*Official* Denon 5308 Thread - Page 168 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5011 of 5021 Old 06-28-2015, 10:13 AM
SMO5007's Avatar
Quoted: 13 Post(s)
and for the life of me cant get the unit to reset to factory defaults by using the power, standard, tx button reset...Just doesn't do it..
Im ready to throw this unit out in the trash and hook my 4308 back up...
SMO5007 is offline
post #5012 of 5021 Old 06-28-2015, 10:17 AM
SMO5007's Avatar
Quoted: 13 Post(s)
plus cant reset the microprocessor using the standard method of power, standard, and tx buttons, just wont do it...
SMO5007 is offline
post #5013 of 5021 Old 06-28-2015, 11:44 AM
SMO5007's Avatar
Quoted: 13 Post(s)
figured out the hard reset, its actually the push button on/off little button, not the larger one...
now since I did this...I will see if this has help with any of the issues I am having.
SMO5007 is offline
post #5014 of 5021 Old 06-29-2015, 08:03 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 9355 Post(s)
Liked: 4316
Try doing a "network reset" by pressing/holding the UP/DOWN arrow buttons on the front panel while powering on the AVR.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #5015 of 5021 Old 06-29-2015, 02:07 PM
SMO5007's Avatar
Quoted: 13 Post(s)
Hi Jd
did both the resets. Unit seems to be better...
will know when I get home from work.
Still have the noise in the L SW channel when approaching -10bd, can only hear it when nothing is playing.
Also, seems to be some high pitched noise (like a fan) running and can hear it when the room is quite. As I turn the volume up past -10bd can hear it.
is there an internal fan that runs to keep the 5308 cool? Bec I can hear something running inside. What do you think?
Another thing, I definitely will not update the firmware. What does this update correct, if you know?
thanks for getting back to me.
The audio is really spectacular with the 5308, I am really happy I upgraded from the 4308, which was a fine machine also.
Recenly moved, sold all my power amps, honestly can not really hear a difference.
The 5308 is in another league...
SMO5007 is offline
post #5016 of 5021 Old 11-15-2015, 02:44 PM
Liked: 0
Hi all
I am trying to update my Denon AVR-5308CI using the network ethernet connection and I am not having any luck. It keeps hanging on 39 mins. Apparently it's a router issue on my end but I've turned off uPNP, set up a DMZ, and static IP for the Receiver. Still no luck. I am about to give up but does anyone know of a method to side load it somehow? Apparently i have A1.91 and there isn't a record of that version anywhere I could find, but the receiver does say there is a version to update. If not has anyone figured out how to get it to stop it from trying keep on updating automatically. I have to unplug the ethernet to stop it from shutting off and restarting attempting to connect to the Denon server. Grrr. Resetting the CPU doesn't do anything beyond wipe out all my settings.
Thanks!!
walterswan is offline
post #5017 of 5021 Old 11-15-2015, 04:55 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4316
Originally Posted by walterswan View Post
Hi all
Thanks!!
Try doing a "network reset" by pressing/holding the UP/DOWN arrow buttons on the front panel while powering on the AVR (similar to microprocessor reset procedure).
post #5018 of 5021 Old 11-16-2015, 07:35 PM
Liked: 0
That worked perfectly!! thank you!!
post #5019 of 5021 Old 11-24-2015, 07:11 PM
bobbyhollywood's Avatar
Originally Posted by Swatdude1 View Post
Quote:Originally Posted by jdsmoothie
No.. This setting would only be used if you were using the 7.1 multi analog inputs and more specifically for the .1 input. Although it shouldn't make a difference, try setting the sub to LFE+MAIN. Does the music you're listening to have lower bass frequencies?
Yes. The annoying thing is that when I set it to any of the surround modes while listening to the DAC-1, the DD-15 immediately fires up and starts pumping out bass. Switch it back to Direct and nothing comes out of the sub. I really prefer to listen to 2-channel 96khz 24 bit music in 2-channel.
When I get home from work today I am going to try a soft reset and see if that does anything.
Did anyone come up with a solution for this ? I'm having the same issue and a search reveals the exact same problem but no real answer I can see.
bobbyhollywood is offline
post #5020 of 5021 Old 11-25-2015, 01:16 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4316
Did you change the mode to "LFE+Main" as I suggested to the OP?
post #5021 of 5021 Old 11-25-2015, 04:43 AM
Yes, I've tried both settings.
Denon Avr 5308ci Receiver
