Been wanting a couple of more HDMI inputs anyway so I suppose its time to look into a new receiver. Its been a couple of years since I have read anything about the new Denon models so I am wondering from the forum which current model is considered the one to get these days? still on 1080p but would certainly like to be as future proof as possible. Any suggestions?
jwheeler is online now
post #20438 of 20440 Old Today, 04:08 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2269
All of the 2104 models can now do 3D, so just depends on your budget and whether you want the same level of Audyssey MultEQ XT (X1100W, X2100W, X3100W) as the 3808CI or the better Audyssey MultEQ XT32 (X4100W, X5200W, X7200W). Review post ##2 in each of the Denon 2014 Owner's threads to review features of each model.
The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ
The "Official" 2014 Denon Atmos+XT32 Model Thread (X4100/X5200/X7200)
post #20439 of 20440 Old Today, 04:41 PM
cdnscg's Avatar
Quoted: 104 Post(s)
If you plan on passing 4K through your avr, you'll have to insure you secure one of the few models than can do this right now. I understand many manufacturers will have models in the second half 2015. In the meantime, for 3D, you can do what I'm doing when I want to watch 3D. Run the HDMI cable direct from the BD player to the pj, and an optical cable from the the BD player to the avr.
cdnscg is offline
post #20440 of 20440 Old Today, 09:27 PM
jwheeler's Avatar
Thanks for the info. running direct to the PJ with a fiber optic cable from the Xbox One to the 3808 is exactly what I did tonight and it worked fine. I will research the new models but maybe prudent to wait until the next models come out like you mentioned.
Denon Avr 3808ci Receiver
