The "Official" Denon AVR-3808CI Thread - Page 686 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #20551 of 20568 Old 10-29-2015, 04:37 AM
Liked: 0
Are there still compatibility issues with the 3808ci and Sony televisions?
Would the sync/etc issues still apply on newer Sony tv's?
thanks
B-Rayn is offline
post #20552 of 20568 Old 10-29-2015, 04:55 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 7363 Post(s)
Liked: 3393
Originally Posted by Carman72 View Post
hello, somebody can help, how can I conect two analog speaker on AVR 3808CI zone 2, ? and what happen with the central rear back speaker?
Set AMP ASSIGN to "Zone 2" and connect the speakers to the Surround Back L/R speaker posts. If you are currently using a single Surround Back speaker, you'll either have to give that up, or if you want to keep it, you'll need to connect an external 2CH amp (or another receiver) to the Zone 2 pre-outs on the 3808CI and then connect the Zone 2 speakers to that external amp. If you add the external amp, there would be no change to your current AMP ASSIGN setting of 7.1CH.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Sony, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
post #20553 of 20568 Old 10-29-2015, 09:10 AM
davelr's Avatar
Quoted: 27 Post(s)
thanks
Haven't a clue on newer Sonys. I'm still using my 2007 XBR4 with a Monoprice HDMI switch in between (no second device on the switch, it just sits between the two). I haven't had a single handshake glitch since setting it up this way. As a worst case you could do the same.
davelr is offline
post #20554 of 20568 Old 10-29-2015, 11:40 AM
Liked: 0
Ok thanks for the tip.
B-Rayn is offline
post #20555 of 20568 Old 11-03-2015, 09:06 AM
AVS Club Gold
aaronwt's Avatar
Quoted: 2735 Post(s)
Liked: 1463
Well I'm back to using my Denon 3808 until my 4520 can get repaired. I will miss the front heights but I forgot how good a job PLIIx cinema did. I have been using PLIIz with the front heights on the 4520. I'm just glad I never got around to selling my 3808.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
LED DLP
XBL/PSN: WormholeXtreme
aaronwt is offline
post #20556 of 20568 Old 11-03-2015, 11:30 AM
Neurorad's Avatar
Quoted: 183 Post(s)
Liked: 116
thanks
I replaced my Sony KDL a couple months ago with a 950b. I don't know what issues you're referring to, but so far have had no issues.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #20557 of 20568 Old 11-03-2015, 11:42 AM
davelr's Avatar
Quoted: 27 Post(s)
The issue was a degree of incompatibility in the HDMI interfaces. It presented as HDMI re-handshakes during viewing sessions. These generally resulted in brief (2-5 sec.) black screens and in most cases loss of audio. The severity seemed quite variable. In my case we'd experience this perhaps as often as a few times a day to a few times a week. Others, however, seemed to have much more severe problems and some people reported periods where the handshakes were virtually constant. I would hope that this is no longer a problem with newer TVs. That's not to imply that it's all Sony's problem as I did find some references to similar (although less common) problems on other brands of TVs.
davelr is offline
post #20558 of 20568 Old 11-03-2015, 04:27 PM
hansangb's Avatar
I'm sure things have gotten better. I too had a problem with 3808+Sony TV and PS3. It worked with Samsung TV. Replace the TV with Sony XBR and HDMI issues. This was about 3-4 years ago. Maybe 5.
hsb
Hansang
hansangb is offline
post #20559 of 20568 Old 11-04-2015, 09:00 PM
williak's Avatar
Quoted: 13 Post(s)
It's got a home right here anytime you feel like it's just taking up space...
williak is online now
post #20560 of 20568 Old 11-25-2015, 09:29 AM
seplant's Avatar
Quoted: 13 Post(s)
Can the 3808 store multiple Audyssey curves, or when a new auto setup is run, do the previously measured settings get erased? I know the Restore will go back to the previous Audyssey settings if any manual adjustments are made after running an auto setup, but I would like to go back to my previous Audyssey settings if I run a new auto setup and are not satisfied with the results.
seplant is online now
post #20561 of 20568 Old 11-25-2015, 09:41 AM
rec head's Avatar
Quoted: 28 Post(s)
Liked: 48
The 3808 will not store previous setups internally and I think that none of the Denons will do that.
You can save your settings to a PC. Check the beginning of the thread for details.
rec head is offline
post #20562 of 20568 Old 11-25-2015, 09:41 AM
rec head's Avatar
Quoted: 28 Post(s)
Liked: 48
rec head is offline
post #20563 of 20568 Old 11-27-2015, 07:50 AM
Liked: 0
Unhappy Receiver Always start on TV/CBL inpu
Hi,
Each and every time I start my receiver either via HDMI control triggered by my TV or directly by switching on my AVR 3808, it will start on the TV/CBL input!!
Is there a way to change that ?
I've tried the quick select option but it doesn't work.
Is it supposed to work like this??
ray_78 is offline
post #20564 of 20568 Old 12-01-2015, 01:27 PM
Tom C's Avatar
Quoted: 26 Post(s)
Originally Posted by ray_78 View Post
Hi,
I'm not familiar with turning on my 3808 with the TV. I didn’t see anything in the manual about it. I looked at the addendum with the Feature Package Upgrade info on page 17 and it looks like that maybe where you’ll find your answer.
With mine it comes on with the last input that I used. If I want it on a different input when turning it on, like DirecTV for example, I push the input button on my remote for the DirecTV input and it turns on the receiver and puts it on the DirecTV input.
If you have the feature pack, but not the addendum you can find it here:
http://usa.denon.com/us/downloads/manuals-and-downloads
Select AVR-3808CI and then "AVR-4308 3808CI Owners Manual -English Addendum (2.85MB)" from the list that drops down.
Hope that helps.
Tom C is offline
post #20565 of 20568 Old 01-24-2016, 06:56 AM
Liked: 0
hello all!
I'm a newbie who just purchased a 3808ci and I have two questions. first how can I hook up two sets of front speakers ( as A-B ) and second how can I get an audessey mic for it. audessey says it needs ACM-1 witch they longer make. I thank anyone in advance for help with these issues
rrhodes1973 is offline
post #20566 of 20568 Old 01-24-2016, 07:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3393
Originally Posted by rrhodes1973 View Post
hello all!
1. Set AMP ASSIGN = "2CH" (p. 69 Owner's manual).
2. DM-A405 mic ---> http://www.ebay.com/itm/like/3516021...chn=ps&lpid=82
post #20567 of 20568 Old Today, 03:41 PM
janky's Avatar
Hi there. I finally upgraded my DirecTV receivers to the Genie and I'd like to use the Genie remote as a Universal remote with my Denon 3808CI. I went through remote setup on the DirecTV menu and chose Denon3808CI. That allows me to control the volume on the Denon and the DirecTV guide as well as power on/off my TV. However, I'm unable to power on nor off the Denon 3808CI. Does anyone know a fix for this?
janky is offline
post #20568 of 20568 Old Today, 08:26 PM
williak's Avatar
Quoted: 13 Post(s)
My DTV remote controls work fine with my 3808s. Which code did you use to set it up? I just grabbed the first one, 31360, and it works fine for power on/off, volume (993), and input selection (numeric keypad). Haven't played with it too much, but I'd guess there are other controllable functions as well. (P.S. I use the big, old, clunky remote (my hand knows it well), but I also have the new sleek one for the Genie system that I could try if you'd like). Good luck.
Denon Avr 3808ci Receiver
