"The" Onkyo TX-SR875 Thread - Page 203 - AVS Forum | Home Theater Discussions And Reviews
post #6061 of 6080 Old 02-26-2015, 01:04 AM
Liked: 0
has anyone ever tryed using the 4X I2S PCM/DSD audio stream inputs thats on the 10pin connector going from the HDMI board NAHDM-9114 to the DSP board NADSP-9072 ?
the 10 pin connector has the following names for each connection,
1. HDSPDIR (i think this is the digital S/PDIF from the SIL9135 an also go's to SIL9134)
2. GNDHD Ground
3. PCMLR/DSDFL (I2S data for main Left & Right/DSD front Left
4. PCMBCK/DSDCLK (I2S/DSD Clock Signal)
5. PCMLRCK/DSDFR (I2S LR Clock/DSD front Right)
6. PCMCSW/DSDSW (I2S Center+Sub/DSDsub
7. hdmi clk
8. hdmi rst (go's high to reset the hdmi mpu ?)
9. vsp rst
10. CEC IO (CEC in/out data ?)
11. vsp rxd/vsp scl
12. vsp txd/ vsp sda
13. hdmi stb
14 rx mute (think this go's high to mute the audio I2S input stream i am trying to get working from hdmi board ?)
15. hdmi sdi
now can anyone help me please ? what signal's out of them 15 do i need to work out in order to get the I2S buses working please, any ideas ?
if only we could get the 4X I2S and DSD audio input bus's working the TX-SR875 would be one hell of a DIY project
it look's possible to mod the power supply's to,
the DAC board from separate highly regulated pure noise free power source along with analog input board
it seem's there's also 3 separate secondary winding's on the transformer for the power output stage but they each pass through a rectifying diode then coupled all all together but could split that up using extra filtering cap's then change how the powe output stage is powered, may be split it up like 2 of the winding's powering 2 channel's each then the other powering 3
the DSP board also has what i think is a JTag connection so may be possible to try and work with the 3 DSP chip's and re-program them as digital Xovers then you could use the amp as a 3 way stereo amp leaving a channel for sub making a basic 4 way with stereo top/mid/bass an shared mono sub channel's plus loads of other possibilities there for future development if only we can sort this I2S bus out first
as the Onkyo TX-SR875's with the HDMI problem are really cheap and a grate could be a really good DIY Gold Mine if its possible to activate the I2S and DSD bus coming from that hdmi board
ps, i have a raspi could i try to get the i2s bus working with that by any chance pls or is there any cheap usb to 4X i2s/6 ch dsd or anything thats really cheap and easy to get hold of here in the uk to start trying things out please ?
im also waiting for a single trace Oscilloscope i got cheap off ebay locally along with other stuff im slowly getting together for my new hobby, DIY Audio so expect to see knocking about on this forum more and moe as time go's on
please any help at all
thanks
paulflan is offline
post #6062 of 6080 Old 03-19-2015, 02:30 AM
Liked: 0
Picture seems better bypassing 875
Hi, I'm a new member and need some advice. My left front speaker no longer works, have checked everything and there is definitely no output from the amp.
Anyway, I've plugged my blueray (Sony PS2) directly into my tv via HDMI so I can put the 875 in to be updated and fixed, and have noticed the picture is much better than when it was previously running through the TX-SR875. Is this normal? The PS2 has no real video output settings so don't know the reason why.
Thanks in advance for your help.
Johno1972 is offline
post #6063 of 6080 Old 06-02-2015, 06:21 AM
Tspeer's Avatar
It sounds like the upconversion on the Onkyo might be set to output at 720p or 480p, or perhaps the output from the ps3 was set to 720p before, and it now at 1080p. It's also possible that the tv has a better upconverter, but that shouldn't matter if the output is 1080 to start with. Just check the video settings all through the chain, starting at the player. You can disable all upconversion in the onkyo as well and compare.
I Bet You Wish You Could! - Roger Wilco
Directions for updating your Onkyo xx5 receivers firmware. **Newly updated 7-22-2009**Re-uploaded 2-23-2015**
Something from damninteresting.com
Tspeer is offline
post #6064 of 6080 Old 08-30-2015, 08:28 AM
scsiraid's Avatar
Tspeer, what firmware versions are represented in your iso image (and in which folder)? Im trying to locate version 1.05. I currently have 1.07 installed and am having the ee2prom error after loss of power. Ive tried the full reset followed by save settings but the store 'fails'. Would greatly appreciate any pointers to firmware 1.05 or any ideas as to how to fix the ee2prom error.
**** EDIT - Well, Ive answered my own question. The iso contains 1.04 and 1.07. I can go back to 1.04 and get rid of the e2prom error but the audio resync is soooo slow I hate it.
I really need to get version 1.05. As I recall, it sped up the audio resync.... Else I just need a new receiver.
Thanks, Don
scsiraid is offline
post #6065 of 6080 Old 08-30-2015, 08:41 PM
Tspeer's Avatar
The ISO has 1.04 and 1.08. I've never found 1.05, and I believe there was a 1.09 as well. But getting to 1.08 fixes all the major bugs.
The ee2prom error we suspect means a bad part in the system. There are a few things to try. There is a text file in the ISO that is a clip from some ancient forum post, this might help you:
After the main unit firmware update, you get a COMPLETE message on the display, then CLEAR appears and then the unit goes into standby. I found that this doesn't completely clear the receiver, I found that network settings & internet radio stations remain intact after a firmware update... so the next thing to do is a full factory reset:
Press and hold the "VCR/DVR" button on the front panel down and then press the "Standby/On" button. This clears EVERYTHING!
Next, On the front panel, press and hold the "Setup" button and press the "Enter" button. "Setup Store ?" will appear on the display. While still holding down the "Setup" button, press the "Enter" button again. You will then see "Setup Storing" on the display. I found this was the magical step that made the dreaded E2PROM ERROR go away.
Until I completed the Setup Store, virtually every time I pulled the plug on the receiver, I would get an E2PROM ERROR message upon restoration of power and my settings would vanish.
I found this only needed to be done once, right after the full factory reset. Even after changing settings on the receiver, it would still remember what I had changed, even if I didn't do the "Setup Store ?" procedure afterwards.
My theory is that the "Setup Store" somehow formats the E2PROM memory to the requirements of the newly flashed firmware.
If you haven't downloaded the ISO yet, I would. I keep having to re-upload it every year or so... the freebie file hosting sites delete files after so long apparently. If the above works for you, you might want to just get it to 1.08. After flashing it to 1.08, follow the above steps to do the full resets and then the setup store step.
Tspeer is offline
post #6066 of 6080 Old 08-31-2015, 06:10 AM
scsiraid's Avatar
Thanks... I had already tried the full reset and 'save' steps. The store settings step 'fails'. With 1.04 the e2prom error goes away but the store settings still fails.
I have downloaded the iso. I found 1.04 and 1.07... not 1.08. Ill dig around some more and see if I can find it. Would you recall where in the structure it is?
Thanks!!!
scsiraid is offline
post #6067 of 6080 Old 09-01-2015, 04:30 PM
Tspeer's Avatar
It's right in the TX-SR875 Folder in the ISO. You can unzip it, or burn the image to cd using imgburn (its free just google it).
From the sounds of it, since the setup-store fails, there's likely a defective component in the unit. The only way to really get around it will be to take it an authorized service center. If you happen to live in a big city that has one, it might be worth doing. If you will have to ship it in, the shipping costs might push the repair cost over the line of being worth it.
Tspeer is offline
post #6068 of 6080 Old 10-10-2015, 12:44 PM
Liked: 0
Hi Tspeer,
sorry to ask but would you share the software again?
I got a 875 what needs to be upgraded but i cannot find
the software.
Johan
aardbei is offline
post #6069 of 6080 Old 10-11-2015, 02:12 PM
Tspeer's Avatar
Originally Posted by aardbei View Post
Hi Tspeer,
the software.
Johan
This link is still working for me: http://www.share-online.biz/dl/O2I509KN3DD6
Tspeer is offline
post #6070 of 6080 Old 10-12-2015, 01:26 AM
Liked: 0
Hi Tspeer,
Thanks. I managed to upgrade the 875 with a Jig yesterday but sad enough
i still don't have any audio on the output so it was not the Firmware problem (i think).
(tried reset, got HDMI output, relais are "klikking" when i change inputs, no fused burned, no smelling,
no visual problems, checked cables).
Now i have no idea what else it can be.
Johan
aardbei is offline
post #6071 of 6080 Old 01-04-2016, 03:27 PM
buzzard31581's Avatar
Not responding to controls
My receiver has worked beautifully for the last several years. However, I had a recent issue where it would no longer accept control inputs either via the controls on the front panel or from the remote. It was still accepting and outputting sound though. The only way I could even get the thing to turn off was to unplug it. I thought maybe it just got too hot, but it wasn't any warmer than usual. I imagine it would probably turn itself off if that was the case anyway. After letting it sit for several hours unplugged just in case it needed some sort of reset, I plugged it back in and it defaults to the VCR/DVR channel. I can't change the input, increase/decrease the volume, or turn it off. I pushed all the buttons, nothing works. It's still not responding to any of the buttons on the control panel or the remote.
I'm guessing one of the boards has gone bad, but wanted to check here before I take the thing 200+ miles for service (it's the closest authorized repair center and happens to be on my way to the in-laws) and pay $50 only to find out they probably can't fix it. Anybody got any ideas on what might be wrong with it or where I can get parts for it myself if it's a simple fix?
Thanks in advance!
buzzard31581 is offline
post #6072 of 6080 Old 01-04-2016, 03:39 PM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
buzzard31581 I got rid of my Onkyo a long time ago, but here's what I would do if I were you. I'm no guru, but there's a few things I know enough to look for to fix some problems.
First, I'd open it up and examine all the cables I could between the different boards and see if they are connected properly. It might be that the ribbon cable connecting the front panel board to the system board has come loose. Might also be a power cable that has become disconnected somehow. And while you are in there dust it out real good.
Second, look for any bad capacitors. Google bad capacitors and look at the images there and check all the caps in your receiver. If you see any bad ones then at least that will get you some idea of what trouble you are in for. But if you don't know what you are doing with those then don't touch them, especial their contacts.
Third, look for any chips or boards that appear to be scorched or burnt in anyway. That could tell if you some component has died.
If you see any problems you can call the service center and perhaps get a conservative quote on what the repair would cost (assuming that it's only that part). You might also want to check on the fee to just have it checked out. I had a receiver knocked out by lightning around 2000 and it cost about $65 back then. It may not be worth even having checked considering the age of this receiver.
Keith Mickunas is offline
post #6073 of 6080 Old 05-14-2016, 01:37 AM
Liked: 0
Hi,my 875 uk model has an issue I could use help on.
The centre and surround speakers don't work sometimes but if I press down on the casing the amp clicks, as though you've just switch input channel, and the speakers work again. Does anyone have any experience with a similar issue, was fault located and fix discovered?
jimjim79 is offline
post #6074 of 6080 Old 05-24-2017, 01:30 AM
Quoted: 12 Post(s)
Liked: 0
Onkyo TX-SR875 Popping and Crackling Sound
2. GNDHD Ground
7. hdmi clk
9. vsp rst
11. vsp rxd/vsp scl
13. hdmi stb
15. hdmi sdi
thanks
Hi Sir I bought used Onkyo TX-SR875 from reputed seller. After few weeks my Onkyo gives popping/crackling sound from its Front Left and Surround right channel. I try to change speaker wires, speakers it self but not solve the issues. Its confirm that there was something wrong with the AVR. I try to upgrade its firmware but I stuck in updating..... logo. So i reset the AVR to factory defaults setting. Now after refusing to repair the AVR from Onkyo Service Center I bought DSP Board from Ebay.com I swapped the old DSP board with new one but It cause AVR completely mute. No sound from any channel but Video works flawlessly through HDMI. So I swapped old card again now I got sound only from Center, and front right channel with popping/crakling Bomb. Sir Please help me to solve the issue of my Onkyo TX-SR875.
Ashish_Solanki is offline
post #6075 of 6080 Old 05-26-2017, 11:11 AM
emtownsend's Avatar
You will have to research to see if this applies, but check this thread:
Onkyo acknowledges failed units and extending warrranties until 2018
emtownsend is offline
post #6076 of 6080 Old 08-23-2017, 03:52 AM
Serpeant's Avatar
I have an Onkyo 875 and was hoping to upgrade to a Dolby Atmos pre-amp.
If I get a Dolby Atmos pre-amp, can I then use the Onkyo 875 as the Power Amp to power the speakers but not do any of the processing?
Serpeant is offline
post #6077 of 6080 Old 08-23-2017, 04:56 AM
gurkey's Avatar
Quoted: 273 Post(s)
Liked: 166
Use multi-channel input, set them up for straight and connect those to the pre amp, then you got 7 channel power amps. Measurements should proceed as usual.
gurkey is offline
post #6078 of 6080 Old 09-17-2017, 06:34 AM
Liked: 0
Hi guys.
Tried setting up my 875 last night, it has been in storage for a while due to divorce. I plugged in my sky q and got sound but no picture. (HDMI) Display says no signal. I did a reset to defaults but I am at a loss. I'm pretty sure I'm missing something simple but without the on screen menu I'm at a bit of a loss.
In a perhaps unrelated problem my remote appears to be broken. It lights up and the red light flashes when I press buttons but it is not emitting IR when viewed through phone camera. I opened it and had a quick look but can't see anything obvious. Has anyone replaced the IR emitter on these? It looks easy enough but not sure where to source them or if I am again missing something simple?
Number 47 is offline
post #6079 of 6080 Old 09-17-2017, 08:50 AM
Liked: 0
Originally Posted by Number 47 View Post
Hi guys.
OK. Seems my diagnostic brain was malfunctioning last night possibly due to alcohol intake. A faulty HDMI cable has now made the ultimate sacrifice and I have video output.
Still have the remote control issue. Will take a look at it later but if anyone has any experience with these I'd be grateful.
post #6080 of 6080 Old 09-17-2017, 09:51 AM
Liked: 0
Seems I've had a battery leak, not sure this can be repaired. Pretty catastrophic.
<blockquote class="imgur-embed-pub" lang="en" data-id="a/c2S27"><a href="//imgur.com/c2S27"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
