Harman Kardon AVR 247 & 347 discussion thread. - Page 176 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5251 of 5273 Old 10-08-2013, 06:06 AM
Bobx101's Avatar
Originally Posted by bobbobster View Post
Hello Bobx101
Receiver uses spdif, I think you should give it a go with the optical, can't damage anything. Just the signal wouldn't lock.
Regards
SPDIF - that's what I needed to know. Thanks a bunch. Now I just need an RCA-to-optical adapter......this is going to be uber cool....digital out from my source, through the HK's DACs...nice.
Thanks again.
Bobx101 is offline
post #5252 of 5273 Old 10-20-2013, 07:20 PM
TheAngryPenguin's Avatar
Proud new owner of a 247. Got it from CL for $60. The previous owner stated that it started going into PROTECT mode whenever he stressed the amp. I immediately performed a factory reset when I got it home, and it has yet to go back into PROTECT mode. The sound is so much warmer than my Yamaha HTR-5640, and I really needed HDMI switching (ordered a 3-way pigtail from Monoprice). So, my questions are:
EzSet/EQ
The first 3 or 4 times I attempted it, the mic was placed in my preferred listening position. The first bursts of pink noise were slow, and it errored out stating that there was a problem with my speaker(s). Thinking I may have reversed the wiring, I switched the front-left speaker's polarity and ran it again. Still got an error. Just for ****s and giggles, I positioned the mic about 6' in front of my listening position and the first bursts of pink noise were much quicker than previous attempts. The process completed, but I ran it again, moving the mic back to my listening position after the first few quicker bursts completed. Is this to be expected?
EzSet/EQ - Subwoofer Configuration
Where should I set the subwoofer's level, crossover, and polarity so that I can get the best results?
TheAngryPenguin is offline
post #5253 of 5273 Old 10-27-2013, 10:53 PM
CasetheCVetteman's Avatar
I bought my H/K AVR347 many years ago, a few months prior to the 355 replacing it.
I have never ever had one single issue with it, it still works perfectly, and for many years served as the primary AVR in my home, recently has been swapped to the bedroom setup now where the AVR360 used to reside.
The sound on the 360 is basically identical from all I can tell, the reason I ended up swapping over was the extra couple HDMI inputs, the 347 only has 2.
Great to see so many others happy with these AVRs, ive never looked back since switching cool.gif
CasetheCVetteman is offline
post #5254 of 5273 Old 11-27-2013, 01:40 AM
francismanapat's Avatar
Good day. i hope you guys can assist me on my issue. i have an avr247 receiver connected to an LG smart tv via optical cable. i use the tv as the mp3 player and the avr247 as my sound output. i like using "logic 7 music" as my default surround when playing mp3s. my problem is, everytime the next track plays, it goes back to "surround off - stereo". i dont prefer this mode. i prefer "logic 7 music". auto polling is set to "off" already. default surround mode is already set to "off". my firmware is 2.4.22.1. date is 02-02-2008 02. thanks in advance.
francismanapat is offline
post #5255 of 5273 Old 12-08-2013, 10:11 PM
Set the default sound mode to Logic 7, youd be better off with a better MP3 player though, the reason for it is too long between tracks, the AVR will default back to the signal its getting and play in stereo.
post #5256 of 5273 Old 01-07-2014, 11:23 AM
ronnbot's Avatar
Originally Posted by nabril View Post
1) I still own a set of Bose Acoustimass speakers (5 cubes and the bass module), and I'm not in the position to replace them yet. I know they are overrated and a pain, but they sound ok. After a recent move, I re-installed everything, and I would like to know if anyone else has Bose speakers connected to the 347, and what settings you chose for the speaker setup. We all know that the bass module processes and equalizes the sound, so I'm sure the AVR's EZSetup gets "fooled" by the equalized sound (or maybe not). I've read other threads linking the 2 (347 and Bose), and most start by saying to replace the Bose speakers and to get real speakers. As I said, I cant do that at this time, and I''d like to enjoy them a bit longer. Any suggestions will be appreciated.
Since all 5 channels go through the bass module and out to the satellites, I'd set the fronts, centre and surrounds as large and sub as none. Because it is essentially 5.0 setup, you can't use the EZSetup and need to manually configure the rest of the settings. Since there is no sub (as the receiver sees it), the LFE (.1 channel) will be diverted to the front speakers where their lower frequency is generated from the bass module, so you don't loose any LFE. Therefore, you shouldn't need an additional sub unless you want way more bass.
I know it's a late reply, but it may help others.
ronnbot is offline
post #5257 of 5273 Old 02-27-2014, 03:32 AM
jang1a's Avatar
I sure hope someone is still monitoring this thread. I had this recent urge to control my Harman Kardon 247 via Eventghost, via rs232. This way, I can have my pc orchestrate proper timing in turning on my TV, AVR 247, before starting XBMC. I was told having the 247 connected to the PC via serial is the best way to go.
Is anyone doing this? Where are the serial codes for avr247? It will be great if someone here has actually gotten AVR247 to work with Eventghost. I have a lot of questions that I could use some help.
jang1a is offline
post #5258 of 5273 Old 02-27-2014, 09:21 AM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
Not possible..
Since the 247 is now > 7 years old, HK did not provide any control codes in their lower range AVRs..
The RS232 port was for firmware upgrading...
Just my $0.05.. 👍😉
M Code is offline
post #5259 of 5273 Old 02-28-2014, 02:06 AM
jang1a's Avatar
I hope you're wrong biggrin.gif Just kidding. I was hoping there would be codes. That may be the reason why I was sending it codes for other Harman equipment, but it's not responding.
jang1a is offline
post #5260 of 5273 Old 07-05-2014, 06:36 AM
Liked: 0
Hello, sorry for the gravedig.
I have a 247 with the "traditional" 1080p sparkle issue.
I know i'm completely out of warranty after 7 years , so i need the original PDF repair file that once was linked here: Harman Kardon AVR 247 & 347 discussion thread.
Looks like it's o more not available on HK network, so does anyone have a backup copy?
dinofly is offline
post #5261 of 5273 Old 11-09-2014, 10:24 AM
Liked: 0
Please Help
Originally Posted by Sam1000 View Post
Hi:
I have waited for months for this firmware, but I'm having some issues getting the firmware upgraded. I have already used 2 different laptops with 2 different rs-232 cables.
Every time I try the upgrade, I get the following message after hitting the "upgrade" button
"Please enter a valid Flash Image File".
Has anyone else noticed this?
The funny thing is, when I try to go back to previous steps where you select the directory with upgrade files, the s24 and hex filenames are blanked out, although it does have the correct folder name in there(c:\\Harmankardon\\AVRx47).
I have win2000 installed on both PCs. I know that the communication is happening between the receiver and the PC because, when I pushed the Tone button on my avr to reset the receiver, I got some data back in the hyperterminal window. (I know this reset is different that rs-232 reset, which is part of the upgrade process).
Any help would be appreciated.
Thanks..
Hi Sam1010 !
I have HK AVR 347 and need help. By updating i have got same problem "Please enter a valid Flash Image File". Can you help me?
Thank you!
samiaksoy is offline
post #5262 of 5273 Old 11-22-2014, 07:32 AM
baily's Avatar
Not possible..
Just my $0.05.. 👍😉
Sorry for ressurecting an old thread for an old receiver. I have an AVR 347 and just wanted to confirm the situation is the same as the 247 regarding remote codes. I finally upgraded to a Samsung TV that is 3D capable and smart, so while I don't watch 3D, I want to make sure the AVR has no issues with passthrough, since it is pre-3D. I routed my blu-ray player straight to the TV via HDMI and use optical out to send audio from TV back to the receiver, but the TV's smart remotes can't seem to control the AVR 347 at all, no matter what model number I enter.
I'm going to assume this is an exercise in futility and is not possible, but wanted to make sure before I gave up.
baily is offline
post #5263 of 5273 Old 12-31-2014, 08:42 PM
mrbizi's Avatar
Playing DTS-HD and Dolby True Hd
I'm thinking of buying a used 247 as a temporary solution until I save up for a high end unit.
My question is can I play dts-hd and Dolby true hd using this unit by doing the following:
1. Connect Samsung bluray player (with dts-hd and Dolby true hd capability and 6.1 analog output) to the 247 's 6.1 analog input.
2. Connect bluray players HDMI output to 247 hdmi input. Or should I just connect the bluray player directly to my display (Benq projector)? What would give me a better picture quality?
Thanks in advance.
mrbizi is offline
post #5264 of 5273 Old 01-04-2015, 10:29 AM
Liked: 0
Is there an adaptor that will connect a Bridgelll to a AVR 347. Called HK support and was told they no longer support either product and referred me to the Apple store
geraft is offline
post #5265 of 5273 Old 01-19-2015, 12:41 PM
canosomx's Avatar
Thanks in advance.
Hi, you can conect your bluray player to HDMI input in AVR247, the the DTS-HD and DOLBY TRUE HD signals will be reproduced as DTS and DD or you can set the output in your bluray player as PCM instead of bitstream. AVR247 passes through 1080p, so picture will be the same as directly conected to display.
canosomx is offline
post #5266 of 5273 Old 08-28-2015, 03:59 PM
afterlife2's Avatar
Quoted: 162 Post(s)
Liked: 78
Bump. Have a 247 and it's not detecting DD with the Roku XS(Says Stereo only in setup, HMDI Auto detect), but my Sony Bluray Netflix is DD. Anyway to fix this? HDMI cord is the newer High Speed.
afterlife2 is offline
post #5267 of 5273 Old 09-19-2015, 07:37 PM
burdell1's Avatar
After the firmware update, will the AVR 247 be ARC compatible? I assume not, but figured i'd ask anyway.
burdell1 is offline
post #5268 of 5273 Old 09-19-2015, 07:48 PM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
No...
Just my $0.02...
M Code is offline
post #5269 of 5273 Old 03-17-2016, 02:42 PM
Liked: 0
I don't know if anyone still uses these things or not, but I recently started using mine with a new TV I got and it allows TV to phone mirroring. So in order to do that, I need to have the audio from the receiver go to the TV. Otherwise I get no audio on my phone.
I have the TV connected to the receiver via HDMI but it seems only the video signal is transferred to the TV. There's no audio. I can't seem to find any setting to turn on audio out.
The manual isn't really helpful either. It doesn't specifically say audio doesn't go through the HDMI out (at least I don't think it does) but I imagine that might be the issue. But some parts of the manual seem to make it seem like it does. There's a part that mentions that if you connect the receiver to your TV using the HDMI port that you "may need to read your owner's manual or contact the manufacturer for instructions on how to turn off the volume or disable the device's speakers". Sooo that makes me think you can get audio out over the HDMI lol.
I really just want an answer and if anyone knows I'd be grateful.
mmmfloorpie is offline
post #5270 of 5273 Old 03-20-2016, 03:55 PM
allargon's Avatar
Quoted: 51 Post(s)
Liked: 44
It won't work with this receiver or most receivers. Most A/V receivers are specifically designed to strip the audio before sending a video signal on to the TV. The only way I can think to do this is to send your center channel audio from the pre-out on the receiver to the TV if your TV has stereo inputs. Please note you will lose your actual center channel speaker and use your TV as the center channel. (Don't laugh. A LOT of people have similar setups.)
allargon is offline
post #5271 of 5273 Old 04-13-2016, 06:28 PM
powrslave's Avatar
Hi My 247 all of a sudden has started producing a very slight white noise almost a hiss.
I'm using 2.4.9.1 firmware/
Nothing at all has changed with my setup and the only thing I really am using is optical in from a computer.
With the optical unplugged there is no difference.
I've done a reset already.
The only ideas I have could be bad caps or something else going wrong inside or possible some sort of "line noise" or dirty electric?
I've already gone through different settings and am using this avr at a very basic 2 speaker mode.
powrslave is offline
post #5272 of 5273 Old 11-24-2016, 09:34 AM
jabu32's Avatar
Quoted: 157 Post(s)
Liked: 34
Anyone know how to fix a avr-347 with no hdmi output?
Sent from my SM-N920V using Tapatalk
Denon x3300w
Klipsch RF-82II - Main
Pioneer SP-T22A-LR - Atmos Fronts
Klipsch RC-62II - Center
Klipsch RB-61II - Surround
Klipsch R-12sw - Subwoofer
jabu32 is offline
post #5273 of 5273 Old 12-23-2016, 09:47 PM
jabu32's Avatar
Quoted: 157 Post(s)
Liked: 34
Anyone?
Denon x3300w
jabu32 is offline
