The Official INTEGRA DTC-9.8 Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 13009 Old 07-29-2007, 10:07 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Originally Posted by frombhto323 View Post
Thanks. It's just that I've noticed that some manufacturers say "balanced inputs/outputs" in their marketing literature, but the price of the component leads me to be skeptical that they are truly balanced at that price point. I know some manuafacturers, like ARC, BAT, and Cary have a reputation for offering truly balanced products, but they also tend to be pricier. Which leads me back to the poster's question on this: At this price point, can we reasonably believe the XLR outputs on the 9.8 are truly balanced?
Why? What is it about "truly balanced" that distinguishes it from balanced that makes a difference to you?
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #722 of 13009 Old 07-29-2007, 10:17 AM
NickS's Avatar
Truly balanced just gotta be mo bettah than the other kind.
Right?
NickS is offline
post #723 of 13009 Old 07-29-2007, 10:20 AM
frombhto323's Avatar
My understanding of the technology is limited, but from what I do understand, many manufacturers use single-ended technology on their XLR inputs and outputs, thereby negating the true benefits of balanced connections. If that is the case here with the 9.8, many end users, like myself, might decide that it is not worth investing in XLR cables when we already have RCA interconnects that will do the job just fine.
If, on the other hand, the 9.8 is truly balanced (not just putting an XLR jack on single-ended circuitry), then some of us might decide it's worth it to give it a try. I've read many a review where the reviewer noted that a component performed better when XLR cables were used as opposed to RCA interconnects, even over short runs. If such a benefit is to be (theoretically) gained with the 9.8, then it is a factor in our setup options.
frombhto323 is offline
post #724 of 13009 Old 07-29-2007, 10:41 AM
davewolfs's Avatar
Any reviews on this pre/pro yet? Seems like we all want one, but there has been minimal feedback.
davewolfs is offline
post #725 of 13009 Old 07-29-2007, 10:49 AM
m1fuller68's Avatar
Placed my order on Friday...Will not receive until the end of August
Equipment that it will power...
Samsung 61" DLP 1080P
Emotiva MPS-1...7.1 config.
Toshiba XA-2 HDDVD
Panasonic DMP...Blu-ray
Xbox 360 elite
D*HR20-700
M1
m1fuller68 is offline
post #726 of 13009 Old 07-29-2007, 10:55 AM
Quoted: 673 Post(s)
Liked: 460
As I implied, one can obtain a true balanced output without having a completely balanced internal configuration. Both will afford all the benefits of a balanced connection.
NO. What they do is convert the SE to BAL before the connector. See above. I strongly doubt that the 9.8 has fully balanced internal circuits and, yet, its balanced outputs are valid if needed.
You are confusing balanced internal circuitry with balanced connections/wiring. The only benefits to balanced connections/wiring are reduced noise pickup for LONG runs in noisy environments and more secore connections (XLR>RCA). Internal issues are another thing and it is doubtful that the opening statement of this paragraph is generally true.
Kal Rubinson
post #727 of 13009 Old 07-29-2007, 11:29 AM
NickS's Avatar
How about the higher output voltage/dB gain found with most competent balanced output designs?
NickS is offline
post #728 of 13009 Old 07-29-2007, 11:31 AM
B&W700guy's Avatar
Kal...are you getting paid to sell "secore connections" I didn't know they had an RCA and an XLR line?
B&W700guy is offline
post #729 of 13009 Old 07-29-2007, 12:34 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3035
Toshiba XA-2 HDDVD
Xbox 360 elite
D*HR20-700
M1
I have on order or own:
Samsung 720p dlp
Panny BD player
Integra 9.8
Emotiva MPS-1
Let's keep in touch.
oink is offline
post #730 of 13009 Old 07-29-2007, 12:49 PM
B&W700guy's Avatar
+6dB Gain on XLR's
Note: when using 5 or 7 channels of XLR with a Subwoofer that is equipped with an RCA input. Because of the +6db gain you may not be able to turn the subwoofer volume up loud enough to match the 5/7 channels volume.
It just depends on the subwoofer. But, as I understand you can have the subwoofer gain modified for match performance.
post #731 of 13009 Old 07-29-2007, 12:50 PM
AJH
AJH's Avatar
Originally Posted by Toe View Post
Also, I skimmed the whole 130+ pages of the online manual and did not see a clearance height reccomendation as far as mounting this unit in a rack. Did I miss this info as far as how much clearance should be given right above the unit? My rack is open on all sides, but no a whole lot of space between the unit and the shelf above it, but I think I would be OK given that there is plenty of ventilation otherwise. Any thoughts?
Check page 2 #18 of the manual for ventilation requirements.
AJH is offline
post #732 of 13009 Old 07-29-2007, 01:00 PM
tlllava's Avatar
As an electrical engineer, let me explain the benefits of balanced connections. (I'm in digital communications not consumer electronics but this is a general transmission issue.)
Balanced connections send the signal voltage as both a positive & negative voltage down two adjacent wires with a third ground wire. This is done for noise reductions. Imagine if the instantaneous voltage is +5v. The balanced connection would send +5v & -5v. At that instance, noise of +0.3v is picked up by the wire. The receiving unit would receive +5.3v and -4.7v. It then inverts the negative voltage and averages the two. The 0.3v noise is cancled out resulting in +5v.
This is the general principal. There are many ways of accomplishing this. However, it is usually only important to start and end the balanced lines at the back panel. Internal noise would generally be generated by the unit it's self since the the equipment has a grounded metal case. If this is the case, there is a design problem that is causing the noise. I can see some hyper-sensitive engineer using balanced internally to keep the small noise from inside the box out of the signal but this is really splitting hairs.
Again, I'm in digital communications so have never had to make a design where the analog signal must remain absolutely pure. I'm sure you could find another engineer to get in a flame war with me but the fact is that internal balanced lines would be used to solve very minor noise issues.
The Lava Lounge Construction Photos
tlllava is offline
post #733 of 13009 Old 07-29-2007, 01:30 PM
D-Bucket's Avatar
Yes, the manual recommends 8" clearance at the top of unit for enclosed applications. That 8" clearance plus the 7-5/8" height of the 9.8 would require an internal shelf height of 15-5/8" (nearly 16") without an external fan or air circulation device.
Quote from page 2, #18 of DTC-9.8 manual
If you install the apparatus in a built-in installation, such as a bookcase or rack, ensure that there is adequate ventilation. Leave 20 cm (8") of free space at the top and sides and 10 cm (4") at the rear. The rear edge of the shelf or board above the apparatus shall be set 10 cm (4") away from the rear panel or wall, creating a flue-like gap for warm air to escape.
D-Bucket is offline
post #734 of 13009 Old 07-29-2007, 02:04 PM
m1fuller68's Avatar
Samsung 720p dlp
Panny BD player
Integra 9.8
Emotiva MPS-1
No problem, when does your 9.8 arrive?
post #735 of 13009 Old 07-29-2007, 03:54 PM
smittycat's Avatar
I have my Integra DTC-9.8 on order as well....no information yet on when it will arrive. Hopefully sooner rather than later!
The 9.8 will be paired up with a B&K 125.7 S2 Reference amplifier and a Samsung BD-P1200 Blu Ray player. Can't wait to get the high-res audio via HDMI matched with the 9.8's Audyssey calibration, for some serious LPCM surround sound.
Although this will likely be overkill for my current theater setup, it should come in handy for a dedicated theater down the road.
Looking forward to more early-owner's reviews so I know what to expect when my rig arrives. Thanks to those so far who are spending time tweaking the 9.8 and posting their impressions.
-Smittycat
smittycat is offline
post #736 of 13009 Old 07-29-2007, 04:45 PM
Toe
Toe's Avatar
Quoted: 1450 Post(s)
Liked: 1831
Bummer I have plenty of room on the sides and back, but only about 1/2" on top.
Toe is online now
post #737 of 13009 Old 07-29-2007, 05:10 PM
tlllava's Avatar
It's probably the heat from that toroidal transformer. Anyone have an idea why a pre/pro would need this? I understand why amps use them but can't figure out why a pre/pro would use it.
tlllava is offline
post #738 of 13009 Old 07-29-2007, 05:29 PM
ekdo's Avatar
Better sound!
A toroidal transformer has a lower noise floor so you can hear the softer passages with better harmonics and signal accuracy. Reduction of noise is more important in a pre amp than an amp.
ekdo is offline
post #739 of 13009 Old 07-29-2007, 05:44 PM
tlllava's Avatar
Originally Posted by ekdo View Post
Better sound!
I still don't get it. The noise reduction comes from having a low noise floor on the power supply. When I was a coop (19 years ago) I built a power supply that could deliver 10A with only 5mV of noise with a regular transformer.
Now, a good pre/pro would want an even lower noise floor but shouldn't need 10A. The toroidal transformer is all about delivering lots of clean current. A pre/pro shouldn't need much as it's not driving speakers.
tlllava is offline
post #740 of 13009 Old 07-29-2007, 05:55 PM
dlinsley's Avatar
Quoted: 141 Post(s)
Liked: 65
Better sound!
Meridian's G68 and 861 reference processors both use a switch-mode supply, and have great analogue performance. It's well reported on the Meridian forum that the switch-mode supply in the G68 is just an off-the-shelf part.
It's possible that Integra/Onkyo kept the changes from the Onkyo 875 as small as possible to minimize design costs and production line changes. The component cost may be higher, but overall it could work out cheaper for them to build this way.
dlinsley is offline
post #741 of 13009 Old 07-29-2007, 06:29 PM
AJH
AJH's Avatar
Has it been confirmed by an owner that the 9.8 won't output to both HDMI's simultaneously?
AJH is offline
post #742 of 13009 Old 07-29-2007, 06:32 PM
davewolfs's Avatar
That is fairly significant. Is it a bad idea in general to put audio equipment in a wood media cabinet?
post #743 of 13009 Old 07-29-2007, 06:41 PM
fakerley's Avatar
I hope not. I just built one last weekend. Don't have the 9.8 yet but put my new Outlaw amp in there. I left 8" clearance for the amp and 6 for the 9.8. All side are open so I am not worried about heat. The amp stays warm, not hot at all.
Wood should be fine for an equipment rack.
Frank
GO Red Wings
fakerley is offline
post #744 of 13009 Old 07-29-2007, 06:48 PM
davewolfs's Avatar
My wife wants to purchase this, I let her choose the furniture she lets me choose the electronics.
Do you think this will be fine?
http://www.ethanallen.com/images/pro...642_xlarge.jpg
post #745 of 13009 Old 07-29-2007, 06:56 PM
fakerley's Avatar
It looks good but can you get the required 8" of clearance that the manual states? Maybe those shelves are removable.
I sould have stated that my rack is behind a wall so I didn't much care how it looked.
Frank
GO Red Wings
fakerley is offline
post #746 of 13009 Old 07-29-2007, 07:09 PM
B&W700guy's Avatar
looks too small to me
post #747 of 13009 Old 07-29-2007, 07:22 PM
shanemcr's Avatar
You're going to need something like this: http://www.parasound.com/zcustom/zbreeze.php
shanemcr is offline
post #748 of 13009 Old 07-29-2007, 08:09 PM
Quoted: 673 Post(s)
Liked: 460
Only an advantage if needed. Most systems have adequate gain.
Kal Rubinson
post #749 of 13009 Old 07-29-2007, 08:11 PM
Quoted: 673 Post(s)
Liked: 460
Agreed. My comments were limited to the external wiring and its immediate connections.
Kal Rubinson
post #750 of 13009 Old 07-29-2007, 08:12 PM
Quoted: 673 Post(s)
Liked: 460
They don't but if we can whip up enought interest.................................................... ...
Kal Rubinson
