"The" Onkyo TX-SR875 Thread - Page 202 - AVS Forum
Old 04-29-2013, 03:05 PM
bojke1's Avatar
Hi guys. I need your help about proper settings of frequency of my speakers with Onkyo TX-SR 875 receiver.
My front speakers are JBL ES90 and technical specification of these speakers is:
Power Handling (Recommended) 110W
Power Handling (Peak) 440W
Sensitivity (2.83V@1m) 91dB
Crossover Frequencies 500Hz, 3kHz – 24dB/octave; 12kHz – 18dB/octave
Maximum Recommended Amplifier Power 225W
Frequency Response 36Hz – 40kHz
Nominal Impedance 8 ohms
My central speaker is JBL ES25C and technical specification is :
Power Handling (Recommended) 75W
Maximum Recommended Amplifier Power 150W
Crossover Frequencies 3000Hz – 24dB/octave; 12000Hz – 18dB/octave
Sensitivity (2.83V@1m) 90dB
Frequency Response (-3dB) 80Hz – 40kHz
Power Handling (Peak) 300W
My surround speaker is JBL ES20 and technical specification is :
Power Handling (Recommended) 60W
Nominal Impedance 8 Ohms
Maximum Recommended Amplifier Power 125W
Frequency Response (-3dB) 60Hz – 40kHz
Crossover Frequencies 3300Hz – 24dB/octave 12000Hz – 18dB/octave
Power Handling (Peak) 240W
Sensitivity (2.83V@1m) 86dB
My subwoofer is JAMO E7SUB and his technical specification is:
Impedance (Ohm) 22k
Woofer (mm/in) 254 / 10
Weight (Kg/lb) 21/46,3
Frequency Response (Hz, +/-3dB) 40 - 150
Rated output (W) 675 peak
Overall Dimensions (mm/in, HxWxD) 375x375x375/14,76x14,76x14,76
I would like to know how to adjust adequate frequency for each of these speakers that I mentioned above(front, central, surround and subwoofer) in the Onkyo receiver TX-SR 875?
All suggestions are welcome. Thank You.
And another question, how in onkyo TX-SR 875 change impedance from 4, 6 ohms to 8 ohms as all JBL speakers works at 8 ohms?
I currently have option in onkyo 875 to change the 4 and 6 ohms.Does not offer me the option to switch to 8 ohms.
Sorry for my bad English.
Thank You in advance
bojke1 is offline
Old 05-25-2013, 01:58 PM
swa66's Avatar
I've an Onkyo TX-SR875 for many years - it was a new model when I bought it.
Screen is attached via HDMI only.
I'm using almost only HDMI inputs (all 4 taken), and 1 component input (WII). I've not used the WII in years, but it used to work just fine - not so anymore.
All the component and composite inputs seem to have gone bad somehow.
The input is seemingly lacking the needed synchronisation and the image is shaking sideways all over.
I've tried hooking up the WII to all 3 component inputs and to the composite input of AUX2 as well, all the same result.
I've also tried all 3 output modes of the WII, no joy.
If I hook up the WII directly to the TV I get a perfectly good image (but no sound, my screen has no speakers at all).
So it's not cables nor the WII itself.
I might over the years have changed some setting that is causing this - but I've tried canging many of them and nothig seems to help at all (passthrough or upscaling all seems to make no difference at all).
Any settings I need to double check or any easy repair options for the Onkyo ?
I'm located in Europe should that matter (and the Onkyo is a EU model).
swa66 is offline
Old 05-27-2013, 11:09 AM
der-gee's Avatar
Hi everyone,
can some one please provide me a link or an copy from the "xx5_Onkyo_UpdatesISO.zip" file? As far as I understand, it's handy for fixing the EEPROM error. I tried google and searched this board, but didn't get a working copy.
*edit: I would like to fix the EEPROM Error according to this post: The Onkyo/Integra direct firmware updates. My Problem is, I just can't find any of the needed files. The receiver is a few years old now and forgets it's settings every time the power goes down. It's actual Firmwares are: MAIN: 1.07 and HDMI 1.01
Can anyone tell me, which are the newest firmwares and where to get them and perhaps the old 1.05 main fw?
Thank you very much in advance!
der-gee is offline
Old 07-14-2013, 12:32 PM
Tspeer's Avatar
I have re-uploaded the xx5 recievers firmware update ISO: http://www.share-online.biz/dl/FCBBVXPM39
I Bet You Wish You Could! - Roger Wilco
Directions for updating your Onkyo xx5 receivers firmware. **Newly updated 7-22-2009**Re-uploaded 7-14-2013**
Something from damninteresting.com
Tspeer is offline
Old 07-16-2013, 05:16 AM
vadja's Avatar
Hi Tspeer, your image includes the TX-SR875 ( 1.09/08Y19A ) firmware?
vadja is offline
Old 07-16-2013, 07:00 AM
Tspeer's Avatar
I believe the 1.08 is as high as it goes. There is also a DSP update and an HDMI update.
They are all good starting points and solve most problems. I do not know what the 1.09 is suppose to fix over the 1.08.
Tspeer is offline
Old 07-21-2013, 07:04 PM
belhouari abdel's Avatar
hi i have a problem with onkyo TX-SR 875 HDMI signal , components signal are OK, i want to know witch capacitors must be changed.
Thank you
belhouari abdel is offline
Old 11-18-2013, 04:15 PM
bkedelen's Avatar
Have any of you folks used your 875 as a 7 channel amplifier for a newer pre/pro?
Because I have a last gen Panasonic plasma (no 4k) and a 7.1 home theater, I am thinking that an integra 80.2 or onk 5508 will better feature match my components than my 875, but I do not have the resources to get a pre/pro AND a new 7ch amplifier at this time. I got my 875 new in 2007 and particularly since getting some active cooling for it, it has been a titan.
It occurred to me that the 875 might act as a perfectly adequate (and THX Ultra 2 certified) amplifier for the time being.
Does anyone have experience with this? Obviously I want the 7 analog channels coming out of a nice pre/pro to bypass all signal processing in the 875, and I have heard that is possible except for volume control. How would one go about eliminating all signal processing from that source (I am assuming there is a specific sound mode for this, maybe a menu setting?), and if the volume cannot be eliminated, what volume should I set on the unit to interfere as little as possible? Is it plausible to expect a setup that works as well or better than the 875 has worked by itself?
I would really appreciate hearing about people's experiences.
bkedelen is online now
Old 01-20-2014, 09:41 AM
sportytourer's Avatar
My TX SR875 was in storage for 4 years and today upon hooking it up noticed there was no output from the Center or Surround L/R channel. I cannot get a test tone either. Tried a reset to no avail. Speakers work fine so that not the issue. Front L/R and Surround Back L/R work fine so it is the other two channels were I am having issues. Any ideas what it could be as I went through the speaker setup and settings are all correct?
sportytourer is offline
Old 01-20-2014, 11:43 AM
Surprise, especially me... It is now working.
I ran it last night and got it fairly warm but still had the issues.
This morning I checked for obvious signs and checked the fuses by pulling them out and placing them back as well as testing transistors and looking for blown caps and a smell test but nothing came up. Hit the power button and surprise all speakers worked perfect.
The only solution I came up with was either the heat from the previous night of running made it work (though I doubt this as it was unplugged all night and it ran perfect while dead cold) or the fuses I pulled to test for the channels might have had oxidation between the clips and by moving it to test the connection was re-established (this is what I think was the accidental fix).
Oh well, no longer looking for a new receiver so happy I am.
Old 02-06-2014, 11:18 AM
Blurry's Avatar
My 875 currently developing crackling sounds on both left frond and right surround back, after 5 yrs working without any issues.
Cables and speakers are checked and confirmed not the cause.
Anybody encountered this before and what is the possible cause?
Blurry is offline
Old 03-21-2014, 10:33 PM
SkullPhyre's Avatar
Quoted: 25 Post(s)
My HDMI port either 1 or 4 worked the other day. My x-box one had video but no audio. I swapped cable around then determined that it was not cables, but the port itself. It lets audio but not sound through. when I used both cables I was testing they worked in the other port. Any suggestions?
SkullPhyre is offline
Old 04-22-2014, 01:41 PM
shpankey's Avatar
Liked: 32
This one works currently. Thanks again.
26 What good will it be for a man if he gains the whole world, yet forfeits his soul? Or what can a man give in exchange for his soul?
Matthew 16:26 NIV
shpankey is offline
Old 06-04-2014, 12:05 AM
T Hameed's Avatar
Did you get the crackling sound problem resolved. I also have the same problem. More so in the surround mode.
T Hameed is offline
Old 08-20-2014, 09:24 AM
Liked: 0
Can anyone who actually owns one of these units answer me a question please?
Onkyo have told me, in numerous emails, that the 875 will pass through both video and audio in standby, in other words, I don't have to have the amp turned on all the time just to watch the news from my SkyHD box etc. But no matter how many times and what permutations of settings I try, nothing works, as soon as I turn off the 875 the picture/sound is gone.
Any ideas, please?
Thank you.
Chris
SSThing is offline
Old 08-20-2014, 09:41 AM
dannieboiz's Avatar
Any ideas, please?
Thank you.
Chris
As far as I know the amp must be turned on.
dannieboiz is offline
Old 08-20-2014, 09:52 AM
Liked: 0
It certainly seems that way, but I have just this minute had another email from Onkyo telling me it is possible and to turn off the unit for one hour. If that doesn't work I am told to reset and then start from the beginning. I am not holding out much hope though to be honest.
SSThing is offline
Old 08-27-2014, 12:39 PM
Quoted: 149 Post(s)
I have the TX-SR875 and it does not hold its settings after the power has been turned off and then turned back on. Which leads me to believe it needs a Firmware upgrade. Having said that I have also heard that some of them have been BRICKED after trying the Firmware upgrade. So is there a way to avoid that or is it the luck of the draw?
ALSO can anyone confirm if it can handle 4 Ohm Speakers without any issues like the Axiom M100s.
I am running Ascend Towers With RAAL FR/FL and Sierra1's as RR/RL with and old Aperion Center and a JL F113 Subwoofer.
I feel like I am not getting the most from these speakers compared to everyone else on the Ascend Forum.
AVSF458 is offline
Old 08-27-2014, 02:17 PM
Jon S's Avatar
Quoted: 169 Post(s)
Liked: 79
Chances are the unit probably has a failing battery to charge the memory that stores the settings. If it does not have a battery, the NV-RAM is going bad. Either way, new firmware ain't gonna fix it...
If it's not a BIG screen, it's not a theater...
Jon S is online now
Old 08-27-2014, 03:47 PM
Keith Mickunas's Avatar
Quoted: 88 Post(s)
Liked: 74
I concur, it's doubtful a firmware update would have any affect on this whatsoever. You could search this thread for memory or battery and see if someone else has had a similar issue. This receiver was introduced 7 years ago, so it might be difficult to get parts for at this point.
As for 4 ohm speakers, try and search the thread, or skim the first few hundred posts, you should be able to find something about that. It's a fairly common subject any time a new receiver shows up. Investing in a good 2-channel amp would probably be a good idea for those speakers though.
Keith Mickunas is online now
Old 08-30-2014, 12:29 PM
VisionOn's Avatar
Liked: 520
This is a well known issue that was covered at length in this thread years back. Firmware will not help and if I remember correctly will need replacement of components.
It's one of the main reasons I replaced mine with a Denon years ago. My 875 is just sitting in the box collecting dust.
edit: searching for the E2PROM error will bring up results like this thread: Onkyo E2PROM Error Thread
VisionOn is online now
Old 08-30-2014, 10:45 PM
crossy1's Avatar
Liked: 0
Hi,
I have a 7 year old TX SR 875 which had the HDMI card replaced at great expense about 15 months ago.
When I got it back I set up all the original inputs (Cable TV, Blu Ray player etc) but did not configure the AM/FM Tuner. Yesterday when I tried to configure it, I couldn't. The display shows the Frequencies changing as I step around the local stations, but I could not tune to and receive any stations (AM or FM). While all this was going on, I was receiving what sounded like a community station playing dance music, but that came through on FM no matter what I did. If I unplugged the external antenna, I got nothing at all.
The unit was reset to factory settings, and Firmware was updated (or so I was told).
Any suggestions, please? Is the tuner a separate plug in unit? Could it perhaps have been dislodged during the HDMI card replacement?
Rob.
PS: I have found that the station it can receive is 99.1 FM. No matter what the tuner display says, this is the only signal I can receive. Strange thing is that even if I scan the Onk past 99.1 it still won't recognise the station.
crossy1 is offline
Old 09-23-2014, 12:08 AM
dannieboiz's Avatar
Is it possible to have the internal amp playing HDMI audio as well as the pre-amp out simultaneously? Looking to have same audio source doesn't even have to be different. I just need to have a 2 channel analog output to a separate amp to drive other speakers.
Old 12-04-2014, 05:27 PM
SkullPhyre's Avatar
Quoted: 25 Post(s)
I just bought a Samsung 8550 and It has the smart hub. This receiver being old doesn't have ARC. I have ran a Optical cable from the out on the tv into the Game/tv optical 1 port. I still can't get the sound to come through. Any ideas. I think it is about time for a new receiver.
Old 12-08-2014, 10:39 PM
Tspeer's Avatar
Audio Return from the TV? I believe you need a particular type of HDMI cable for that. The ARC channel only goes in one direction, so the HDMI cable has to be plugged in a certain way. I bought some newer HDMI cables awhile back and it was labeled input and output. If I hooked it up backwards, no picture. If you get a couple of those, I think you will get the missing audio. It's also possible that the directional-ness, was just the particular brand I had purchased: http://www.monoprice.com/Product?c_i...seq=1&format=2 In any case I would try a new high-speed HDMI cable before buying a new receiver.
Tspeer is offline
Old 12-13-2014, 01:31 PM
SkullPhyre's Avatar
Quoted: 25 Post(s)
I got it figured out. I set input to Aux 1. When I input digital optical it switched back. It is working good now.
I am switching to a Nr838 next year unless the 2015 models look better.
Old 01-07-2015, 07:24 AM
zpaulg's Avatar
Liked: 0
Onkyo 875 problem
Gents,
The left rear surround channel on my amp has stopped working for no apparent reason. Definitely the channel as I have checked speaker, cables etc. Any ideas appreciated........
zpaulg is offline
