The "Official" Denon AVR-3808CI Thread - Page 684 - AVS Forum | Home Theater Discussions And Reviews
post #20491 of 20515 Old 07-13-2015, 11:08 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4725 Post(s)
Liked: 2473
Could be the Belkin or loose or defective HDMI cables.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective? Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #20492 of 20515 Old 07-13-2015, 12:28 PM
tee.edwards's Avatar
Yeah, as I was talking to a co-worker about it, it occurred to me it's entirely possible the HDMI cable between the receiver and the TV is faulty. I will start with that, then the Belkin, then the other HDMI cables. On the plus side, I have access to a killer Denon vendor discount, if the receiver is at fault and I need to replace it.
tee.edwards is offline
post #20493 of 20515 Old 07-14-2015, 07:39 AM
I am relieved, if a little embarrassed, to admit that the issue was with one HDMI cable between my receiver and the set. I have never had an HDMI cable fail before, but I guess there's a first time for everything. This was a Monoprice cable, and while I have always had good luck with their stuff, nobody's perfect. Everything is fine now.
post #20494 of 20515 Old 07-14-2015, 08:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2473
Great! Thanks for reporting back. Enjoy.
post #20495 of 20515 Old 07-15-2015, 12:28 PM
g_e_young's Avatar
Originally Posted by batpig View Post
Audio Return Channel (ARC) refers to the ability of HDMI to pipe an audio stream back FROM the display TO the receiver over the single HDMI monitor connection. So if your TV has internally tuned audio (direct cable signal, smart apps like Netflix streaming, etc) you can pipe it back to your AV receiver without having to use a separate digital audio connection. One cable, two-way street.
Does anybody know if this will solve the problem? I finally got a smart TV and was just informed by the installed that the TV aps won't play through my AVR. Grrr.
Amazon: Search hdmi arc adapter
Thanks for the help!
g-
g_e_young is offline
post #20496 of 20515 Old 07-15-2015, 12:29 PM
g_e_young's Avatar
g-
Here is the link: http://www.amazon.com/ViewHD-Adapter...mi+arc+adapter
post #20497 of 20515 Old 07-15-2015, 12:34 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2473
g-
Correct. The 3808CI is only HDMI 1.3 while in order for HDMI ARC to work, the AVR must be at least HDMI 1.4.
You don't need this, rather simply connect an optical cable from the optical audio output on the TV to one of the AVR's optical inputs and set the TV's audio to "external speakers"/"home theater."
post #20498 of 20515 Old 07-15-2015, 12:38 PM
g_e_young's Avatar
Thank you for the quick reply...the problem is that my HDMI goes through the wall to an audio cabinet, and I'm thinking this little box might be a simpler solution than trying to fish more wires through the wall. I'm just not sure this little box does exactly what I need since most of the reviewers are doing something different than what I'm intending to do.
Thanks for the help..
g-
post #20499 of 20515 Old 07-15-2015, 12:55 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2473
g-
Right. This extractor is apparently used in only one direction which passes the HDMI signal through to the TV and extracts the audio via the optical audio output. Strange that they list it as an HDMI ARC device. You could try and contact the mfr to confirm.
post #20500 of 20515 Old 07-15-2015, 01:49 PM
g_e_young's Avatar
Note first paragraph below...a bit cryptic but I think it should work. Agree?
The VHD-H2HARC is the latest generation ViewHD HDMI Audio Extractor with MHL, Ultra HD / 4K and ARC supports. It extracts audio from the HDMI input and present it in SPDIF output or analog L/R output, for audio receiver / amplifier / headphone applications. The unit does not change incoming video and audio formats. HDMI output signals (audio and video) are identical to the HDMI input signals (audio and video).
This newer version incorporates special Audio EDID settings for flexible and advanced audio applications. The three special EDID settings are implemented to make the product more user friendly and provide more controls for various applications.
L/R outputs support PCM 2CH stereo and SPDIF supports audio formats up to Dolby Digital 5.1CH or DTS 5.1CH, therefore when the incoming HDMI audio is 2CH stereo, the SPDIF and L/R outputs will work at the same time; when the incoming HDMI audio is Dolby Digital 5.1CH or DTS 5.1CH, the SPDIF will work, but the L/R output will not work; when the incoming HDMI audio format is higher than Dolby Digital 5.1CH or DTS 5.1CH, such as Dolby Digital Plus, PCM 5.1CH, PMC7.1CH including Dolby TrueHD and DTS-HD Master Audio, both the SPDIF and L/R outputs will not work, user can still obtain these advanced audio signals from HDMI output, because HDMI output signal is identical to the HDMI input signal.
Use ARC button to turn on / off the ARC function as indicated by the ARC LED light; To use ARC function: 1) the ARC LED light must be on; 2) the display connected to HDMI output must support ARC and a HDMI v1.4 cable must be used to connect the HDMI output to the ARC enabled HDMI input of the display; 3) ARC audio is available from the SPDIF optical output ONLY. Typically, ARC audio uses Dolby Digital 5.1CH / AC3 surround sound format for audio system / receiver application.
post #20501 of 20515 Old 07-15-2015, 02:25 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2473
Sure. Strange that not one review (at least of those I read) shows it being used in that fashion though. Give it a try and report back the results.
post #20502 of 20515 Old 07-15-2015, 03:14 PM
williak's Avatar
There'll be an endless supply of these gizmos in every flavor coming onto the market. Lots and lots of perfectly good AVRs in place that are less than HDMI 1.4-capable. When someone hears of a particularly flexible HDMI splitter that is REMOTE-CONTROLLABLE, please post up its make, model, channel, and price.
williak is offline
post #20503 of 20515 Old 07-17-2015, 10:03 AM
g_e_young's Avatar
Deal - I will order it and install it when I get back from travel in a few weeks and let you guys know how it goes...
g-
post #20504 of 20515 Old 07-17-2015, 10:06 AM
g_e_young's Avatar
There are a bunch of options on Amazon, but it's hard to sort wheat from chaff.
http://www.amazon.com/s/ref=nb_sb_no...tical+splitter
Have fun!
g-
post #20505 of 20515 Old 07-17-2015, 02:35 PM
williak's Avatar
Have fun!
The idea was that you hard-up guys would do the guinea pig routine, then report back to let us big mules know what works/what doesn't. Any problem with that program?
williak is offline
post #20506 of 20515 Old 07-23-2015, 12:59 PM
batlin27's Avatar
Quoted: 32 Post(s)
Translation: search out HDMI switches that handle all this stuff (see Item 7974 Monoprice to see particulars, no recommendation implied).
Have you used this item ( 7974 Monoprice) ? I am looking to Watch 3D with my Projector, XBone and Denon 3808
batlin27 is online now
post #20507 of 20515 Old 07-23-2015, 01:06 PM
williak's Avatar
I have not. However, most products on most of the usual sites have user reviews associated with them. I suggest you consult them for actual experiences with the products you're considering. Good luck.
P.S. Don't forget Amazon; it also sells Monoprice products AND has an active review community.
williak is offline
post #20508 of 20515 Old 07-23-2015, 01:56 PM
batlin27's Avatar
Quoted: 32 Post(s)
post #20509 of 20515 Unread Today, 08:57 AM
batlin27's Avatar
Quoted: 32 Post(s)
Question for you all on my Denon 3808
I watch a lot of youtube videos on my tv, also stream music etc from different sources. It seams when I stream any sort of music / youtube I have little to no bass, and I also notice my Sub doesn't fire at all.
Can I get some advice for the following
For streaming music etc how do I get my sub to be used?
If I want to listen to Music in 7.1 (or just out of all the speakers) how do I do that?
Thanks all
Check out my theater build thread Theater on the Fairways Build
post #20510 of 20515 Unread Today, 09:10 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2473
Thanks all
After running Audyssey, if the AVR sets your FL/FR speakers to LARGE, reset them to SMALL/80Hz using Manual Setup which will then pass the lower frequencies to the sub as well as pass the load required to play them to the sub which has its own amp.
post #20511 of 20515 Unread Today, 09:14 AM
batlin27's Avatar
Quoted: 32 Post(s)
Awesome, Thank you... This has to be what it is because I noticed the fronts were set to Large.
Thank you!
post #20512 of 20515 Unread Today, 09:19 AM
rec head's Avatar
Quoted: 21 Post(s)
Liked: 43
Are your speakers set to Large or Small? Does your sub work with other media?
To listen using all speakers you just need to change the surround mode you are using. I can't remember which button on that remote. You want to try Dolby PLII, DTS Neo (or whatever it is called) and 7 channel stereo.
rec head is online now
post #20513 of 20515 Unread Today, 09:23 AM
batlin27's Avatar
Quoted: 32 Post(s)
The Sub works when I am listening to 5.1 and 7.1 content
Speakers got set to Large through Audysee
post #20514 of 20515 Unread Today, 09:41 AM
rec head's Avatar
Quoted: 21 Post(s)
Liked: 43
Set the speakers to small and set the cross over to 80hz and see how it sounds. Also make sure you aren't using Pure Direct or Direct mode.
post #20515 of 20515 Unread Today, 10:18 AM
davelr's Avatar
If you want to listen in stereo and have the sub work you should also check the following setup location after running an Audyssey calibration. I haven't run a calibration in a long time but my recollection was that the AVR set this area to a default of Large/no sub whenever a calibration was performed and I'd have to go in and reset them manually.
Manual Setup
Audio Setup
2ch Direct/Stereo
make sure Fronts are set to small, sub to yes (probably LFE mode) and the crossover is correct.
davelr is online now
Denon Avr 3808ci Receiver
