Any other Dish/Echostar codes for Harman Kardon remote? - AVS Forum | Home Theater Discussions And Reviews
Old 06-23-2007, 11:33 PM - Thread Starter
sremick's Avatar
I have a Harman Kardon AVR-146 receiver and a Dish Network (Echostar) model 311 satellite receiver. None of the Echostar codes in the HK manual work to program the HK remote to operate this extremely-common Dish receiver, which is surprising. I've also had no luck stepping through all the codes using the technique mentioned in the manual (although I might be doing it wrong).
Since this Dish receiver is so common, I'm hoping someone else with an HK receiver has found other codes for Dish Network/Echostar receivers...? Maybe?
"Your" isn't the same as "you're". "There", "their" and "they're" are also not the same. Please learn the difference.
And... it's "couldn't care less". Thank you. :)
sremick is offline
