The "Official" Denon 4308ci Owners Thread - Page 172 - AVS | Home Theater Discussions And Reviews
post #5131 of 5144 Old 02-03-2015, 06:53 AM
mckeand13's Avatar
Manual tuning HD Radio?
I just moved and haven't located my Harmony One yet.
I was trying to figure out how to manually tune in an HD Radio station. It seems as though you can only move through presets on the receiver itself, and no manual tuning is available. It can be done from the remote only.
Can anyone confirm? That seems ridiculous if that's true.
mckeand13 is offline
post #5132 of 5144 Old 02-03-2015, 07:12 AM
DenonLover's Avatar
Quoted: 89 Post(s)
Liked: 32
We have done this by moving over to Apple TV and using the HDMI port. It sounds amazing and much better quality and interface. The only issue with my 4308 now is the triggers for the amp. When I turn on the amp both trigger power my two external Emotiva amps but for some reason when I select DVD, its the only HDMI setting that does not power one of my external amps. When I swithed the cable it would not power up the other amp so I have localized it to the DVD setting only. I am out of HDMI slots so I have the issue with whatever item is now plugged into that DVD setting! I guess if this is the only issue with my amp after this many years that's not too bad.
DenonLover is offline
post #5133 of 5144 Old 02-23-2015, 07:32 AM
ROSSO Z's Avatar
Thumbs down What causes popping sound when playing DVD?
I was playing a concert DVD and heard this loud intermittent abrupt popping sound.
Ideas?
ROSSO Z is offline
post #5134 of 5144 Old 02-23-2015, 07:47 AM
ROSSO Z's Avatar
Loud popping sound from DVD???
OOPS! duplicate....
ROSSO Z is offline
post #5135 of 5144 Old 02-23-2015, 05:15 PM
DenonLover's Avatar
Quoted: 89 Post(s)
Liked: 32
My unit recently stopped triggering one of the amps and I isolated it to one of the two triggers. Then my unit has been powering down. The first power down was about 30 days ago and it has slowly gotten worse every day and now it will power down 10 times while the movie is playing. I think its time for a new unit.
post #5136 of 5144 Old 02-23-2015, 05:26 PM
bweissman's Avatar
Quoted: 76 Post(s)
Liked: 43
^ Save your settings and reset the microprocessor. No guarantees, but it's worth a try.
DenonLover likes this.
OPPO BDP-103, Comcast DVR, Sony FMP-X1 4K server
Marantz AV8801 pre/pro, Yamaha MX-A5000 amp
Sony VPL-VW600ES projector, Stewart StudioTek130 103" diag screen
7 Thiel speakers (3 SCS4, 2 PowerPoint, 2 PowerPlane), 2 JL Audio E110 subs
Harmony Ultimate remote
bweissman is offline
post #5137 of 5144 Old 02-23-2015, 05:32 PM
DenonLover's Avatar
Quoted: 89 Post(s)
Liked: 32
Not sure how to save my setting but I will download the manual and check it out. As far as resetting the microprocessor, I have unfortunately had to do that a few times.
post #5138 of 5144 Old 02-23-2015, 05:42 PM
bweissman's Avatar
Quoted: 76 Post(s)
Liked: 43
Save settings via the web interface Setup menu.
post #5139 of 5144 Old 02-23-2015, 08:34 PM
DenonLover's Avatar
Quoted: 89 Post(s)
Liked: 32
So far so good, fingers crossed it keeps working so I do not end up needing to buy the Marantz 7702.
post #5140 of 5144 Old Yesterday, 05:03 PM
Docj04's Avatar
Ok guys, New and frustrating issue.
Lately, My 4308ci won't play back hi def audio formats from blurays over my PS3. Two examples are that:
on the Jewel BD concert which has DTS-MA, the display on the 4308, (and sound quality) only indicate "DTS Surround"
Nine inch nails beside you in time has Dolby true HD, but will only playback in Dolby digital. The same holds true with polar express and it's soundtrack.
In both examples, the display will read "multi channel in", up until the concert actually plays--at which point it "dumbs down" to the inferior format.
Oddly, Pink Floyd dark side of the moon SACD, and the Pentattone SACD playback in HI def (multi channel in) format...just not my bluray discs.
Can't determine if this is a PS3 issue, or with the 4308ci. HELP
Docj04 is offline
post #5141 of 5144 Old Yesterday, 06:25 PM
Docj04's Avatar
Well--borrowed my neighbors Samsung BD player, and the lossless formats play just fine. Sooo, apparently its my gen 1 PS3....?
Docj04 is offline
post #5142 of 5144 Unread Today, 02:47 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3361 Post(s)
Liked: 2081
Correct. The "fat" PS3 cannot bitstream HD codecs, rather you must set the PS3 to LPCM instead to play BDs with HD codecs.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #5143 of 5144 Unread Today, 05:34 AM
AVS Club Gold
longbow's Avatar
JD a question.
My 4308 has worked perfectly with a Wii plugged into the Component 1 and Stereo in using the HDP/iPod connection. I run an HDMI out to the TV. I just had it in for a repair and upon return I cannot get video now from the Wii. All the HDMI inputs are fine. I get sound just no video. When I am on the HDP setting I get a blank TV and sound from the speakers.
I am probably missing something simple. The settings I had were reset to factory when I got it back.
any ideas?
Eric
EricN
"You are in a maze of twisty passages, all alike"
HT: Denon 4311CI, Denon DVD-5900, M&K S-150's LCR & ss-150's SL & SR, SVS PB12+, Oppo-BDP-83, Sony Cineza LCD, Stewart StudioTek 130 92"
2 Ch: MacMini,W4S DAC2 DSDse,VPI Scout 1.1&Dynavector 10X5,Cary SLI-80&Vandersteen 2Ce Signatures II's
longbow is online now
post #5144 of 5144 Unread Today, 05:54 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2081
Ensure "i/p Scaler" is set to "A to H" (p. 30 Owner's manual); "Video Convert" = ON for that source (p. 39) as well as ensuring the correct Component input is assigned (p. 40).
Denon Avr 4308ci Receiver , Denon
