*Official* Denon 5308 Thread - Page 166 - AVS Forum
post #4951 of 4970 Old 01-10-2014, 04:48 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 276 Post(s)
Liked: 1302
AFAIK, no new AVRs at CES, rather more likely to hear something later in the spring on the new models.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #4952 of 4970 Old 01-21-2014, 04:17 PM
notnyt's Avatar
Quoted: 65 Post(s)
Liked: 316
So is there really anything available at the moment that can remotely compete with the 5308? Not that I'm looking to upgrade, I'm just curious. Seems it was the last of the great flagships frown.gif
notnyt is online now
post #4953 of 4970 Old 01-21-2014, 04:19 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 276 Post(s)
Liked: 1302
Depends on whether its got the 3D/XT32 upgrade ... if not .. then yes ... if yes ... then no.
post #4954 of 4970 Old 01-21-2014, 07:35 PM
notnyt's Avatar
Quoted: 65 Post(s)
Liked: 316
post #4955 of 4970 Old 02-09-2014, 04:38 PM
ROSSO Z's Avatar
If they are not going to release a new high end receiver, why not release more of the upgrade kits? It does not make sense to me.
Are there kits available? I was told no months ago.
Cheers,
ROSSO Z is offline
post #4956 of 4970 Old 05-09-2014, 08:43 AM
vakil92's Avatar
Hello,
i need some help… i was living under a rock you can say …was un aware of the upgrade until i needed to
add an 80 inch 3d TV to my home theater…. found out that upgrade has been discontinued
do i have any recourse or place where i can buy after market parts to get my 5308cia upgraded
i love my Denon 5308… it is awesome and don't want to replace it … have listened to macintosh before
my devon in my humble opinion operates far better than the macintosh i used to own...
any help would be greatly appreciated for any work around solution etc etc. to get my audio unto speed if not
the HDMI...
vakil92 is offline
post #4957 of 4970 Old 05-09-2014, 09:23 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 276 Post(s)
Liked: 1302
No kit. No upgrade. However, all you need do is to simply purchase a dual HDMI 1.4 Blu Ray player so you can pass the 3D video to the TV and the HD audio to the 5308. smile.gif
post #4958 of 4970 Old 05-09-2014, 09:41 AM
Michaeldef's Avatar
I would never sell the 5308 either, get you an Oppo, and do the 7.1 ext ins and enjoy, Same dilema here, with my 5803, until I opted for the 4520, because of Audyssey XT32, everything thrown at it sounds incredible, I just cant get myself to sell the 5803 though, it will eventually power another theater room and considering mild electrostatics for the 5803 massive amps, when I wasted 800.00 on the thx upgrade for the old Denon, I never used it, just throw a towel over your speakers for thx effect, but if you can find an Xt32 upgrade for the 5308, it will be more than worth it . God please allow the new Denons to remember all settings for every input this time around, or at least a quick select for each input
Michaeldef is offline
post #4959 of 4970 Old 05-09-2014, 05:12 PM
vakil92's Avatar
Thanks guys ... I really appreciate all the help
I have Focal Electra Be 1038 as my fronts , monitor audio center , alpine ceiling speakers , monitor audio sub woofer and Bose 901 series 6 hanging from ceiling as the surround back speakers 7.1 set up ...was gonna get an 80 inch 3d tv this coming thanks giving to finally retire my more than 10 year old 60inch sony grand wega and move from 1080i 2d to the realm of 1080p 3d tv ... Searching for compatibility is how I discovered bout the upgrade last week ...
What do u guys think about the thought of using a pre amp and use the 5308 as a power amp any suggestions on
What would work best with my 5308...
That way I may be able to enjoy the benefits of new Audissey 32 sound upgrade as well ...
vakil92 is offline
post #4960 of 4970 Old 05-09-2014, 09:19 PM
vakil92's Avatar
My apologies ... I checked out the opo 3d blue ray player ... It has individual outputs for each of the speakers and impressive chip set ... It will solve my dilemma
vakil92 is offline
post #4961 of 4970 Old 05-09-2014, 11:12 PM
Johnla's Avatar
No, it won't work that way. If you were to use the 5308 only as a power amp, then you also would not be able to use any of it's Audyssey features, as those are in the pre-amp section of the 5308.
Johnla is offline
post #4962 of 4970 Old 05-10-2014, 02:41 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 276 Post(s)
Liked: 1302
Consider the Oppo 103D for only $100 more than the 103 as the 103D uses the Darby Vision technology as well as can be firmware upgraded to support 4k/60fps video while the 103 will be limited to 4k/30fps video.
post #4963 of 4970 Old 07-01-2014, 01:56 PM
blackssr's Avatar
Hello,
the HDMI...
Same exact issue here. Just purchased the Vizio 80" 3D TV and have no way to pass 3D video through the Denon. I have 6 Dune players in my house. 4 Bases 3.0 and 2 303Ds. Currently running optical out the 303D into the Denon for sound. I called Denon about the upgrade and was told no it is no longer available. The AVR 4520CI is a downgrade in my opinion :-(. I have been disc less in my house for 5 years now so the Oppo is not on the table. Zappiti and my 32 TB Video Server are too convenient.
I have tried several HDMI splitters and HMDI Detective with custon EDID to fool Denon but no luck. Once 3D signal hits Denon on any HDMI input nothing passes at all. I am corresponding with HD Fury in reference to their HD Fury 4 and custom EDID splitter for a solution. I was quoted $ 550.00 US and a guarantee that 3D will pass through to TV on output one and HD Audio on output two of the custom splitter with the HD Fury 4 on the Denon side of things.
blackssr is offline
post #4964 of 4970 Old 07-01-2014, 01:59 PM
blackssr's Avatar
The Oppo has 2 HDMI outputs. One for Video/Audio and the other for the HD Audio w/2D blank image for any non 3D AVR.
blackssr is offline
post #4965 of 4970 Old 07-05-2014, 03:19 PM
kdeemer's Avatar
No Sound from Zone 2
I'm trying to reconfigure my 5308 to use zone 2, which I haven't used before. I've attached a pair of speakers to Amp Assign-2, have set Amp Assign to Zone 2, turned on Zone 2, assigned Zone 2 to Source, and cranked up the volume. But I get no sound from the speakers. What am I missing?
kdeemer is offline
post #4966 of 4970 Old 07-05-2014, 04:20 PM
JChin's Avatar
Quoted: 30 Post(s)
Liked: 122
Hi kdeemer, are trying to pass a HDMI source to Zone 2? If so, not possible, its either optical or coax digital or an analog RCA cables.
JChin is offline
post #4967 of 4970 Old 07-05-2014, 11:31 PM
kdeemer's Avatar
Yes, that was it. Thanks!
kdeemer is offline
post #4968 of 4970 Old 07-06-2014, 10:50 AM
jappleboy's Avatar
4K
Hi all nice to see this thread is still a live. I have the last upgrade on my 5308ci the one with 3D. Do you ever see Denon doing a 4K upgrade is it even possible . Long live the tank 5308ci
jappleboy is offline
post #4969 of 4970 Old 07-06-2014, 11:23 PM
jevans64's Avatar
Liked: 52
Very unlikely since the unit would need a complete DSP overhaul.That would be way more expensive than just adding an Oppo 103D for $600 that would handle 4K.
HD-DVD = 94
Blu-Ray = 120 ( 24 Warner red2blu )
jevans64 is offline
post #4970 of 4970 Old 07-07-2014, 09:41 AM
jappleboy's Avatar
4K
So bypass the 5308ci and run your HDMI cable from your Oppo to your 4K TV.
Denon Avr 5308ci Receiver
