The "Official" Denon 4308ci Owners Thread - Page 166 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #4951 of 5232 Old 04-11-2012, 12:13 PM
raoshree's Avatar
Thank you that worked. I always thought that when i assign a source it should have a video input and audio input. that's not really the case
raoshree is offline
post #4952 of 5232 Old 04-27-2012, 01:32 PM
techjunky2's Avatar
Heeeeeeeelp please! Im about ready to throw this unit out the window! I have an ongoing issue when either watching a DVD or just TV, the "auto setup" screen will pop onto the screen at random. The only way i can get it to go away is by hitting return on the remote and cancelling speaker setup. This is driving me totally nuts! Im getting so frustrated. I have the latest firmware and have tried everything you can imagine yet this annoying problem keeps happening.....help!
-Just when you think you've caught up with technology, it passes you like you were standing still.-
techjunky2 is offline
post #4953 of 5232 Old 04-27-2012, 03:33 PM
dramsey68's Avatar
Tried searching through the forum but couldn't find anything on this.
Denon 4308 updated firmware, just added Apple TV and trying to get audio out to Zone 2. Took a little searching to find out, Zone 2 is analog only. No problem, went to Radio Shack and bought Optical to RCA coverter and great it works. However the volume is very low from this source only. All of the other sources output the volume at a much higher(normal) level. I am using Zone 2 volume control to adjust the volume.
Is the quality of the converter suspect, do I need HDMI to Analog converter, what am I missing?
Thank you for any help!
dramsey68 is offline
post #4954 of 5232 Old 04-27-2012, 04:44 PM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5503
Try resetting the microprocessor (p. 60 in Owner's manual) and if still no joy , it will likely need repair.
jdsmoothie is offline
post #4955 of 5232 Old 04-27-2012, 04:57 PM
jdsmoothie's Avatar
Liked: 5503
The 4308CI is one of a handful of AVRs that can also pass optical/digital coax PCM 2.0 to Zone 2. Give optical a try.
post #4956 of 5232 Old 04-27-2012, 05:21 PM
techjunky2's Avatar
No offense jdsmoothie but denon advises you to reset the microprocessor prior to doing a firmware update....so yes, tried that and the receiver still switches to auto setup at random times....its so frustrating! A receiver of this magnitude should not have issues like this....other than this one flaw, the 4308 performs flawlessly....to bad this problem occurs so often for me...its almost embarrassing having this occur on such an exceptional Home theater setup. :-(
post #4957 of 5232 Old 04-27-2012, 05:28 PM
jdsmoothie's Avatar
Liked: 5503
Why would I be offended? You didn't mention you already did a reset and this generally resolves most issues which is why I suggested it. Try inserting the setup mic into the mic jack a few times to clear out any dust.
post #4958 of 5232 Old 04-28-2012, 06:08 AM
techjunky2's Avatar
I posted about having this issue earlier and you actually gave me the same response about resetting the microprocessor. I didnt actually think you would take offense, but yes I already tried the resetting suggestion and it did nothing but make me redo all my settings. Taking the unit somewhere
for service seems a bit ridiculous, even if i did, where, and at what cost? Cant they make adjustments over the internet? It seems like im the only one whos had this malfunction. Not cool.
post #4959 of 5232 Old 04-28-2012, 06:16 AM
techjunky2's Avatar
Oh and dust in the hole for the setup mic? Are you serious or just teasing me? The actual setup process works fine, but then the unit keeps bringing up that setup screen over and over like i havent done my setup yet. I can use the setup lock feature to prevent the auto setup screen from popping on my screen, but everytime the unit tries to bring up the auto setup screen, up pops the setup locked message for five seconds or so. Still very annoying, but better than having to grab the remote and cancel the auto setup mode everytime it pops up. Ugh..... :-[
post #4960 of 5232 Old 04-28-2012, 06:52 AM
dramsey68's Avatar
Worked like a charm, thank you!
post #4961 of 5232 Old 04-29-2012, 11:57 AM
mckeand13's Avatar
I had it working up until now.
When I switch to the Net/USB source, the menu is basically frozen. I can't move up or down or select (ok or right) using either the remote or front panel.
I had favorites set up, but just can't get to them. The on screen gui works, but again, I can't navigate at all while I'm in that source.
Any ideas?
mckeand13 is offline
post #4962 of 5232 Old 06-18-2012, 07:53 AM
alan278's Avatar
Hi. Long-time owner of the 4308.
Suddenly there's no audio or video coming from it. Can't even see system-set on either 1080p monitor that have been hooked up to it forever. Unplug those and still no audio, even on analog CD input. Front panel lights/controls seem fine.
(seemed to happen when i was starting to play a dvd in my blu-ray player, the one monitor i had turned on said that "resolution is not compatible - should be 1920x1080" which it usually is coming from the 4308! i could still hear audio when i got that message, then i lost the audio. now no picture on either 1080p screen (one is a monitor, one a projector) and no audio either.)
Tried: unplug/re-plug and a micro-processor reset - still no A/V. Anything else I can try?
Repair or Replace needed? 3313CI reasonable replacement?
TIA
alan278 is offline
post #4963 of 5232 Old 06-18-2012, 08:03 AM
jdsmoothie's Avatar
Liked: 5503
Repair could cost as much as $500, especially if the HDMI board has gone out; however general rule of thumb is to buy new if repair costs are more than 50% of the new cost. So really depends on whether you need any new features offered in the modern AVR models. The successor to the 4308CI is the 4810CI which is now discontinued and being replaced by the new 4520CI in Sep. Although the 4308CI and the 33XX series feature the same version of MultEQ XT, you would be better served going to the 4311CI (also being replaced by the 4520CI) as it offers the more advanced version of XT32 and is the current successor to the 3808CI. If budget prevails and the 3312CI or 3313CI offer the features/inputs that you need, either would likely serve you well.
post #4964 of 5232 Old 06-18-2012, 11:46 AM
Hyrax's Avatar
Quoted: 88 Post(s)
Liked: 45
I'm wondering if I anyone has connected a pre/pro to the 4308CI via the "Ext. In" inputs. I'm not even sure this makes sense. I've got an external video processor, so all I want to to do is get the newer Audyssey features in current receivers. It seems silly to completely replace my 4308CI because there is really nothing else I want to upgrade on it.
Hyrax is offline
post #4965 of 5232 Old 06-18-2012, 11:52 AM
jdsmoothie's Avatar
Liked: 5503
post #4966 of 5232 Old 06-18-2012, 12:54 PM
Hyrax's Avatar
Quoted: 88 Post(s)
Liked: 45
I'm sorry that my question was not clear. The Pre/Pro would do the Audyssey processing, the 4308CI would just be an amplifier in this case.
Hyrax is offline
post #4967 of 5232 Old 06-18-2012, 01:42 PM
jdsmoothie's Avatar
Liked: 5503
Ah ... gotcha .. so you just want to get the Audyssey Dyn EQ and Dyn Volume features correct? There's a firmware upgrade for $100 that will get you those features ...
http://usa.denon.com/US/Support/Pages/upgrade.aspx
post #4968 of 5232 Old 06-18-2012, 01:55 PM
Hyrax's Avatar
Quoted: 88 Post(s)
Liked: 45
Brilliant! Does it actually work?
Hyrax is offline
post #4969 of 5232 Old 06-18-2012, 02:11 PM
jdsmoothie's Avatar
Liked: 5503
Although I have no personal experience with the install, it should work as well as it does on the current model AVRs; however, it will not include the newer "Audyssey Dynamic EQ Reference Level Offset" setting which can adjust the 0db reference setting to improve dialog from TV and music sources at volume levels below 0db. However, the same result can be achieved by adjusting the Source Level setting.
post #4970 of 5232 Old 06-18-2012, 02:28 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6500 Post(s)
Liked: 3608
I have a 4308 as my secondary AVR, and it has this upgrade. I can attest that it works as advertised, and is well worth the cost of the upgrade.
AustinJerry is online now
post #4971 of 5232 Old 06-18-2012, 03:27 PM
Hyrax's Avatar
Quoted: 88 Post(s)
Liked: 45
Thanks! I'm buying it now. Perhaps I will end up with this AVR for a decade after all smile.gif
Hyrax is offline
post #4972 of 5232 Old 06-30-2012, 02:56 PM
Harley Ghost's Avatar
I have a 4308ci and would like the wireless to connect with my music file on my HP computer. I have a Pavilion Slimline with an external 500 gig hard drive that all my music is on.
Has anyone tried, or is it even possible to get the 4308 to see and play my iTunes files that are all assembled, or should I be looking at doing all of the music collections over again and put them into Microsoft Media?
Is there something that is better and easier? Heard about Twonky Suite, but still do not know to much about this one yet.
Harley Ghost is offline
post #4973 of 5232 Old 06-30-2012, 03:25 PM
jdsmoothie's Avatar
Liked: 5503
For iTunes files, try connecting an Apple TV via HDMI to the 4308 and use Airplay to stream the files from the HP to the ATV.
post #4974 of 5232 Old 06-30-2012, 06:29 PM
Thanks, right now that seems like the easiest and most straight forward way to do this.
You know you spend so much time getting all of your playlists set, and then the thought of having to do that over again, just makes you shiver!! I have around 350 gigs of music, iTunes says around 54,000 songs, so doing this over again, will really suck.
Again, Thanks for the input, I will give it a shot and let you know how it goes.
Hope everyone has a GREAT July 4th Holiday!!
post #4975 of 5232 Old 07-21-2012, 05:06 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
Greetings. I am a newcomer to this thread, having recently inherited an AVR-4308CI. I moved into a house where the owner (purposely) left behind a roomful of A/V gear, and the 4308CI is one of those items. So I'm exploring its capabilities.
I updated the firmware to the most recent and then paid $100 for the further upgrade to Audyssey Dynamic EQ. I had previously used DEQ to good advantage on my Marantz AV7005 pre/pro in my old house.
Dynamic EQ on the Denon sounds awful! It boosts bass way too much, making human voices boomy and chesty. Dialog from center channel is less intelligible than without DEQ. Overall, the Audyssey XT implementation seems much inferior to that on the somewhat newer Marantz. The Denon system is using 7.1 Atlantic Technology in-wall speakers, also left by the previous owner and new to me.
My question: have others noticed adverse effects from Dynamic EQ on the 4308CI? Or is the problem my room & speakers?
Thanks for any words of wisdom.
bweissman is offline
post #4976 of 5232 Old 07-21-2012, 05:34 PM
Liked: 3608
I have a 4308, now in my bedroom. The DEQ sounds fine to my, comparable to my 4311 in my primary listening area. Have you re-run the Audyssey calibration?
post #4977 of 5232 Old 07-21-2012, 06:47 PM
jdsmoothie's Avatar
Liked: 5503
More likely the room dynamics and the speaker positioning. Although the version of XT and Dyn EQ are exactly the same as on the 7005, the XX09 and newer models (to include the 7005) feature a "Reference Level Offset" setting that reduces the bass boost at lower reference levels which is especially helpful to improve the center channel dialog for TV and music sources. You can do something similar by lowering the Source Level setting by -10db and then increasing the master volume by +10db. As this is a used AVR, you should reset the microprocessor (p. 60 OM) and do the AUTO SETUP procedure again.
bweissman likes this.
post #4978 of 5232 Old 08-01-2012, 03:08 PM
bonzichrille's Avatar
Got a question for you other denon 4308 owners!
I recently purshased this unit in my local second hand market as an upgrade to my current denon 3312. I have pretty low impedence speakers and the 4308 certainly sounded much better than the 3312. The center channel really opened up and I was delited with this buy.
However, I soon discovered this odd thing. You see, I have 2 sources, one digital tv box and the mediaplayer Boxee box. Both have worked great connected through HDMI to the 3312. But sadly, through the 4308, specifically with boxee, there is now quite often a lipsync problem with many movies. This can ofcourse be adjusted using the audio delay option, but it is quite boring and time consuming to do so. In addition, the amount of "adjustment" needed is different from movie to movie.
If I switch back to my denon 3312 and connect the boxee box (again using only HDMI cable) the lipsync issues totally dissapear. Everything is perfect. The setup is the same in all other aspects.
Obviosly, the more modern denon 3312 is doing something to the HDMI-signal which makes it have perfect sync. However, this is somehow lacking on the denon 4308 despite having turned on "auto lipsync" option inside its menus.
I have installed the latest firmware. Also turned off all sorts of scaling of the picture but still problems. With my digital tv box there is much less pronounced, but still got this feeling that lipsync is just slighly off (1-3 ms perhaps). Adjusting it is difficult since I dont seem to get in perfect sync (its like it is 2.38 ms or something). Reinstalling the 3312 and this feeling totally dissapear, voices are just spot on.
Is this a known issue with the denon 4308? Perhaps it has something to do with my TV (sony nx720) not properlly communicating the audio delay needed to the 4308? Are there any other Boxee box owners here with a similar eperience?
Anyway, any input would be appreciated.
bonzichrille is offline
post #4979 of 5232 Old 08-01-2012, 03:50 PM
Quoted: 303 Post(s)
Liked: 269
I have 4308CI since it first came out and have the upgrade. One thing I have learned with the Audyessy and the 4308 is the sub EQ always seems off a tad I always have to tweak sub volume. For me because of the room I usually have to pump up the sub 3-4db. Also I find while most people concentrate on the highs and refections and such I find sub placement to be far more critical. I actually had to move my sob from one side of the room to the other to get really good lows.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Klipsch RP-280F / RC-62ii / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #4980 of 5232 Old 08-01-2012, 04:06 PM
Hyrax's Avatar
Quoted: 88 Post(s)
Liked: 45
My only thought is that HDMI includes an auto-sync ability. Perhaps the problem has always been in those files and the newer Denon does a better job of correcting it (or the older Denon didn't have the ability). I've got a Dune player connected to my 4308 and I notice that MP4 files always tend to be more likely to have an audio delay than MKV or M2TS files. Note that I created all of my MP4 files from TV shows and am looking for a reason a high percent of them have audio delay issues. I recently did a batch convert on my MP4 files to create MKV files and the problems have mostly gone away.
Hyrax is offline
Denon Avr 4308ci Receiver , Denon
