Denon Audyssey: Disappointing? Read on... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 47 Old 07-12-2007, 07:44 AM
Kal Rubinson's Avatar
Quoted: 802 Post(s)
Liked: 567
Originally Posted by J.Mike Ferrara View Post
The room is 17' by 11' - the pictures seem to make is much longer than it is. I did pull the speakers out a bit, as well as the seating area. Plus, I raised the center speaker, and then removed the coffe table when I re-did the auto-calibration.
Good. That reflective table is a biggie.
Questions: if I change the center speaker size to Small (Audyssey always makes it Large) and adjust the SW cutoffs, does that affect the EQ? The one thing that Audyssey does in spades is improve the sound stage.
But it is small. You do not have to take all of Audyssey's recommendations. I suggest you try it.
When I ran MultEQxt, it said all my speakers were large but I know my rear speakers better. Interestingly, the SEQ/Pro did say that the rears were small.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #32 of 47 Old 07-12-2007, 08:24 AM - Thread Starter
J.Mike Ferrara's Avatar
Quoted: 153 Post(s)
Liked: 179
I see that I can change the speaker size, but the Audyssey light changes from green to red. Can I also change the cutoff point without affecting the EQ? I believe that if I change the speaker size, there is no automatic change to the cutoff point. To me, this is not logical.
The Yammay allowed me to set the center channel as small, and set a cutoff point to send lows to my L/R speakers. I don't see that option with Denon.
Jeepers, I wish I could get my hands on some detailed documentation on Denon's implementation of Audyssey.
J.Mike
Those who die with the most toys ... are still dead!
J.Mike Ferrara is offline
post #33 of 47 Old 07-12-2007, 08:27 AM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
J. Mike, that room does really limit what you can achieve. You didn't answer what kind of speakers those are so I'll just assume they are capable of playing full range at least down to 25hz their corner placement will emphasize the bass. Here's what I'd try if I were you this will be worth the effort;
-Move your equipment rack to the front under the screen either side of the center if need be.
-Move your main speakers out from the wall, a couple of feet at least, and get your right and left as far away from the side wall as far you can without impeding your vision.
-Pull your couch out two or three ft from the back wall and place your sub behind it center of the wall (to start anyways, you might want to corner load it depending if that's an opening I see on the right.)
Then do some temporary acoustic treatments to give you an idea of what can be accomplished, once you see what you can accomplish you can use proper stuff to match your decor;
-Sit in the middle of you couch and have someone slide a mirror along the side wall starting near your front speakers and moving towards you and as soon as you can see the tweeter in the mirror mark that spot on the wall and place something there on both sides, a pillow or a small rug - these are the first reflection points.
-Temporarily place pillows in the four upper corners of your room so there's air space behind them and in the back wall corners if you have enough. These will be mock bass traps to give you an idea of what they can do.
- Cover the glass table with anything like a thick table cloth but leave the table there - you normally would, and if you take it away when measuring what the Audyssey does will be wasted because there's going to be a bunch of stuff bouncing off that glass surface. (That's likely why your center channel doesn't sound right.)
- Lean or put something between your back two speakers at ear height that has a completely irregular surface, a loaded bookcase or something - this will act as diffusion.
- Set your mains to Front+LFE - do cross over your center to at least 80hz, set your subs' level to where it sounds properly integrated with the rest of your system.
- Now run the Audyssey - and make sure you do it with the projector off.
This is a starting point as far as the Sub and center channel/ mains crossover are concerned. Try it with your mains just set to large w/no LFE, you can also move your sub around, the goal is to get a smooth bass response without being able to localize the sub.
I'm guessing a center back position for the sub because of the size of your fronts and their corner placement reinforcing the bass coming from the front.
Current Gear: Anthem AVM60, D-Sonic 3500/7, Oppo UDP-203, PS Audio Nuwave Phono Pre, Technics SL1210 w/ Denon DL103, Dune Duo 4K, LG Oled55e6, Paradigm Sig. S6 & C3 v.3's, Monitor ADP's, Velodyne SPLR1200.
rnrgagne is offline
post #34 of 47 Old 07-12-2007, 10:17 PM
soundlovr's Avatar
You should set all of your speakers to small (see here) and you can adjust the crossovers to whatever you like for each individual speaker (starting off with 80Hz which is the generally accepted standard). Speaker setups and Audyssey really aren't the same thing, they're just very aware of each other - Audyssey keeps on working no matter the changes in the speaker setup. The only change will be the colour of the light.
soundlovr is offline
post #35 of 47 Old 07-13-2007, 04:18 AM - Thread Starter
Quoted: 153 Post(s)
Liked: 179
Hey guys - thanks for the terrific tips.
The sound is getting better with each tweak I apply.
J.Mike
post #36 of 47 Old 07-14-2007, 12:15 PM - Thread Starter
Quoted: 153 Post(s)
Liked: 179
UPDATE
Here is a link to the FAQ section of the Audyssey website:
Audyssey FAQ
This Q/A is of particular interest:
What happens to the MultEQ settings when the parameters are changed? MultEQ corrects for room acoustical problems. Changes in the tone controls do not change the filter performance. They do change the tonal balance based on the preferences of the customer. The benefit of MultEQ is that it allows a customer (or installer) tone control setting to work on all program material in a much more predictable way than it would on an uncalibrated system. Changes made to the crossover frequency or small and large settings of the loudspeakers will affect the performance of the MultEQ filters and Audyssey does not recommend changing them.
I've been playing around with the speaker settings because after a dozen calibration routines, Audyssey still sees my center speaker as Large, which it is certainly not. It's interesting: when I change the center speaker to Small, the cutoff frequency is automatically set to 40Hz. That's OK, and if I make just that one change, I still have the impressive sound-stage that Audyssey produces. It seems that any other changes to speaker level or changing the cutoff to 80Hz will negatively impact the sound-stage. Therefore, there seems to be very little flexibility in tweaking an Audyssey calibration.
J.Mike
post #37 of 47 Old 07-14-2007, 12:31 PM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
UPDATE
Audyssey FAQ
Can you not set the crossover before you run the Audyssey?
Regardless, the Audyssey won't come close to doing for you what Kal and I suggested. I repeat, it will be worth the effort.
rnrgagne is offline
post #38 of 47 Old 07-14-2007, 12:35 PM
catapult's Avatar
Mike, I think that's an old FAQ and Chris has revised his advice on this forum as time went on if you do a search. The small/large and XO frequency settings are just 'recommendations' made by Audyssey based on Denon's insistence that anything that can play below 80 Hz is 'large.' The actual settings are done in Denon firmware, not Audyssey firmware, so there is no harm in changing them to what they should be, i.e. where they sound best.
Dennis H
catapult is offline
post #39 of 47 Old 07-14-2007, 01:08 PM - Thread Starter
Quoted: 153 Post(s)
Liked: 179
Frankly, I'd like to rename this thread to:
Based on the terrific feedback I'm getting (rnrgagne: yes your advice helps so much), the sound is really improved to a point that I can say that Audyssey makes a compelling improvment, BUT IT TAKES WORK. Thank goodness for this wonderful forum.
PS: I assume that messing with the individual speaker levels will certainly affect Audyssey's EQ, right?
J.Mike
post #40 of 47 Old 07-14-2007, 10:45 PM
soundlovr's Avatar
No, it will just change how loud each speaker is (but each speaker will still be corrected for a proper frequency response in your room). You can expect your soundstage to shift around.
As has already been pointed out, changing the crossover and small/large settings is fine... the original Audyssey FAQ was written by someone who assumed that the setup routine would get those to their best settings and that's why they shouldn't be changed. Experience quickly taught that it wasn't so and as has been pointed out, Chris clarified soon after to ignore that warning.
post #41 of 47 Old 07-15-2007, 03:58 AM
legierk's Avatar
Originally Posted by vetboy View Post
has anyone used audyssey with more than one subwoofer? I currently have 2 paradigm servo 15's flanking the tv on either side and I'm thinking of upgrading to the 4308 from my 3803 but I'm not sure if its worth it.
I tried to calibrate with Audyssey using both of my subs and kept getting errors. I had to disconnect one sub, and viola, calibration went down without a hitch. After that, I just reconnected the other sub. Worked well for me.
I'm sure delay issues caused the problems.
This is MultiEQ XT on a Onkyo 805 BTW.
legierk is offline
post #42 of 47 Old 05-26-2013, 08:36 PM
Namikis's Avatar
No matter how much you or we try to defend it - the autocalibration feature in the midline receivers (basic Audyssey) is a big disappointment. It happened with my Onkyos and now with the Denon 3313ci I just bought (and with the Yammy YPAO I had before, to be fair). In every case I was better off leaving Audyssey out and using the RS level meter to deal with levels (and a measuring tape for distances). This morning, as an example, I listened to two concerts in the Denon (no Audyssey) and was amazed at the sound. I had more time in the afternoon and decided to test Audyssey to see if it would do any better than in my old Onkyo TX-NR1009. The receiver now sounds like crap. I will reset it and go back to my levels iPAd app to calibrate. The sounds feels compressed, lifeless, dirty. That is how I see it - stick with a level meter and you will be happy. Use Audyssey and you will need three beers in your before it sounds ok.
Emotiva XMC-1 / Emotiva XPA1-L / Sunfire 405x5 / Behringer iNuke 3000DSP
Oppo BDP-83 / VPI Aries 1 / with JMW 10.5 Memorial Tonearm and Van de Hul Frog cart
Goldenear Triton Ones / Supercenter XXL / Buttkicker LFE /Rythmik FVP15HP
Mistubishi HCD7900 / Elite VMAX2 135" screen / Sharp Aquous 60" LC-60LE450U
Other sources: MacMini / Roku HD / XFINITY / Chromecast / too many tape decks
Namikis is offline
post #43 of 47 Old 05-26-2013, 09:07 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
do whatever works best for you and your system. we will not be listening to your setup and only YOU need to be satisfied.
Afro GT
afrogt is offline
post #44 of 47 Old 05-27-2013, 05:06 AM
Quoted: 75 Post(s)
Liked: 113
It's obviously true that Audyssey didn't work for your system and room, but that doesn't mean it's true for every setup. Also, Audyssey isn't the only player on the block as YPAO, ARC, MCACC, and others are out there as well. Do whatever sounds best to you.
rnatalli is offline
post #45 of 47 Old 05-27-2013, 10:05 AM
Patrick Murphy's Avatar
Quoted: 67 Post(s)
Liked: 65
I stumbled on this thread, assuming it was another "I hate Audyssey" bashing, only to find that it was almost 6 years old. Namikis, how many pages did you have to go back to find it?
Patrick Murphy is offline
post #46 of 47 Old 05-27-2013, 01:49 PM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Accurate sound reproduction isn't everyone's cuppa. Some just get used to a rooms' character and don't like the change.
rnrgagne is offline
post #47 of 47 Old 05-27-2013, 06:45 PM
Quoted: 995 Post(s)
Liked: 523
"Accuracy" is a different thing from "adding a non-defeatable notch to the midrange to compensate for incompetently-designed loudspeakers, and neutering the natural low-end room gain." (The high-end rolloff technically isn't either, but unlike those first two design choices the HF rolloff makes some sense.)
If you like Audyssey, great. But its target curve is not reasonably characterized as "accurate."
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Audyssey
