*Official* Denon 5308 Thread - Page 167 - AVS | Home Theater Discussions And Reviews
Old 08-23-2014, 09:41 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3706 Post(s)
Liked: 2179
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
Old 08-24-2014, 11:52 AM
jappleboy's Avatar
Quoted: 63 Post(s)
To the forum gods, I just sold my Denon 5308ci why i just got a Samsung 65inch 4K,3D tv so i needed the 3d, 4k pass though. So this is what i am up to i do see Denon and Marantz are coming out with new Dolby Atmas Receivers. With the new receivers will i need new speakers. I also see the i can now pick up Denon 4520, and a Marantz 7008 for the same price. I do have a wife she said NO NEW SPEAKERS. So a little help please.
jappleboy is offline
Old 08-24-2014, 11:59 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2179
Unless you currently have overhead ceiling speakers, ideally you either want to install 2 or 4 speakers, get Atmos top firing speakers or use add on Atmos modules placed on top of existing speakers or a flat surface nearby. If new speakers are not in your future, the 4520CI would be the better alternative as it is Denon's current flagship 32 bit model mfr'd in Japan, while the SR7008 is a China built 24 bit model.
Old 08-24-2014, 12:13 PM
jappleboy's Avatar
Quoted: 63 Post(s)
Thank you for the reply i have 7.1 setup my ceiling is about 7 feet . This is my setup 2 front Definitive tower speaker with 1 center, 2 side speakers 6 feet of the ground and on the wall and 2 back speakers 6 feet up on the wall and 1 sub, The center and front have subs built in.
Old 08-24-2014, 12:18 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2179
Okay. So you could add a pair of Def Tech Atmos A60 modules placed on top of your FL/FR speakers for a 7.1.2 setup; however, if not wanting to add more speakers, the 4520CI is likely your best option.
Old 08-25-2014, 10:44 AM
turnne1's Avatar
Quoted: 1014 Post(s)
Liked: 230
has there ever been any documented information that the Chinese made models( of any brand) were inferior to the ones built in Japan?
or is it a placebo....
Clearly...I know the reason for the move
But just wondered if anyone has any verifiable information on the differences..if any
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 LG 47LE8500 Denon 4520 Celestion 305 speaker system
Rm 3 Samsung 51E8000 Pioneer SC37 Kef 2005.2 speaker system
Rm 4 Panasonic 50ST50 Pioneer SC77 Mirage Omni sat speaker system
turnne1 is online now
Old 08-25-2014, 10:45 AM
turnne1's Avatar
Liked: 230
added to that the falling prices of the unit....that IMO...will continue to do so
Warren
Old 08-27-2014, 05:12 AM
LaserKen's Avatar
Anyone have an issue with the HDMI port going bad? I believe mine has.
LaserKen is offline
Old 10-11-2014, 01:39 AM
vakil92's Avatar
I looked at the current line up of denon ..... I think the 5308 still has the edge on amp quality output ... Gonna use my 5308 as a power amp paired through individual speaker inputs with a decent pre amp that has xt32 audyssey sound processing and thereby use the 3d / 4k output as well on that pre amp ... IAM kind of surprised that pre amps with hdmi2.0 and 3d are priced higher than an avr with hdmi 2.0 and 3d ....
vakil92 is offline
Old 10-11-2014, 04:01 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2179
The $1000 5308 3D/XT32 upgrade kits have been sold out for awhile, but you may get lucky if you call around various authorized repair facilities and find one if you are interested in going that route.
Old 10-11-2014, 09:56 AM
notnyt's Avatar
Quoted: 781 Post(s)
Liked: 814
Any idea if the upgrade includes subeq? I'm just curious, I have the upgrade already.
notnyt is offline
Old 10-11-2014, 01:37 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2179
No, it does not as the 5308CI uses a much more advanced sub configuration setup than the lower models.
Old 10-14-2014, 04:15 AM
vakil92's Avatar
Thanks for the reply jd ... Unfortunately I did call all of Denon Superservice centers a few months back and they had no spare kits ... The kits were ordered on case by case basis when they were available and as far as the main stock of the kits at denon ...Denon folks told me that they put the remaining kits on stock 5308 that were remaining and sent them to accessories for less outlet and there were no more kits being manufactured ... So in essence there are no more kits out there Iam outta luck ... But I can still use my 5308 as a power amp ...
vakil92 is offline
Old 10-22-2014, 02:48 AM
vakil92's Avatar
Well I finally bit the upgrade bullet for my system ... Got a lg 84ub9800.... Can only use one of the hdmi inputs on TV for either my 3d blu ray or 5308 ... UGHHHHHH!!! .... Other TV inputs keep telling me hdmi is not compatible ... So I searched for a solution and recently saw denon X4000 on clearance pricing ... Went ahead and bought one ...will be delivered this Friday /Thursday ..hoping to use my 5308 as power amp to the new x4000.... I noticed none of the denon amps are hdcp 2.2 compliant so pretty much I figured that there is not much difference in x4000w and x4000 except for atmos but as x4000w wont be able to play the 4k blu Ray coming out in 2015 the atmos is not that important ... Plus everybody is gonna be in the same boat dealing with obsolete amps yet again by next year thanksgiving ... The benefits of the set up will hopefully allow me to enjoy xt32 room correction using the x4000 and the superior sound of avr5308 amp section via individual inputs and finally use the 4k inputs on the tv for hdmi and plug all my devices into the x4000 and not having to plug the 3d blu Ray into TV and disconnect my amp and vice versa .... Also using the iTunes app to control amp will simplify the control of the amp... And I figure using this set up I should be good for next few years ... As the new 4k blu Ray player comes out next year the lg TV is already hdcp 2.2 compliant ... And the audio return hdmi plug on my lg TV would return the audio to x4000 to process the sound or I can buy a dual hdmi output 4k blu Ray player when they come out next year ... Love the sound of my 5308 and hope to keep the beast around for many many years to come .... I hope to get around the audio lag issue by using the x4000 as a processor and the hub of all connections so hopefully won't run into much of an issue there ...
Long live the 5308 ... Even if the hdmi is outdated on it ... It's still one of the best amps out there
vakil92 is offline
Old 12-21-2014, 08:42 PM
krichter1's Avatar
Liked: 80
I know this is probably just wishful (naive?), thinking but would there be any way Denon might consider doing another upgrade to support the Atmos codecs? Just curious if there might be any insight here as the minutia of Atmos is all still pretty new to me.
Kevin
You only live once, but if you live it right, once is enough.
==> The Richter Family 3D Theater
krichter1 is offline
Old 12-22-2014, 02:19 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2179
AFAIK, not going to happen. Only the new 2014 and newer models will be Atmos capable.
krichter1 likes this.
Old 12-22-2014, 07:06 AM
mtbdudex's Avatar
Quoted: 77 Post(s)
Liked: 423
Hello prior Denon 5308 flagship owners and users - do you have thoughts/comments to add to the below thread?
"The official Denon 2016/2017 flagship AVR (x9200w?) wishlist"
From post # 36 Dec-17-2014:
I've been thinking how to move this discussion forward, so this weekend started to consider the back panel layout and the interior hardware layout as 2 key drivers.
This article gives one of the best re-caps and comparisions I've seen on the X7200W to what some consider the last flagship, the 5308CI (I'd have used the 4520CI but I'm prejudiced as owner of that)
http://www.audiogurus.com/learn/elec...-receiver/2977
Using back panel of x7200W as baseline:
>>Keeping audio and video board basic layouts as is
>>Should help with thermal management and EMI management issues
Here is mark-up of "keeps" and "deletions".
I realize this is debatable, but I truly see in 2016/2017 that a flagship has little need for true "legacy connectors" besides the bare minimum I've kept below.
Giving this result.
Since we are 2 years out, and the layout restrictions to keep the architecture of the x7200W, this seems "doable".....
Thoughts, comments, feedback?
mtbdudex is offline
Old 12-22-2014, 10:02 AM
Nobody Special Member
BamaDave's Avatar
Quoted: 72 Post(s)
Liked: 44
I’m like 99.99999% sure that will not happen!
BamaDave is offline
Old 12-22-2014, 01:45 PM
krichter1's Avatar
Liked: 80
Kevin
Old 12-22-2014, 03:29 PM
Liked: 0
Problem updating AVR-5308CI (Hung at DSP1 updating)
AVR-5308CI receiver has been offline for a couple years. Just did the firmware update and its hanging with message "DSP1 Firm 24 Minutes Updating". I have done both the up down arrow reset and the standard and TX button reset. Neither made a difference. Using Wired Ethernet directly connect to my modem, also tried another internet source. Have left it sitting over night with no luck. Have canceled the update using the reset procedure and started from scratch but keep getting stuck at the same place.
Receiver still seems to be working ok
Versions on my receiver:
Main Ver A1.91
Main Sub 01.18
Main Rom A1.191
PLD00.25
DSP1 36.60
DSP2 37.17
DSP3 38.13
GUI FPGA A080719A
PRG 00007621
DA 10003022
Real TA 08030a
HDMI A PLD 00.20
Digital FPGA 0.16
Video PLD 00.10
Any ideas on how to get the update to complete or if its actually going to make any difference from the Firmware version I am currently on? Unless I come up with anything else I assume my only option is to take it into a service center.
Thank you,
Jeff
jcolter is offline
Old 02-08-2015, 10:29 AM
drmanny3's Avatar
New Firmware update for 5308CI
I heard about an firmware update on the Denon AVP-A1HDCI forum. Some indicated that it only shows up if you have the upgraded units. I just tried and it has begun the download. I understand that it is associated with fixing the timing behaviour of DTS-HD Master Audio decoding. Someone replied after the update that they were unable to hear any difference. From my view point I will do it anyway to keep my unit functional. I recently added a seven channel amp Sunfire 7401 at 400 Watts per channel to my system. I am pretty happy with the Denon and see no reason to change out. Perhaps when I purchase a 4K TV, I will consider. However, there maybe a work around for the limited 4K content. Perhaps there is something out there now or in the near future like Opto that would allow the 4K to be sent directly to the TV while also sending the audio to the Denon.
Manny
drmanny3 is offline
Old 04-12-2015, 07:01 AM
MoFoHo's Avatar
Hi there. I wonder if there's still some owners of this wonderful amp around? I have a question and I hope someone may be able to answer. It also concerns my Denon DBP-4010 Blu-ray player, so please bear with me.
I don't have many older BDs with a 5.1 LPCM soundtrack, but a few older ones nonetheless. I'm wondering if my BD player has a bug that also plagued another Denon BD player, the 2500BT. Namely, that the .1 channel is 10dB too low when sending out LPCM only. (bitstreaming the lossless codecs isn't affected). I've looked and looked and can't seem to find any solution on the BD player side. So I was wondering if a 10dB boost is possible for a particular input when recieving LPCM? I know the analog inputs have this ability but I need to boost the HDMI input.
Is this possible? Anyone?
MoFoHo is offline
Denon Avr 5308ci Receiver
