Need some advice on the onkyo 875 - AVS Forum
post #1 of 5 Old 07-24-2007, 01:59 PM - Thread Starter
Islandborn's Avatar
HI...Here's the deal..I have a new Samsung FTP6374 and have a 7.1 speaker set up in my new house...I was planning on getting the Onkyo 875 to run all my devices(STB,dvd,etc) but am thinking for the money, should it be better to just get say the toshiba xa2 and output directly to the tv and get a good 7.1 receiver like a yamaha or pioneer to do the 7.1 sound via a digital coax or optical cable or would you guys advise to use the onkyo 875 for everything? I know my question is kind of vague but I am late for work so I hope I can get some good input..Later
Islandborn is offline
post #2 of 5 Old 07-24-2007, 02:21 PM
dildatonr's Avatar
I would pose this question in the 875 thread or the onkyo anticipation thread.
dildatonr is offline
post #3 of 5 Old 07-24-2007, 03:09 PM
millerwill's Avatar
Quoted: 63 Post(s)
Liked: 49
You'll miss hi def audio from the Tosh with digital optical/coax connections. If you want to get that, I think the Onkyo would be a good choice.
millerwill is offline
post #4 of 5 Old 07-25-2007, 09:54 AM - Thread Starter
Islandborn's Avatar
Hey thanks for th responses...So let me ask this...If I bought say the xa2 and went via hdmi straight to the tv....I would assume th picture quality would look amazing....But since I want 7.1 from my speakers, I would mute the tv speakers and just hook up a cable to my receiver say the 875...So not using an hdmi cable into the receiver would not yield HD audio? I would like to use my 7.1 speakers for all my applications....And would like to hear different comments on the best ways to impliment 7.1 with my set up...
post #5 of 5 Old 07-25-2007, 10:47 AM
PioManiac's Avatar
Liked: 41
High Def Audio should be sent via HDMI to your receiver, which will process the High Def audio and pass the HD Video signal through to your Display.
Digital/Optical only has enough bandwidth capablity for lossy compressed DD or DTS 5.1 audio tracks, not LPCM or TrueHD high def audio from HD DVD's.
HD DVD Player -> HDMI -> AVR -> HDMI -> Display
With the XA2, another option would be to use the multi channel analogue outputs for audio,but thats a lot more cables to route than a single HDMI.
My First Home Theater
...When a Kuro plasma still isnt enough, make your movie Experience Larger than Life with a Projector!
PioManiac is offline
