Onkyo PR-SC885P Preamp thread - Page 186 - AVS Forum | Home Theater Discussions And Reviews
post #5551 of 5579 Old 02-03-2012, 07:23 PM
jsnable's Avatar
Originally Posted by AVB View Post
Check the measurements of the current model. If the height is the same I'm willing to bet the handles are the same. Also see if Onkyo has any for the consumer version - the DTC9.8 or 9.9. Did you get yours used because the 885 came with handles in the box, or at least mine did.
Also make sure they are not still in the box - mine were in a box that looked a lot like the bottom of the main box. If not, one option could be the Middle Atlantic custom shelf - it may not be any more expensive than buying the actual Onkyo part, plus you can use the shelf part for future components while just ordering a new face plate. Disclaimer - I have these shelves for other components but haven't seen the one for the 885.
Jay
jsnable is offline
post #5552 of 5579 Old 02-29-2012, 09:12 AM
CupCak3's Avatar
Has anyone got a real quote or sent their unit in for HDMI output failure? If so, how much was it?
CupCak3 is offline
post #5553 of 5579 Old 03-08-2012, 11:34 AM
mberk's Avatar
I spoke with the authorized repair in Northern New Jersey. If the problem is the bad capacitors on the video board which is the case most of the time, it should run between $175 and $200. They are very familiar with the problem and said that very few 885s were affected compared to the receivers from that era. There is a thread on the problem and how to fix it yourself if you are inclined to try your own soldering.
http://www.avsforum.com/avs-vb/showthread.php?t=1246078
mberk is offline
post #5554 of 5579 Old 04-28-2012, 11:57 AM
shadowgoon's Avatar
I am finally delving into the Home Theatre market, and deciding to go with separates.
This processor is the only thing within my budget to catch my eye from all angles, and after reading the write up on page 3 my mind is set. I plan on outputting through the unbalanced pre-outs to a Carver AV705X THX powered amp for now until I can pony up the cash for a better powered amp with XLR inputs and way better speakers.
My question is this, to all current/past 885 owners:
I have two seperate A/V systems that I use for digital playback, an HTPC for watching TV/Movies and a stand alone music server (custom built). Both machines make use of the XBMC software for playback.
The HTPC is fairly standard as such I have no questions there. With my music server however, I output from the motherboard's on-board SP/DIF output via WASAPI to a Fiio D3 DAC and into a 2 channel analogue amp (presently).
If I made the move to this processor, would it be possible to still output the video via HDMI to my TV and use an analogue input for the 2 channel audio? Or is the built in DAC in this processor good enough to trump the Fiio (which is very neutral) and output the audio along with the video signal via HDMI?
As for the music I listen to, it's mostly 60-80's classic rock, 70-90's hard rock and metal, 80's new wave, 60-90's punk, newer alternative and electronic (House, dub-step, DnB).
Current main speakers are a pair of PSB Alpha B's.
Thanks in advance!
Gabrial
shadowgoon is offline
post #5555 of 5579 Old 05-02-2012, 08:18 AM
ClarkeBar's Avatar
Quoted: 25 Post(s)
Liked: 25
Hello Gabrial,
I am unfamiliar with the particular DAC you mentioned but I would say you should try both pathways and listen for yourself. The Analog out of the 885 is generally not as well thought of as the digital side of things but I have no issues using either. I have no high end analog needs and the SQ difference for me is somewhat difficult to distinguish after I turn off Audyssey on the digi side. Perhaps a slight output level increase and very subtle detail changes, mostly for the better, with analog. But the loss of Audyssey in my untreated room makes the digital pathway the only one for me. I'm sure I'm not alone in this. If you are mainly using headphones your situation may be very different.
Paul
ClarkeBar is offline
post #5556 of 5579 Old 05-02-2012, 08:28 AM
rtart's Avatar
Quoted: 34 Post(s)
Liked: 63
^^^^ What he said.
I owned the 885 for a couple years and was impressed enough to upgrade to an 886 which I still own. I use analog ins for a Sony PS-X75 turntable and have used the XLR balanced inputs for a phono amp in the past. No real complaints either way.
I have a WHS based server that I access via a PS3 for music files in my HT. This gives me HDMI connectivity from the PS3 so SPDIF is not needed.
All of this aside, I'd hook up both options and listen for a while. Everyone's ears are different and what sounds good to yours is all that matters.
I'm finding that I'm smarter than I thought, but dumber than I need to be.
PSN ID: rtart, alt Ginsuyou2
rtart is offline
post #5557 of 5579 Old 05-10-2012, 12:46 PM
Quoted: 52 Post(s)
I am a happy owner of a PR-SC885P. I recently moved to an area with poor radio reception. So now while I hadn't really cared about the lack of ability of the 885 to get internet radio before, I now wish I had it. The 886 didn't add internet radio, did it? If not, any suggestions for an add-on?
Thos.
Home theater:
Samsung UN65JS850DFXZA
Onkyo TX-RZ900 Receiver
Kinergetics / Chiro C300, C500 Amplifiers
Mirage 3si, Mcsi, OM-R2, BPSS-210
Tivo Roamio, AppleTV, Playstation 4, Harmony 900, Oppo BDP-103D
thos19 is offline
post #5558 of 5579 Old 05-10-2012, 03:03 PM
Kal Rubinson's Avatar
Quoted: 572 Post(s)
Liked: 405
SqueezeBox Touch
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #5559 of 5579 Old 06-26-2012, 01:57 AM
porrick's Avatar
hey - saw yer post re: hdmi board goin south - were u referring to somethin that afflicted a buncha devices? my vid board just died - wondering if i can replace it myself - tx 4 any help!
porrick is offline
post #5560 of 5579 Old 08-13-2012, 09:02 AM
Samaritano's Avatar
Has anyboby here attempted the HDMI daughterboard repair on the 885? My 885 was showing the symptoms and finally is out for good.
Edgar
Samaritano is offline
post #5561 of 5579 Old 08-23-2012, 11:42 AM
islandview's Avatar
Mine is also deteriorating (rapidly). It started with slight green veining around moving/still images and has become progressively worse to the point there are now total colour blotches and freezing. Would be interested to know if the fix is suitable for this model.
If all else fails ......... read the instructions.
islandview is offline
post #5562 of 5579 Old 08-23-2012, 12:37 PM
Bill Mac's Avatar
Quoted: 1112 Post(s)
Liked: 1184
I'm curious if you can bypass the 885 for video and just use the HDMI inputs for audio? Or is audio effected by HDMI board failing as well? If audio is not effected you could run your video sources directly to your display. Certainly not a fix but a possible option till you get the 885 repaired or replaced.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk 1801-TLs, Salk 1801b center, ADS 300C (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #5563 of 5579 Old 08-29-2012, 05:37 PM
Samaritano's Avatar
Well I went ahead and tried that DIY fix for the HDMI board on my SC885 and so far it is working. I had to replace 13 100uf and place 1uf 50V Cer Caps over the 6 regulators. Hopefully it stays that way.
Edgar
post #5564 of 5579 Old 11-17-2012, 11:44 AM
Gunnar's Avatar
Hi! I`m able to remote control the PR-SC885 using IP and Irule app on a Galaxy tab, but Im not able to get feedback. It would be nice to have feedback for at least the volume setting, since the equipment is not located in the HT-room.
I use the setup in Irule Builder for Onkyo/Integra main zone. It isn`t specifically for the PR-SC885, so I can`t be sure the PR-SC885 really gives feedback? But all the commands that I have tried for control works without modification.
Gunnar is offline
post #5565 of 5579 Old 11-17-2012, 11:54 PM
coolrda's Avatar
Quoted: 679 Post(s)
Liked: 509
It does. I assume you have the the version of iRule that allows component feedback. Mine display current surround mode, volume, mute.
coolrda is offline
post #5566 of 5579 Old 11-22-2012, 03:40 PM
Gunnar's Avatar
Yes, I have the $99 version (Pro?). I use a Galaxy S 5.0 (android 2.3.5) as handset. Can this be the problem? PLEASE tell me what you did to get it working?
What handset do you use? Which Irule device and feedback device did you use? The reason I doubt that my Onkyo is sending feedback is that I logged the IP-traffic with Docklight, but I might have set it up wrong..
Gunnar is offline
post #5567 of 5579 Old 11-22-2012, 11:09 PM
Guttboy's Avatar
Hi Folks,
Just an update...my 885 has bit the dust. Sadly so as I really loved the unit. For some odd reason I get extremely low levels from the surrounds. Swapped cables, rerouted through different speakers, even went as far as changing the amp out...no dice. Onkyo was mildly helpful and stated it needed to be returned.
Unfortunate to say the least as I loved the unit.
Sad thing is that EVERYTHING works aside from the surrounds and LFE channels. I may just have to relegate this to the garage and use an old amp to power the speakers........
If anyone has any suggestions, aside from sending it in for return, I am all ears.......may have to get a new unit for my home theater. Currently using a 15 year old Yamaha that is doing well but alas no HDMI on it....sounds great but would love the HDMI options.
Cheers,
Guttboy is offline
post #5568 of 5579 Old 07-30-2013, 10:45 AM
Quoted: 52 Post(s)
My PR-SC885P has developed the same issues with the HDMI board as others have written in the last pages of this thread. Freezing video, green lines across the frozen screen, and only audio apparently working. If I could have it fixed for the aforementioned $175-$200, I think that would be worth it.
If anyone went the repair route and could relate their steps taken, it would be very much appreciated. Even a phone number (rather than the e-mail address I found) could be very useful.
Home theater:
thos19 is offline
post #5569 of 5579 Old 07-30-2013, 02:34 PM
muadib's Avatar
muadib is offline
post #5570 of 5579 Old 08-22-2013, 04:11 PM
jorsan's Avatar
Hi, need some help please: under PCM what audio option should I choose to have 7.1 channels output ? (direct, pure aduio ,... other?..... I can't find a multichannel option or somehting like that). I have tried several and all that Im getting is stereo. I have Jriver installe din my HTPC and want that all the conversion of my audio surround takes place within the program and not in the Onkyo. thanks in advance.
jorsan is online now
post #5571 of 5579 Old 08-27-2013, 10:43 AM
jorsan's Avatar
no one?
post #5572 of 5579 Old 10-20-2014, 09:49 AM
Dark Vader's Avatar
I guess I'm re-re-resurrecting this old thread. My 885 is still running although the side surrounds are not outputting audio. I'm curious if anyone knows what the issue is in regards to this.
Also, strangely, I was having the HDMI board issue as of a couple of years ago, but it seems to have resolved itself (???). I haven't had a "failure" in quite awhile. Don't know why I had it before and don't have it now but everything seems to work fine on the unit aside from the side surrounds.
Still enjoying this unit but we will be moving in a month and I'm considering leaving all the HT equipment with the house (for some $$) since it's all installed in racks. If the fix to the surrounds is simple, I may look into fixing it. Or, I may take down the side speakers and be done with it.
Mike
SONY 52" KDL-52XBR4 -- ONKYO PRO PR-SC885P Preamp
EMOTIVA MPS-2 -- DirecTv HR20
SONY BDP S3100 -- ATHENA AS F2-1 LCR
KLIPSCH RS-42 Surrounds -- VELODYNE 15" DLS-5000R Sub
FURMAN M5500-EX Power Conditioner -- HARMONY 890 Pro
Dark Vader is offline
post #5573 of 5579 Old 02-12-2015, 12:42 PM
Guttboy's Avatar
Mike
Sad my other rooms 885 died.......wont put out sound at all......
Repair estimates?
Guttboy is offline
post #5574 of 5579 Old 03-05-2015, 08:46 AM
Mfusick's Avatar
Quoted: 602 Post(s)
Liked: 2588
If one or two HDMI is busted how easy or expensive is this fix?
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #5575 of 5579 Old 09-08-2015, 05:18 PM
jorsan's Avatar
Need some help: I have my Onkyo connected to my projector and my TV. what I need is to pass the audio directly to my TV and want the Onkyo to process the audio when my projector is in use. Any idea of how to configure that? thanks in advance
post #5576 of 5579 Old 10-25-2015, 06:50 PM
mwaarna's Avatar
Anyone one run into issues setting up a AVR or Pre-amp to be controlled by the Xbox One Kinect?
I just got a kinect this weekend.
It recognizes my samsung tv, but my older Onkyo PR-SC885 pre-amp it for some reason cannot control.
It lets me search for the unit by model number, but does not allow me to test it.
I tried searching for the remote control with no luck as well. The model number on the remote shows RC-690M, which apparently was replaced by ONKYO RC632M.
Any trouble shooting guides?
Would love to be able to have the Xbox Kinect turn everything on and off.
Last edited by mwaarna; 10-26-2015 at 07:26 AM. Reason: Update with better details
mwaarna is offline
post #5577 of 5579 Old 01-25-2016, 07:54 AM
timfrommass's Avatar
Bringing this back from the dead. Still super happy with this unit. I haven't changed any equipment in years but I'm thinking of upgrading my projector. Will this processor pass through a 3D signal? If not is there any way around that?
timfrommass is offline
post #5578 of 5579 Old 01-25-2016, 07:56 AM
Mfusick's Avatar
Quoted: 602 Post(s)
Liked: 2588
You could always hit a splitter first and hit both projector and AVR with the outputs.. but I never tried that.
post #5579 of 5579 Old 02-15-2016, 02:33 PM
jorsan's Avatar
Hi, is possible that someone can post the HEX code to switch between HDMI audio output on and off? thanks in advance
