The "Official" Onkyo TX-NR905 Thread - Page 289 - AVS Forum | Home Theater Discussions And Reviews
post #8641 of 8847 Old 08-30-2011, 06:27 AM
Grodfather's Avatar
Hi All,
Having read through a significant number of the posts, I'm not sure if I have or have not found the answer.
A week or so ago, my 10 month old reached up and pressed pretty much every button he could reach. I didn't think anything of it and then the next day tried to get it working. However, this time all of the HDMI inputs displayed a red/green crazy lined video sometimes appearing on only half of the screen.
The audio seemed to be fine for a few of the channels, but nothing else. I resetted the factory settings but to no avail. It's all packaged up ready to go but the postage costs are extortinate and from reading the earlier threads I'm guessing any repair will be too.
So the questions are: Is my HDMI board messed up, am I missing something, is it coincidence the little fella was playing with it before and what should I do?!
Grodfather is offline
post #8642 of 8847 Old 08-30-2011, 04:29 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Originally Posted by Grodfather View Post
Hi All,
This is a typical symptom of a failed HDMI board. The video shows vertical pink and green stripes on the top half with snow on the bottom half of the screen... To repair the board would probably cost about $250, replacing it would be very expensive... ~$900-1200 is what I heard. Not sure where you are located but from Hawaii, shipping costs about $250 one way to the east coast to the Onkyo NJ service center... When you get it back, i would strongly recommend you have a cooling fan placed over the right rear of the chassis where the HDMI board is... The HQV Reon processor generates a lot of heat which dries out nearby caps which causes the failure.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #8643 of 8847 Old 09-01-2011, 09:07 AM
acroatis.gr's Avatar
I'm often surprised at how many problems you folk in the good ol' USofA seem to have with your kit. Don't know if it's so much bad luck, not reading the manual - and even if they do, geting it wrong in setting up, or what?
I am still using the fabulous M9750 power amp to drive the recently upgraded 4 Peerless 12" bass drivers in my tri amped, marble sided main speakers. I've had two wonderful A 9070 amps for over 30 years driving my super tweeters and extraordinary Onkyo plastic mid range horns which I bought in Singapore in 1974!!!! (and wouldn't trade them for all the BMWs in China!) and only recently replaced one of them with the remarkable A 9750 digital amp.
I've had my 905 since late 2007 with the 1.06 fw and it has been putting a smile on my face ever since without a hitch! For the last three years it has been in my house in Greece where the temp in summer can reach over 40c and, as the HDMI board gets ridiculously hot, I simply placed it on the top shelf with a 12cm fan on top - and it is enough make the amp feel cool even!
The only two issues I have had recently, after a nasty storm and power failure, are I can't save my set up (Store Fail msg), which makes the second one a real drag, as when there is a power cut (which happens a bit too often down in my village) and despite a power regulator, I lose my settings and they come back all random. A ball breaker, but I know all the settings off by heart so it only takes me a couple minutes to re-do.
Any advice/suggestions to correct these annoying issues would be greatly appreciated as, apart from that, I am still in love with the big Onk - and all my other lovely Onkyo kit.
"Take care to get what you like or you'll be forced to like what you get"! G B Shaw
acroatis.gr is offline
post #8644 of 8847 Old 09-01-2011, 09:32 AM
Audiodork's Avatar
Liked: 37
Hello,
I had that happen a few times on my 875 and all I had to do was unplug it to return normal operation. Even a few weeks ago, the friend I sold my 875 to had this very issue and I told him to simply unplug it from the back of the AVR and it has been working just fine since.
I am not saying that it might not be the HDMI Board going south, but it is certainly worth trying to simply unplug it to see if it returns to normal operation.
Cheers,
AD
Radio Shack SPL Meter Owner
Audiodork is offline
post #8645 of 8847 Old 09-01-2011, 06:19 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
I am not certain if that is really the culprit
The 805s seem to have HDMI board failure as often as as commonly as their Reon equipped 875/905 brethren
what I think is that its just a plain design flaw across the board...one that I have been lucky enough... with 3 failed HDMI boards on 3 different Onkyo units...to have been under the factory warranty
Without it...the unit is basically a brick as its not worth fixing
The worse news is that the xx07 series receivers are starting to have failed HDMI boards as well
so..the saga continues I guess
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #8646 of 8847 Old 09-02-2011, 02:42 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
This might help users in the long term... go to XBRDepot.com and you can buy heat sinks with self-adhesive tape. They are about 1"x1" in size(they were originally designed for X-Box360 CPUs and are pretty cheap. They should help dissipate the heat from the HDMI Reon chips.
Jon S is offline
post #8647 of 8847 Old 09-02-2011, 10:11 PM
turnne1's Avatar
Liked: 410
Ironically....
All of the fans etc don't seem to make a whole lot of difference on these
They still fail at an amazing rate...Reon equipped or not
Besides that...if you have to go through all the fans and all the other stuff...and still fear that the HDMI board might go south anytime.....where is the enjoyment in that?
By the way...where do get this information that the Reon processor is putting out all the heat?
I have personally owned a non Reon equipped unit...that had a failed HDMI board as well...and it got just as hot as the 875 and 905 did
On another note Onkyo made me an offer on the buy
back of my 905
They offered me a refurbished 3009 receiver in exchange
First off..I am surprised they have refurbs of that unit already...I thought it was just now hitting dealers shelves
Secondly..I am not sure how I feel about that unit...the lack of a longer coverage warranty concerns me
The refurbs only have a 1 year warranty
Warren
turnne1 is offline
post #8648 of 8847 Old 09-02-2011, 10:44 PM
Quoted: 72 Post(s)
Liked: 44
That's to early for refurbs don't you think. Man I'll think twice about getting a 3009 that was refurbs so soon.
jsil is online now
post #8649 of 8847 Old 09-03-2011, 08:03 AM
turnne1's Avatar
Liked: 410
That went through my mind
Though on the other hand it seems that Onkyp products seem to be more trouble some in general...so perhaps a refurb will have the bugs worked out and prevent me from having to have a it serviced so quickly
except for pure power a 3009 is probably a better unit than the 905 is in every way
Anyway...I was concerned about the 1 year warranty as well that comes with refurbs...on an Onkyo product I wanta longer warranty
Warren
turnne1 is offline
post #8650 of 8847 Old 09-03-2011, 04:05 PM
originalsnuffy's Avatar
I second the comment about unplugging the unit for a reset to fix problems from time to time. When the system gets thoroughly bollixed, that particular solution works well. I do that about once a year it seems.
originalsnuffy is offline
post #8651 of 8847 Old 09-07-2011, 04:50 PM
turnne1's Avatar
Liked: 410
Got an update from Onkyo
they are doing a buyback on the 905 and giving me a new 5009 receiver
Based on everything..I would say they are trying to do the right thing
Warren
turnne1 is offline
post #8652 of 8847 Old 09-08-2011, 06:35 AM
golffnutt's Avatar
Quoted: 85 Post(s)
Warren
By saying "buyback", do you mean they are giving you a free 5009 in exchange for your 905?
Thank you.Golffnutt"GO DAWGS" !!!!!!!!!!!!!!Panasonic PT-AE 8000U Projector with 10' Screen // Samsung 65" TV UN65KS9500F // Denon X6200W Receiver // Oppo 203 4K Player // Pioneer Elite BDP-05FD Blu-Ray Player (Great CD Player and Excellent Blu-Ray Player) // PSB 9.2 speaker setup with 2ea. M&K 12" Subs // Panasonic Surge Protector // Monoprice Premium Cabling
golffnutt is offline
post #8653 of 8847 Old 09-08-2011, 06:41 AM
gurkey's Avatar
Quoted: 112 Post(s)
Liked: 89
No. They are giving him a "symbolic" $ (just one ) for his 905...
gurkey is offline
post #8654 of 8847 Old 09-08-2011, 08:31 PM
turnne1's Avatar
Liked: 410
yes...they are giving me a free 5009 in exchange for the faulty 905
similar deal happened a few months ago with an 807 that they had worked on 3 times...in that case I was given a full retail price store credit...I then picked up a Yamaha A3000 in Magnolia Home Theater and used to retail store credit against the purchase
Warren
turnne1 is offline
post #8655 of 8847 Old 09-09-2011, 10:38 AM
HiHoStevo's Avatar
Who have you folks been dealing with to get this "exchange?"
There are just two theories for successfully quarreling with a woman -- neither one works!
The Barn - Use Password = AVSForum
HiHoStevo is offline
post #8656 of 8847 Old 09-09-2011, 04:09 PM
turnne1's Avatar
Liked: 410
in regard to the 905
"elevated" customer support
Recall though...the fact that I have had so many failures with Onkyo products documented... that they know about may have helped my case
However...they did refuse to replace my 5508 preamp
They did say I would have to take that one in for service
in regard to the 807
I bought a service plan from Best Buy when I bought the unit
It was in the shop 3x...under their plan that means replacement
In this case...and this was manager discretion...he gave me 100% retail of the 807, even though I only actually paid 35% of retail for it
I put the 100% retail store credit he gave me towards a Yamaha A3000..a stellar piece...and have been very pleased
Warren
turnne1 is offline
post #8657 of 8847 Old 09-10-2011, 09:40 AM
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
Hello!
I got 2 damaged Binding Post (Negative and Positive). My left front speaker fell over and bent the left front speaker Binding Post on my 905. I just need to replace the Left Front Speaker Binding Post.
Is this something I can repair myself or do I have to send the 905 to Onkyo?
I opened the 905 and all I have to say is WOW!!! There are so many circuit boards in the way in order to reach all the binding posts which is at the bottom of the 905.
Anyone ever replace a damaged speaker binding post on the 905?
Thanks for any advice!!!
mantaraydesign is offline
post #8658 of 8847 Old 09-10-2011, 10:44 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Originally Posted by mantaraydesign View Post
Hello!
Repair might not be that easy as you think. Connectors are soldered to the board. So the board itself is likely damadged. If you are not familiar with electronics repair, do not try it yourself. But be aware that Onkyo service center will most likely decides to replace the whole board. It may cost you several hundred dollars.
ap1 is offline
post #8659 of 8847 Old 09-10-2011, 11:02 AM
Quoted: 133 Post(s)
Liked: 33
Thanks for letting me know. I was hoping to replace ONLY the binding post and not the board. If it will cost me several hundred dollars, I might as well get a new receiver.
post #8660 of 8847 Old 09-11-2011, 11:42 AM
turnne1's Avatar
Liked: 410
Agreed
Not worth a fix of several hundred dollars
Warren
turnne1 is offline
post #8661 of 8847 Old 09-17-2011, 02:34 AM
Hi again. Anyone had any experience with "Failed Store" msg when trying to save set up by holding 'setup' button and pressing 'enter'? Any help/advise would be much appreciated.
post #8662 of 8847 Old 09-17-2011, 12:53 PM
HiHoStevo's Avatar
Don't recall seeing that. I have one of the very first 905's sold here in the US... also one of the early ones to receive the updates (was an unbelievable nightmare to find someone with the correct cable and knowledge to do the update).
Mine however stores info into memory, but anytime there is a power interruption or failure it loses everything and must be completely set up again from scratch.
For this reason I purchased a UPS just for the 905... wound up with 3 of them... one for the 905, one for the DVR, and one for the projector.
post #8663 of 8847 Old 09-17-2011, 02:14 PM
gurkey's Avatar
Quoted: 112 Post(s)
Liked: 89
Sounds like the flash memory is damaged or dead.
gurkey is offline
post #8664 of 8847 Old 09-18-2011, 01:51 PM
lsarver's Avatar
I've been thinking about doing the same, but haven't found any that are cost-effective for such use. Which did you buy?
Edit: Don't we need a UPS that outputs a true sine wave?
lsarver is offline
post #8665 of 8847 Old 09-28-2011, 10:54 AM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Has anyone experienced the DTS "bomb" playing back the new Star Wars blu-ray discs with a "patched" DSP on the 905?
Jon S is offline
post #8666 of 8847 Old 10-11-2011, 01:53 AM
jcp2's Avatar
Quoted: 37 Post(s)
Liked: 25
I just experienced the Bomb on my patched (a couple of years ago) 905 with ANH. I was smart and had the volume really really low. I can imagine that it may have blown my speakers if I had the volume up. No bomb via LPCM.
BTW the bomb only happens if I jump to ch.16. It doesn't happen if it plays straight through from the end of ch.15
jcp2 is offline
post #8667 of 8847 Old 10-11-2011, 11:05 AM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
make sure you call Onkyo, otherwise they will not attempt to fix this problem...
Jon S is offline
post #8668 of 8847 Old 10-12-2011, 06:34 PM
lsarver's Avatar
I couldn't hurt to call, of course, but I don't believe that this is an Onkyo problem. It seems to be the disc(s). For example, there are reports from users of the Oppo BDPs, using AVRS and pre/pros from other manufacturers.
lsarver is offline
post #8669 of 8847 Old 10-21-2011, 05:30 PM
jcp2's Avatar
Quoted: 37 Post(s)
Liked: 25
Got a call back from Onkyo this morning. He asked for my serial # and said that they were able to replicate the bomb on a few of their models. I told them how Denon has released a fix for their receivers, and he said that might be helpful as they share a few of the same DSP chips. He said that he would send the info to upper management. I remain cautiously optomistic. *fingers crossed*
jcp2 is offline
post #8670 of 8847 Old 11-06-2011, 05:52 PM
mykee50's Avatar
I've had my 905 since 07'. I've never had a problem with it. I use it almost exclusively for TV and movies but sometimes for music. About a year ago I started getting a loud buzzer type of noise (no music) when on "Tuner". It happens on all zones.
Has anybody ever heard of this. Is it worth contacting Onkyo at this point?
"Buzzing in Seattle", Mike
mykee50 is offline
