List of Receivers with 2 HDMI 1.3 outputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 56 Old 06-14-2007, 10:51 AM - Thread Starter
chuckvb's Avatar
I'm looking for a list of all the Receivers with two 1.3 HDMI outputs. Here's what I've got so far. I'll add more to the list as you guys send them in.
Note: Marantz SR-8001 has two HDMI outputs but they are not 1.3 version.
What other ones can we add to the list of future Receivers with 2 HDMI outputs?
chuckvb is offline
post #2 of 56 Old 06-14-2007, 12:50 PM
Vowani's Avatar
  • Sherwood Newcastle R-972
  • Onkyo AVR TX-NR905
Denon AVR-4308
And perhaps the Pioneer VSX-94TXH (specs not yet released).
Vowani is offline
post #3 of 56 Old 06-14-2007, 01:11 PM
esaleris's Avatar
Marantz SR-8001
esaleris is offline
post #4 of 56 Old 06-14-2007, 01:17 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Originally Posted by esaleris View Post
Marantz SR-8001
Not HDMI1.3 AFAIK....
____
Axel
Axel is offline
post #5 of 56 Old 06-14-2007, 02:03 PM - Thread Starter
chuckvb's Avatar
Marantz SR-8001
I thought I saw some where something about an update coming for it. Does anyone know anything about that?
chuckvb is offline
post #6 of 56 Old 06-14-2007, 07:55 PM
bootman_head_fi's Avatar
Quoted: 535 Post(s)
Liked: 340
HDMI 1.3 requires a hardware upgrade not a software one.
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
post #7 of 56 Old 06-14-2007, 08:01 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 421
HDMI 1.3 has a bandwidth requirement of 3x (400MHz) that of 1.2a so a revised HDMI Tx and Rx ICs are required...
M Code is offline
post #8 of 56 Old 06-14-2007, 10:26 PM
Quoted: 535 Post(s)
Liked: 340
My point exactly.
A new component purchase would be required.
Set an example:
post #9 of 56 Old 06-15-2007, 09:16 AM - Thread Starter
chuckvb's Avatar
How about Pioneer or Sony? Any offerings there yet?
chuckvb is offline
post #10 of 56 Old 06-16-2007, 09:10 AM
talbain's Avatar
or yamaha? i haven't heard boo from them...
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
post #11 of 56 Old 06-16-2007, 09:20 AM
rob316's Avatar
How about Panasonic Receiver.
Rob
rob316 is offline
post #12 of 56 Old 07-11-2007, 11:28 AM - Thread Starter
chuckvb's Avatar
I'm getting ready to pull the trigger on the Onkyo as it has the Reon video chip and my main purpose on top of quality sound processing is using this as my Video switcher and processor to my two display devices.
So any new announcements on dual HDMI output receivers?
chuckvb is offline
post #13 of 56 Old 07-11-2007, 12:22 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Heck, a number of these companies just put out HDMI 1.2 models within the past 12 months.
I suspect fall will bring more HDMI 1.3 models...
p.s. You probably won't gain anything from 1.3 over 1.2
"But this one goes up to 11"
MichaelJHuman is offline
post #14 of 56 Old 07-11-2007, 12:37 PM - Thread Starter
chuckvb's Avatar
The key is that is must have two hdmi outputs. And so far this is all I've found.
chuckvb is offline
post #15 of 56 Old 07-11-2007, 03:37 PM
CraigW's Avatar
Do the two outputs need to be independent (display different sources at the same time)?
I am not sure if any HDMI 2-output device can do that currently?
CraigW is offline
post #16 of 56 Old 07-12-2007, 03:30 AM
SMac770's Avatar
Are you asking about dual outputs for the main zone, or a receiver with an HDMI output for zone 2? Personally, I would just enhance the listing to cover both topics, if any examples of the second configuration exist. I'm sure there will be a point where HDMI delivery to secondary zones will be expected, but it's been like pulling teeth just to get component out in zone 2.
edit - also, just because it has dual main zone outputs (if that's the what the subject is about), does that mean that both outputs can be active at the same time? One could consider that a form of "duplication", and we know how rabid the content publishers are about that bs.
SMac770 is offline
post #17 of 56 Old 07-12-2007, 12:13 PM - Thread Starter
chuckvb's Avatar
I'm only seeking the ability to send one of many sources to either of two displays. I do not require the ability to feed one source to one HDMI output and another to the second HDMI output. I think that would require two video processors and would greatly increase cost for a seldom used feature. If that's needed I would rather have dedicated receivers for each display. In my theater I have two displays (Projector and Tv) and I'm only using one or the other.
chuckvb is offline
post #18 of 56 Old 07-12-2007, 02:27 PM
htpartyshack's Avatar
I asked this exact question of Marantz, and their tech rep said only one can be active at a time. As it was due to "copyright protection" I would suspect that the same restriction would apply to the other manufacturers as well.
htpartyshack is offline
post #19 of 56 Old 07-12-2007, 05:45 PM - Thread Starter
chuckvb's Avatar
Since Gefen sells devices that duplicate the signal to multiple displays I don't think that's a copy write issue or they couldn't sell such devices. As far as I know HDCP it has little to do with how many displays so long as they are all HDCP compliant so the video is not stored and passed around.
chuckvb is offline
post #20 of 56 Old 07-12-2007, 05:57 PM
RoboRay's Avatar
Your Marantz guy is feeding you a line of BS. There is no "copyright" restriction on splitting an HDMI output. Your HDCP source could care less how many devices or splitters are downstream from it, so long as all of them support HDCP. I use the Gefen splitter in my system to drive multiple displays and have no HDCP problems.
RoboRay is offline
post #21 of 56 Old 07-13-2007, 04:48 AM
SMac770's Avatar
Now there's some HDMI 1.3a? What a mess.
Marantz SR8001 is only HDMI 1.2 input and HDMI 1.1 output. And regardless of why, there is a menu setting where you pick which HDMI output to send the main zone video output to, so both are never simultaneously active
I don't know how useful a list of vaporware is. So is the SR8001 the only dual-connector (I'll call it that rather than dual-output since dual output it clearly is not) HDMI receiver out there in reality world?
SMac770 is offline
post #22 of 56 Old 07-13-2007, 05:13 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I'd go with the Onkyo at this point...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #23 of 56 Old 07-13-2007, 08:57 AM
steady teddy's Avatar
Quoted: 97 Post(s)
Liked: 49
How bout the Integra 8.8?
Mains: Revel Salon2's powered by ATI AT6002
Center: Revel C208
Surrounds: Revel F208
SW: SVS PB 13 Ultra
Amp: Emotiva XPR5 (surrounds & center)
steady teddy is offline
post #24 of 56 Old 07-13-2007, 12:31 PM
SMac770's Avatar
The 8.8 and the NR905 are the same thing effectively. Well, will be the same thing, when they exist.
SMac770 is offline
post #25 of 56 Old 07-15-2007, 04:13 PM
superbnerb's Avatar
is this a complete list of recievers that have 1.3? there are only 3 on the market right now?
Does anyone know where to get a list of receivers with hdmi 1.3 that are selling right now?!?!
i need to purchase one soon and need to research asap.
superbnerb is offline
post #26 of 56 Old 07-15-2007, 07:41 PM
SMac770's Avatar
Read the title and opening post. It's about receivers with dual HDMI 1.3 outputs.
SMac770 is offline
post #27 of 56 Old 07-15-2007, 08:21 PM
superbnerb's Avatar
read this, i asked a question... anyways, is there a list or not?
post #28 of 56 Old 07-15-2007, 09:10 PM
RoboRay's Avatar
This is the list.
RoboRay is offline
post #29 of 56 Old 07-29-2007, 03:59 PM
Quoted: 97 Post(s)
Liked: 49
Newb question regarding the Yamaha Vx800 series with dual 1.3 outputs: Does "4 in, 2 out simultaneously" mean both HDMI outputs can be active at the same time?
If so, is the Yammy the only AVR that can do this?
Center: Revel C208
SW: SVS PB 13 Ultra
post #30 of 56 Old 07-29-2007, 04:16 PM - Thread Starter
chuckvb's Avatar
Yes, but it appears to be a mirror of one input.
chuckvb is offline
