The "Official" Denon AVR-3808CI Thread - Page 685 - AVS Forum | Home Theater Discussions And Reviews
post #20521 of 20526 Old 08-08-2015, 08:40 AM
KitKatHT's Avatar
Quoted: 28 Post(s)
Liked: 7
Originally Posted by Azaqui View Post
I hope someone still visits this thread...
I have a weird issue with the 3808 - rear channel is not present during calibration or playback.
Now, the rear channel is handled by the last set of speaker jacks, described on backplate as rear / assign.
If those speakers are set to 7.1 they are not being detected during the audyssey setup,
You may have the manual speaker configuration set to 7.1 and not the Audyssey?
Be sure the Audyssey is also set to 7.1; I had the same issue not seeing the set-up was on 5.1; it is easy to check and change.
Little Denon system, Denon 2808ci
Polk M40, front and surround, CS2 center.Yamaha subwoofer
Sony 222 es SACD/CD player
Panasonic Blu-Ray player
Sony dual DVD and VCR player.
LG 46" HDTV.
KitKatHT is offline
post #20522 of 20526 Old 08-13-2015, 12:32 PM
dharalson's Avatar
Liked: 0
Issue with Main Power Switch
Kyle454 or others - I searched around and only found Kyle454's situation was like mine -
Did this issue with the main power switch not staying on or in standby mode ever get sorted out. The description below just happened to me yesterday AM. Kid tried to watch some cartoons, and nothing from the receiver - TV, Cable/DVR work fine, but unit was no longer in standby mode after watching a ball game the night before.
If I hold the switch in and turn the unit on all is good and seems to function as normal. Clearly, holding the switch down to watch TV/Movies/or listen to my choice of music is not going to work. Neither is paying a shop a bunch of cash if the its something more than a switch replacement.
kyle454 - so today out of the blue my 3808 receiver won't turn on! I noticed the red power indicator light around the bigger power button wasn't on, I press the power switch and the receiver turns on when I hold it down but when I let off the receiver shuts off? WTF! anyone had a problem like this?
Help plz!/
jdsmoothie
You're pressing the small button and it won't go in to Standby mode?/
kyle454Quote: Originally Posted by jdsmoothie
exactly!/
That is strange. Try unplugging the unit for a few minutes. If still no joy, you'll likely have to reset the microprocessor or may want to pop the top and see if you can find something loose or a blown fuse.
ok, will do, thanks
do you think never updating the FW has anything to do with it?
it worked fine last night...luckily it's still under warranty!/
kyle454ok, thank you!/
dharalson is offline
post #20523 of 20526 Old 08-13-2015, 12:38 PM
dharalson's Avatar
Liked: 0
Can't post links and such or PM Kyle454 to see what his resolution was. Can someone help by replying and adding his user name so he will be flagged to look at this?
post #20524 of 20526 Unread Today, 01:00 AM
dharalson's Avatar
Liked: 0
Bump
Bumping my last posts about the main power switch
post #20525 of 20526 Unread Today, 01:01 AM
dharalson's Avatar
Liked: 0
Bump2
Bump2
post #20526 of 20526 Unread Today, 04:50 AM
Liked: 0
Help sought - back speakers not present
If you only have a 5.1 setup, the surround speaker should be connected to the "Surround" speaker posts and not "Surround Back."
If you have a 7.1 setup, the SB CH OUT setting (p. 43 Owner's manual) should be set to PLIIx - Cinema.
This is a 7.1 setup, using "7.1" Audyssey mode, not the "7.1b" one.
The issue is I have no such option under the menu (SB CH OUT) - possibly because the speakers are not detected during the speaker calibration.
I might be wrong in assuming speaker calibration should work no matter what sound mode is chosen, as it is soundmode-agnostic?
Any and all help welcome!
Azaqui is online now
Denon Avr 3808ci Receiver
