Onkyo PR-SC885P Preamp thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
post #1801 of 5590 Old 03-09-2008, 08:37 AM
Bill Mac's Avatar
Quoted: 1269 Post(s)
Liked: 1446
Originally Posted by Artcon View Post
I have upgraded from an Outlaw 950 to the Onkyo 885 pre and am finding a large decrease in volume from the Onkyo in to my outlaw 7700 amplifier.
Bob,
Did you set all your channel levels at 75db using a SPL meter?
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #1802 of 5590 Old 03-09-2008, 08:47 AM
matnick2127's Avatar
Originally Posted by Gary Murrell View Post
waaaaaay to few details for us to make a nice choice or give advice on a amp
-Gary
I guess you need what speakers I have. Ok here goes:
L/R Front - Klipsch RVX-54
Center - Klipsch RC-62
Surrounds - Klipsch RS-52
Back Surrounds - Klipsch RSX-5
Sub - RW-12d
Any other information you require?
-Matnick
matnick2127 is offline
post #1803 of 5590 Old 03-09-2008, 09:18 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Sub - RW-12d
-Matnick
Room size? How loud to you like to listen? Budget? Etc.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #1804 of 5590 Old 03-09-2008, 09:49 AM
Craig
Oh ok
Room size: 26' X 14'
I like to listen fairly loud. Like to listen to clean sound.
Budget: Approx $1000.
What do you think of Rotel? Is that a good make? Want for a 7.1 system. Should I get one 5 channel and another 2 channel?
-Matnick
post #1805 of 5590 Old 03-09-2008, 10:11 AM
bayareakirk's Avatar
I've had the 885 for a couple of weeks. I LOVE it. Mine came with 1.05 firmware.
One problem I'm curious if any one has had. The single 12v input on the back does not seem to work. I have tried plugging in a powered antenna and a cooling fan but they would not turn on with the unit. I'd really like to get the cooling fan to only run when the system is running. Any ideas?
bayareakirk is offline
post #1806 of 5590 Old 03-09-2008, 10:28 AM
Artcon's Avatar
I used the RS meter to set the levels at 75db and it is not so much of a straight volume loss that bothers me as it is the clarity lost at these higher volumes compared with the 950.
I would expect an improvement if anything.
Artcon is offline
post #1807 of 5590 Old 03-09-2008, 10:35 AM
Gary Murrell's Avatar
Thanks For your quick reply Gary, There are only RCA inputs on my amp, the interconnects that you are talking about convert the balanced to RCA?
the Outlaw 7700 is balanced as well no?
-Gary
Gary Murrell is offline
post #1808 of 5590 Old 03-09-2008, 10:55 AM
Artcon's Avatar
Unfortunately I bought my amp 4.5 years ago and it didn't have the balanced connections.
Bob
Artcon is offline
post #1809 of 5590 Old 03-09-2008, 02:42 PM
Luffy's Avatar
I am assuming that you plugged them into Trigger B and/or C? If you did, did you check to make sure they are enabled in the menu?
Luffy is offline
post #1810 of 5590 Old 03-09-2008, 02:54 PM
Originally Posted by pepar View Post
oooh, you're making us scroll left and right.
not on my 1680x1050 Sammy 24"
-Gary
post #1811 of 5590 Old 03-09-2008, 05:09 PM
rudolpht's Avatar
Correct, you do need to set them on & they do work.
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #1812 of 5590 Old 03-09-2008, 07:35 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Oh ok
-Matnick
Seven channels for $1,000 isn't going to get you a *lot* of wpc. Emotiva makes a great product at half that money, but it's *only* 125 wpc x 5 and 50 wpc x 2:
http://emotiva.com/lpa1.html
Still, 125 wpc ought to be enough to drive those Klipsch speakers to pretty good levels, since they're so sensitive, and you probably don't need more than 50 wpc for your rears.
They also make a 200 wpc x 7 for $1,700:
http://emotiva.com/mps2.html
Craig
Lombardi said it:
My System
post #1813 of 5590 Old 03-09-2008, 08:43 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Touché!
244T?
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #1814 of 5590 Old 03-09-2008, 08:48 PM
Oh ok
-Matnick
I'd save a couple hundred more bucks and spring for a Adcom, you can get a 7705 for 1250$ but you said you needed 7 channels, that size room needs some serious wattage, I'd go for 300w myself and with 7 channels you are looking at something well above that budget to do it right, you might also look at the Outlaw monoblocks at 200w, 7 of them would hit around 1600$ I think
or if you have bi-ampable speakers get 2 amps like the Adcom 7607(refreshed from 1call) or something along those lines
if I had that size room I would murder a Adcom GFA-7807 or ATI 3007
-Gary
post #1815 of 5590 Old 03-10-2008, 03:21 AM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
-Gary
Maybe so for you, but you still need to scroll L&R on a 17" widescreen HP laptop to see it all.
Johnla is offline
post #1816 of 5590 Old 03-10-2008, 07:59 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Gary is larger than life, and so are his posts.
pepar is offline
post #1817 of 5590 Old 03-10-2008, 08:32 AM
-Gary
My Klipsch speakers max is 150 watts. If I could find something around 140 watts I think I would be happy.
Is Adcom a reputable amp? Never heard of them before.
-Matnick
post #1818 of 5590 Old 03-10-2008, 09:35 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
-Matnick
Adcom is very good, and a very good value as well. BTW, did you know it is easier to blow a "150w" speaker with a 140w amp than it is with a 300w amp?
pepar is offline
post #1819 of 5590 Old 03-10-2008, 09:48 AM
No I didn't know that. What wattage do you recommend for my 150 watt speakers? 200 watts ok?
-Matnick
post #1820 of 5590 Old 03-10-2008, 10:18 AM
bertro54's Avatar
Just bought Onkyo PR-SC885P at ggvideo.com. If anybody is looking to buy 1 they said they had extra units in stock. I looked at as many places as I could find on the internet and they seemed to have the best price $1299.
They said I will receive an e-mail tonight with the tracking number. I have read other peoples comments about this Co. and I hope they are true.
bertro54 is offline
post #1821 of 5590 Old 03-10-2008, 10:41 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
-Matnick
I recommend that you buy as big an amp as you can afford. And then listen closely for distortion if you listen at high levels so you know the capabilities of your system.
It is usually an amplifier "clipping" - the tops (and bottoms) of the waveform are flattened - that sends, basically, direct current to the voice coils causing heat and blown drivers. A higher power amp will be more comfortable at that same listening level, supply clean power to the speakers with no bad effects.
pepar is offline
post #1822 of 5590 Old 03-10-2008, 10:41 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Please, no prices in posts. Pls edit to remove.
pepar is offline
post #1823 of 5590 Old 03-10-2008, 12:02 PM
I looked at the ADCOM and looks very good. Just one question. Where do you connect the sub? I looked at the owners manual and there is no mention about the sub.
-Matnick
post #1824 of 5590 Old 03-10-2008, 12:20 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
-Matnick
The sub should have it's own built-in amp. Plug it into the "Subwoofer/LFE Out" on the pre/pro.
Craig
Edit: The Adcom 7700 is a nice amp, but it's only 5 channels @ 200 wpc. The 7807 is 7 channels @ 300 wpc, but it's 3 x your budget. The Emotiva MPS-2 I recommended earlier is 7 channels @ 200 wpc. This will provide about as much amplifier power as your speakers can handle for about half the price of the Adcom.
Craig
Lombardi said it:
My System
post #1825 of 5590 Old 03-10-2008, 12:38 PM
Craig
Craig
Craig,
I noticed that ADCOM has a 7channel 200 wpc (7707). Not sure of the price yet.
I looked at the rear of the 885 for the subwoofer/LFE connection and looks like it requires a special connector. I spent a lot of money for my 25' subwoofer cable.
-Matnick
post #1826 of 5590 Old 03-10-2008, 12:42 PM
fyzziks's Avatar
It's a standard RCA or XLR connector.
fyzziks is offline
post #1827 of 5590 Old 03-10-2008, 01:03 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Craig,
-Matnick
There are both XLR outputs for long, balanced runs and RCA phono-type outputs nearby amplification.
What is your "25' subwoofer cable?"
pepar is offline
post #1828 of 5590 Old 03-10-2008, 01:04 PM
Any difference between the two?
-Matnick
post #1829 of 5590 Old 03-10-2008, 01:14 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
-Matnick
Oh yeah. Balanced is more expensive and only provides a benefit for l-o-n-g runs in that it is resistant to picking up noise from RFI/EMI. I would define l-o-n-g as anything longer than 10'. Otherwise, the single-ended (RCA phono) outputs are used.
pepar is offline
post #1830 of 5590 Old 03-10-2008, 01:24 PM
Well I have a max of 6'. Should I still go with balanced or for this short distance it won't make a difference?
-Matnick
