Help! My Denon AVR-3805 is shutting off! Flashing Red.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2007, 09:19 AM - Thread Starter
jdbizkits's Avatar
I have had my Denon 3805 and system running for about 2 years. I have not had any issues and have not touched a thing in a long time. All of a sudden the receiver is going into the protection mode (shutting off and flashing red light) when I turn up the volume a little bit (only to -15db or so...not really loud at all). It seems to only happen on DVD and TV mode. I checked the CD player and I can play it super load for a long time with no issues.
I tried to narrow things down a bit also, by turning off the TV (i am using the component video switching). I also put a plain CD player in the DVD player with no video and it still tripped it.
I shut off the sub/amp, still tripped. I tried dolby digital, pro logic, DTS, and stereo...all tripped. I dont have this issue on my zone 2 setup either.
If anyone can help me out to figure this out that would be great. This is really a bummer and my family is giving me the evil eye since this is the families tv setup and since the video goes through receiver....it kills everything.
JD
jdbizkits is offline
post #2 of 4 Old 07-16-2007, 09:30 AM
JOHNnDENVER's Avatar
1. Check all speaker wire and re-do all speaker connections. Listen carefully to each driver in each speaker to make sure you do not have a blown driver that you are unaware of.
Still have issues?
2. disconect all speakers and see if the amp stays on
Still have issues?
3. start swap'n speaker connections and see if you can isolate it to one speaker
Still have issues?
Take the AVR in for service.
JOHNnDENVER is offline
post #3 of 4 Old 07-16-2007, 10:15 AM
Zen Traveler's Avatar
Quoted: 527 Post(s)
Liked: 531
Originally Posted by JOHNnDENVER View Post
1. Check all speaker wire and re-do all speaker connections...
I agree with JnD--check this first.
Zen Traveler is offline
post #4 of 4 Old 07-18-2007, 07:08 AM
wolfgaze's Avatar
If it does have to go in for Service, you have a Denon Authorized Service Center not too far from where you live:
SCAN AUDIO
8101 ORION AVENUE #7
VAN NUYS, CA 91406 USA
(818) 786-4240
Even though you are out of your warranty, it would be wise to take it to an authorized repair center.
wolfgaze is offline
