Blinking Standby Light Pioneer VSX-D912 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-16-2007, 08:08 PM - Thread Starter
BigdogBTS's Avatar
Hey all,
I'm hoping that someone on here can help me out. I've got a Pioneer VSX-D912 that suffered through a brownout this afternoon. The unit shut down, and now all I've got is a blinking standby lights. I've been doing some poking around on the forums and came across the reset procedures for the Pioneer 1014. What I'm hoping is that someone out there knows how if there's a similar procedure to get my D912 back up and running, or if not, some other way to get the old girl back on her feet. I know the 912's quite a few years old, and I know that's it's probably time for a replacement, but for more reasons than I need to go into, I'm having to make due with it for the time being. I'd really appreciate any help that anyone has to offer.
Thanks in advance,
Brad
BigdogBTS is offline
post #2 of 12 Old 06-16-2007, 11:08 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Just try using the 1014 reset procedure, it might work and it very likely won't hurt anything even if it don't.
Johnla is offline
post #3 of 12 Old 06-17-2007, 06:34 AM - Thread Starter
BigdogBTS's Avatar
I've tried the 1014 reset procedure, but the D912 doesn't have a video 2 button, and combinations of all the input buttons with the enter button didn't accomplish anything.
post #4 of 12 Old 06-17-2007, 07:47 AM - Thread Starter
BigdogBTS's Avatar
I figured a little more info might help things along. About a year ago, this unit was serviced for the same issue. According to the notes included on the repair receipt, the tech said that he "reset the system processor" and then the unit came up just fine. Of course, he charged me $70 for the trouble. Don't know if that helps or not, just thought I'd add it in there.
post #5 of 12 Old 06-17-2007, 09:21 PM - Thread Starter
BigdogBTS's Avatar
The reset code for this specific model is ENTER + ADVANCED SURROUND for two seconds while the unit is plugged in. It came back up and works just fine. Hope this helps someone else that might need it.
post #6 of 12 Old 06-17-2007, 09:35 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Good work, you saved $70, unless of course you charged yourself for resetting it....
Johnla is offline
post #7 of 12 Old 06-24-2012, 09:15 AM
nmdrifter's Avatar
I experienced this same problem last night. After much tinkering and reading the manual and using their OFFICIAL "reset code" I was not successful. The manual indicates that if this fails you need to take it in to have it repaired. smile.gif
I had become resigned to exploring reviews for a new AV Receiver. This morning: I thought I would try AVSForum (always a great place for tips/tricks) as a final check and BigdogBTS had a different code suggestion. I just tried and my AV Receiver bounced right back. All is now right in my world.
A huge thanks to BigdobBTS and AVSForum
But . . . I am somewhat miffed that Pioneer would not provide the "real reset code". Wonder how many folks have taken in their Receiver to be "taken in" by Pioneer's hidden revenue generator.
nmdrifter is offline
post #8 of 12 Old 02-11-2013, 10:15 AM
nodiak's Avatar
Another big thanks to BigdogBTS for this thread!
Was also starting to search for a replacement, then googled and found this. Reset worked!
I am oldish and not very agile in this digital world so am especially relieved for simple solutions.
Don
nodiak is offline
post #9 of 12 Old 07-12-2014, 02:35 PM
Larek's Avatar
Yet Another big thanks to BigdogBTS for this thread!
Mine did this late last night, This thread fixed it in seconds.
Larek is offline
post #10 of 12 Old 07-12-2014, 02:49 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
That is a pretty low thing for him to do...
fatbottom is offline
post #11 of 12 Old 07-12-2014, 02:59 PM - Thread Starter
BigdogBTS's Avatar
I guess he considered it "troubleshooting". I'm just glad that this bit of info has helped so many people. I still use that same receiver, and haven't had any issues with it since that last reset. Keeping my fingers crossed...
post #12 of 12 Old 10-24-2015, 02:29 AM
Tdekany's Avatar
I have 2 of these receivers so it makes them 12 years old since I bought them. One just went out, I have the blinking light going on but your suggestion didn't work unfortunately. I realize this is an old old thread, but wanted to let future owners know in case they are having the same issue. Time to buy a new unit I guess.
Tdekany is offline
