The "Official" Denon AVR-3808CI Thread - Page 687 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #20581 of 20602 Old 03-20-2016, 08:23 AM
hansangb's Avatar
Originally Posted by kevinwoodward View Post
So my ONKYO isn't working and I move my 3808 to the office.
I can't get anything to work on the DVR HDMI input
Sometimes I see the picture but not the audio.
Same component (cable box or apple tv) works on the other inputs.
Anyone have any idea what I have done?
thanks
UPDATE 1 hour later...
NO HDMI output. No OSD. No DENON logo.
tried 2 other tv's.
What could be going on here. NO OUTPUT today on ONKYO then same on DENON
Can a component or a bad HDMI cable cause this issue.
This is a nightmare.
first things first. Did you try a factory reset?
Hansang
hansangb is offline
post #20582 of 20602 Old 03-20-2016, 08:53 AM
maxmonty's Avatar
Posted this in the firmware thread too, but I'll try here too. I tried the firmware update yesterday and now I can't get any video out. No denon logo, no menu, nothing. I've tried the factory reset and microprocessor reset with no change. Any suggestions?
maxmonty is offline
post #20583 of 20602 Old 03-20-2016, 11:38 AM
kevinwoodward's Avatar
Quoted: 22 Post(s)
Yes I did. several of them.
kevinwoodward is offline
post #20584 of 20602 Old 03-28-2016, 03:22 PM
Plex's Avatar
I need to add a BT transmitter to my 3808, how do I connect it since there is no 3.5mm out jack, I only have the R/L RCA's as input.
Audyssey setup guide
Plex is offline
post #20585 of 20602 Old 03-29-2016, 03:57 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 10304 Post(s)
Liked: 4769
http://www.walmart.com/ip/39137232?w...988649&veh=sem
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, SVS, Oppo
Ask me how to get a FREE HEOS 1 HS2 wireless/Bluetooth speaker.
jdsmoothie is offline
post #20586 of 20602 Old 03-29-2016, 01:14 PM
Plex's Avatar
OK,, thanks I do have one of those, but which output do I connect too. I'm running CBL/TV input from STB, how do I keep that and still use BT?
Plex is offline
post #20587 of 20602 Old 03-29-2016, 08:30 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4769
Either of the VCR or DVR audio outputs.
post #20588 of 20602 Old 05-08-2016, 06:26 PM
oachalon's Avatar
I am bringing this thread from the dead. I have replaced my 3808ci with a new x6200W. My 3808CI has worked perfect except for the following:
Roughly 1 year ago, the receiver started forgetting its settings. It would completely forget what input is assigned to what connection. Also if the input was named it would forget this. This would only occur if the receiver lost power. Everything else on the receiver works perfect. Firmware updates worked without issues, the previous downloadable upgrades were still there etc. Just everytime it lost power, settings were lost, and i would then have to upload the settings back in over the network.
I want to use this receiver in another room, so hoping there might be a fix. Last time i asked, no one had ever run into the same issue. I was just seeing if anyone has had this problem occur, or has anyone ever completely disassembled a 3808ci and saw if there was an internal battery used to hold memory/settings.
oachalon is offline
post #20589 of 20602 Old 05-11-2016, 05:32 AM
henningdalgaard's Avatar
My 3808 changes HDMI input on my tv after approx 30 min
I have noticed that when my receiver is on, it changes the input of my Panasinc G20 series to HDMI4 after about 30 min.
I just switch back but it is annoying and especially when my kids are using the tv because they don't know how to change back to the correct input.
I am pretty sure this started to occur after I upgraded to the new firmware with hdmi control. Not sure if it has anything to do with it. I have tried to disable "HDMI Control" but it still changes input.
Any ideas?
henningdalgaard is offline
post #20590 of 20602 Old 05-13-2016, 06:51 AM
earthbound's Avatar
Interesting that you are having a similar problem to what I just started having with my 3808. It has probably been years since I upgraded the firmware so I don't think that is your problem. So within the last month the Denon input will change on its own with nobody touching any remotes, not even the cat stepping on the buttons. I'm only using the smaller remote. The bigger one with the display doesn't even have batteries in it. Maybe a full reboot will fix the problem. I may do that later today, but right now I need to cut grass and paint a couple rooms, and that is more important in maintaining marital bliss than fixing the Denon!
earthbound is offline
post #20591 of 20602 Old 05-13-2016, 10:01 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4769
Any ideas?
This issue has presented randomly on some more current models as well. If doing a microprocessor reset 4-5 times in a row doesn't resolve the issue, most likely cause is a defective HDMI board and the board is likely no longer available.
post #20592 of 20602 Old 08-09-2016, 12:06 PM
Liked: 0
Denon 3808Ci Help!
Good Morning All,
Really hoping to find some help here....not sure where to turn next. I received this Receiver (Denon 3808Ci) as a hand me down, and I'm really having issues getting this set up properly. So I guess I'll start at the beginning.....
I'm not using this device for a regular Home Theater application, rather, I'm using it in my home studio as my receiver/amplifier, mainly to route my audio from various components (TV,Xbox, etc) to an rca output that will connect to the rca input on my mixer and, I'd like the sound to route to my speakers, I have 2 sets of speakers (one set on either side of the tv at the front of the room, and one set at the rear of the room facing the front set) both with speaker wire inputs (not rca).
I have tried following the instructions to connect via hdmi (and composite for that matter), but I never could get it to work right. I just want to route the L/R audio from my TV outputs into the Denon L/R composite, then have the sound come out of all four speakers and one of the zone rca outputs (I don't care if its 2 or 3) to go to my mixer.
I have to admit I'm getting pretty frustrated, and I'm beginning to think I should just go get the best buy $99 special, but it seems like such a waste of an awesome receiver....but maybe its too much machine for my application.
Appreciate any assistance that anyone can offer....I hope I'm posting this in the right place.
D
damiansanford is offline
post #20593 of 20602 Old 08-10-2016, 03:31 PM
CHuntMD's Avatar
Try the Optical Out from the TV to the Optical In on the Denon.
CEH in MD
CHuntMD is offline
post #20594 of 20602 Old 08-10-2016, 03:56 PM
batpig's Avatar
Quoted: 3404 Post(s)
Liked: 3245
First forget about the mixer. Let's just get a basic audio input working to the 3808.
You can use either RCA analog or optical digital (as long as the TV is set to output 2.0 PCM stereo via digital) from the TV. Both 2.0 PCM over optical and analog RCA will be available via the RCA stereo outputs, but HDMI audio will NOT so forget about HDMI for this application.
Now, the problem is almost certainly your input assignments and input mode settings. If you are connecting to an input on the 3808 that has an HDMI input assigned to it, then you won't get the "lower priority" audio feeds because it will be expecting audio from the HDMI connection.
So you need to find the input settings in the 3808 GUI, and then make sure no HDMI input is assigned to the logical name you are trying to use. There is also an "input mode" setting which can toggle Auto>Digital>Analog so you can force the audio from a non-HDMI connection by changing from "Auto" to "Digital" (for optical) or "Analog" (for RCA).
Once you get that all sorted than the RCA output should be working too as long as it's selected as the Zone 2 source. And you can broadcast audio to all four speakers by selecting the "Multichannel Stereo" surround mode. Make sure to double check the speaker settings and disable all but Front L/R + Surround L/R so that no signal is going to unused speaker outputs.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #20595 of 20602 Old 08-12-2016, 09:54 AM
Bernie R's Avatar
Perhaps HDMI issue...
Hello All,
i purchased a Android TV Box "Greatever T95m" TV Box. I have a Denon 3808ci receiver with a newer Vizio TV. If i plug the T95 directly to the Vizio TV with the HDMI i can see the picture fine. but when i plug the T95 to my Denon 3808ci that is only HDMI 1.3 capable i only can see the T95 logo for a second, then the screen goes blank. I think the issue is that the T95 is HDMI 2.0 ? only? not backwards compatible with HDMI 1.3? please help! Bernie
Bernie R is offline
post #20596 of 20602 Old 08-12-2016, 05:15 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4769
Originally Posted by Bernie R View Post
Hello All,
Try updating the HDMI cables to the newer "Premium" HDMI 2.0 cables and if still no joy, you'll need to pass the video directly to the TV with audio to the AVR if you don't plan on updating the AVR to a more current HDMI 2.0a/HDCP 2.2 model.
post #20597 of 20602 Old 08-15-2016, 09:37 AM
Bernie R's Avatar
OK.
Having experimented with a family members cheap ( but much newer ) Yamaha receiver the problem lies with my older ( but expensive) Denon 3808ci receiver being HDMI 1.3 not working with this Android TV Box.
What do you guys think about this HDMI switcher with SPDIF/TOSLINK as my video switcher:
https://www.amazon.com/J-Tech-Digita...dp/B01296E5OO/
Will I be able to receive Dolby Digital into the 3808ci with the SPDIF link and it will recognize and play the DD 5.1 audio properly on my Denon?
thx,
Bernie
Bernie R is offline
post #20598 of 20602 Old 08-25-2016, 02:37 PM
Liked: 0
So I recently just bought the Denon 3808ci because this is my first home audio setup I have executed on and have the following speaker setup with it:
Polk Audio Monitor 70 towers
Polk Center CS10
Polk Bookshelf T15 Side speakers (ceiling mounted)
Polk Bookshelf R15 Rear speakers (Ceiling mounted)
Polk Sub PSW505
--I already know this system has way more than enough juice, but I am actually inquiring how I get the rear speakers to turn on for Cable and/or Tuner? I have only used the system thus far for Cable TV and Tuner, but it seem like the audio for TV is best guided by how the station is digitally setup through the cable provider; so, I have the setting on Direct right now, which mostly only uses the front towers and center with sub; Tuner can use any settings I choose except for 7 channel surround, it always goes back to 5 channel surround as default. Do the 5th and 6th channels only operate through a preamp, iPod dock, or DVD component?
prafferty82 is offline
post #20599 of 20602 Old 08-25-2016, 06:39 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4769
Polk Center CS10
Polk Sub PSW505
If you select the DD PLIIx surround mode, this will simulate audio to the Surround Back speakers.
post #20600 of 20602 Old 08-29-2016, 09:01 AM
Liked: 0
Thanks JD for the response. So I was able to get the Tuner to accept the DDPIIx but Tuner seems to only be able to produce sound on 5.1 maximum. I based this on the display image of the speaker locations that will receive sound by the AVR (SW, CTR, FR, FL, SR, SL).
As for the TV/Cable, I'm currently using HDMI, Digital Audio, Manual Surround, I do not have the option to pick DDPIIx - just 2 CH, Direct, Analog, and 5 CH. Could the DDPIIx not be there because it's HDMI and Digital Audio? Should I use RCA's or go Analog?
post #20601 of 20602 Old 08-29-2016, 10:22 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4769
Been awhile since I looked at the 3808CI manual, however, there is a SB CH Out setting (p. 43 Owner's manual) that must be set to PLIIx Cinema in order for you to be able to select that mode.
batpig likes this.
post #20602 of 20602 Old 09-11-2016, 11:31 AM
peterson65's Avatar
3808ci all video inputs dead
i have a 3808ci and the hdmi and analog video works. i have the denon menu but nothing external works throught the hdmi or analog to tv. i just get a black screen tried resetting the unit and the same thing. any techs out there that would have an idea what board may have went ? thanks
also tv sees a signal doesnt give the error no input also no audio from hdmi and i have audio set to amp not tv? so hdmi board is bad?
peterson65 is offline
Denon Avr 3808ci Receiver
