The "Official" Denon 4308ci Owners Thread - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #5221 of 5244 Old 12-20-2016, 01:25 AM
jdsmoothie's Avatar
Quoted: 15072 Post(s)
Liked: 7274
Originally Posted by caldirun View Post
You misunderstood, I want to power passive transducers not amps
No misunderstanding ... the AVR is not designed to power "passive transducers", rather you should be using an external "buttkicker" amp.
jdsmoothie is offline
post #5222 of 5244 Old 12-20-2016, 01:32 AM
jdsmoothie's Avatar
Liked: 7274
Originally Posted by bweissman View Post
Is there any way to disable the annoying "Muting: ON" on-screen display which won't go away while the receiver is muted?
Although owners have been complaining about this for years, unfortunately no, there is not.
post #5223 of 5244 Old 12-20-2016, 08:17 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
No sure exactly why yet, cause I have never seen it on, but my 4308 doesn't have that displayed (ie. muting on) while the unit is in "mute". The main power button flashes, though during mute. Onscreen volume and on screen displays work fine. The unit feeds a samsung tv via hdmi. Not sure which option turns it off though. Mute is set at -20db which might be the key as opposed to "full mute". :-)
budwich is offline
post #5224 of 5244 Old 12-24-2016, 12:11 PM
caldirun's Avatar
More info, even if 7.1 was available with speakers B, zones 2, 3 and 4 will not play digital inputs.
Best way to do it is use 2 splitters into SubW PreOut, 1 for sub and 2 for R/L input to another amp (any analog input), I used a Denon 3802 driving the transducers via Front Right and Front Left, feels very impressive.
Then you have the 2 Denon amps problem!
The 3802 has only the default remote codes, the 4308 has a choice of codes but the user manual is misleading, the only way to enter the code is with the EL screen showing Amp and all the soft buttons showing on the lower screen, the transmisson display flashes twice then it works.
caldirun is offline
post #5225 of 5244 Old 01-21-2017, 02:36 PM
amred's Avatar
When listening to a internet radio station then switching to another internet radio station the volume sometimes changes dramatically. Is there a way to set the volume level in memory for each preset? I see it is possible using "Quick Select" but that is only three presets.
amred is offline
post #5226 of 5244 Old 01-30-2017, 12:17 PM
amjosh's Avatar
Is it worth buying this for $250?
amjosh is offline
post #5227 of 5244 Old 01-31-2017, 01:03 AM
jdsmoothie's Avatar
Liked: 7274
By source (ie. Internet Radio) yes, but not individual station preset.
If you have not downloaded the Audyssey update yet, refer to --> https://usa.denon.com/us/downloads/productupdates and then use Dynamic Volume to help normalize the volume regardless of the source.
post #5228 of 5244 Old 01-31-2017, 01:07 AM
jdsmoothie's Avatar
Liked: 7274
Depends on the use case and whether or not the $250 would be better spent on a more current model using the better version of Audyssey MultEQ XT32 and/or 4k/Atmos/DTS:X capable.
post #5229 of 5244 Old 01-31-2017, 07:42 AM
amjosh's Avatar
1080p is good enough for me as well as 5.1. What I really care about it sound quality. Would the new $500 receiver match the audio quality of this beast? I have Polk LSiM 703 bookshelf speakers.
amjosh is offline
post #5230 of 5244 Old 01-31-2017, 07:48 AM
jdsmoothie's Avatar
Liked: 7274
No, rather you'd have to go up another level.
post #5231 of 5244 Old 02-08-2017, 06:19 AM
Liked: 0
AVR 4308ci - no signal
Everything was fine last night and when I woke up this morning, I turned on the TV and get a Check Signal Cable. I have sound but no video.
When I check the "sources" on my TV, with the HDMI cable plugged into HDMI 4, that source disappears. If I unplug the cable, the source appears. I changed the HDMI cable, thinking that was the issue, but no go.
This is a first for me - I have no idea what happened overnight :-(
Does anyone have any ideas that may point me in the right direction?
many thanks,
paige
tekgirl is offline
post #5232 of 5244 Old 02-09-2017, 05:39 AM
jdsmoothie's Avatar
Liked: 7274
many thanks,
paige
In some cases, the issue can present when there is an update to the cable box. Otherwise, HDMI handshake issues can often times be mitigated by powering the components in a specific order, most often: TV, pause 5 seconds, AVR, pause 5 seconds, cable box. The work around would be to connect the cable box (HDMI) --> TV with cable box (optical) --> AVR.
post #5233 of 5244 Old 02-11-2017, 11:26 AM
amred's Avatar
Can anyone suggest a android app that lets me choose the presets? A1,B2 etc?
amred is offline
post #5234 of 5244 Old 02-12-2017, 11:26 AM
amred's Avatar
To answer my own question:
AVR-Remote for Denon by Andreas Pillath
this app is better than the one from Denon I use on my laptop. I wish Andreas made one for windows.
amred is offline
post #5235 of 5244 Old 07-25-2017, 08:28 PM
slidey's Avatar
Question for folks here..my 4308 is still working great. Upgrading to a 4K tv soon and would like to keep the 4308 on audio duty. I will have multiple 4K sources which don't have dual HDMI output, so they'll go straight to the TV. Is there any good way to get full fidelity audio streams back to the avr?
I don't want to do optical from the TV since it would be DD5.1 at best, probably 2.0. if I recall there is no ARC on the 4308 so that's out. I think all that leaves me with is an HDMI matrix, but I've had lots of hdcp/handshake problems with those (when I cared about 3D briefly) and don't want something too fiddly.
Anything I'm missing? It may be time to upgrade but want to eliminate options first...
Thanks! Glad to see a 4308 community still exists, it has been a fantastic avr all these years.
Sent from my LG-H918 using Tapatalk
slidey is offline
post #5236 of 5244 Old 07-25-2017, 09:13 PM
Hyrax's Avatar
Quoted: 112 Post(s)
Liked: 50
I'm using a DVDO Edge for what exactly what you're describing. The problem with the Edge is that it isn't 4K(it handles 3D great).
Someone can correct me, but I don't think streamed audio is ever uncompressed, so you could use the optical audio out from the TV to the 4308 when streaming. I believe think the only source where you need to split HDMI audio (to the 4308) and 4K video (to the TV) is disks. Therefore, what I'd do if I were you I'd is get a 4K blu-ray player that has dual outputs (such as the Oppo 203). The Oppo probably streams things like Netflix & Amazon, but I prefer using a NVidia Shield TV for streaming (and gaming).
slidey likes this.
Hyrax is offline
post #5237 of 5244 Old 07-26-2017, 07:54 AM
Hyrax's Avatar
Quoted: 112 Post(s)
Liked: 50
Note: I've discovered that the Oppo 203 does not support streaming applications, but you can plug a Roku or other streaming device into its HDMI 2.0 input. Alas, the Oppo is a pretty expensive option.
Hyrax is offline
post #5238 of 5244 Old 08-01-2017, 09:02 AM
Liked: 0
I have a Denon 4308ci and my question is how do you hook up a Bluetooth transmitter for wireless headphones? I would like to use the best quality signal as I can even though I'm using Bluetooth. Could I hook up Optical instead of just a headphone jack? I have seen a lot of Bluetooth transmitter / receivers but I don't understand how to hook them up and which one to buy can someone please point me in the right direction and shoot me some links? I have the cowin e7 headphones
These are the headphones I have
Sent from my SM-G920P using Tapatalk
knever3 is offline
post #5239 of 5244 Old 08-01-2017, 09:10 AM
jdsmoothie's Avatar
Liked: 7274
There are numerous Bluetooth transmitters on the market which generally have a 3.5mm cable so you would need to also purchase a 3.5mm to RCA converter cable and then connect that to the Zone 2 or 3 pre-outs on the AVR and pass the audio to either Zone 2 or 3.
post #5240 of 5244 Old 08-01-2017, 04:10 PM
Liked: 0
So in that case would I have to switch to Zone 2 or Zone 3 on the remote? Would it mute the audio so the headphones alone would have the sound? Is there any way that I could use Optical or digital output instead of analog RCA's?
knever3 is offline
post #5241 of 5244 Old 08-01-2017, 05:37 PM
slidey's Avatar
Shield TV will be my streamer. It can pass through DTS MA via something like Plex..I wonder if that would work through the Oppo's input. Great option thanks for sharing.
slidey is offline
post #5242 of 5244 Old 08-02-2017, 02:05 AM
jdsmoothie's Avatar
Liked: 7274
1. Yes.
2. If you mean mute the main zone audio, no. You would need to press the Mute button to do that.
3. Yes. If the source is input via optical/digital coax, then you could use an optical out.
post #5243 of 5244 Old 08-02-2017, 07:17 AM
Liked: 0
1. Yes.
Could you recommend a couple of high quality transmitters then? There are so many I don't know where to start. I guess I would like one with digital and analog for flexibility sake. I hope they're in the $50 range.
knever3 is offline
post #5244 of 5244 Old 08-02-2017, 08:30 AM
jdsmoothie's Avatar
Liked: 7274
Sorry, none to recommend although Google and Amazon reviews should provide some good info for you.
Denon Avr 4308ci Receiver , Denon
