The "Official" Onkyo TX-NR905 Thread - Page 295 - AVS Forum | Home Theater Discussions And Reviews
post #8821 of 8849 Old 09-27-2014, 04:50 PM
pieczonka's Avatar
Can anybody help me I did a factory reset on my receiver, and now I cannot remember how to get my Sirius radio working again?
pieczonka is offline
post #8822 of 8849 Old 12-03-2014, 11:02 PM
PeterPL's Avatar
I lost Ethernet and USB working in my TX-NR905, I tried Hard reset VCR+Standby = Net Clear skip [ent] then push Enter and display show "Clear" nothing helped.
Network settings in Menu is unselectable, receiver is connected to router, also not any blinking port behind receiver and router.
EDIT
I checked firmware versions and looks like it lost firmware for Net because shows "?"
Main 9....1.08 / 08223A
SR8051...08214A
SR8052...07518A
SR8053...07820B
HDMI......1.01 / 07706A
Video......07606E00924
Net........?
Net usr...blank
Net rfs...blank
Net krn....blank
Net ipl...blank
How to fix that ? Which firmware contain soft for Net ? Main or DSP ? Please help
PeterPL is offline
post #8823 of 8849 Old 01-25-2015, 04:50 AM
Liked: 0
Nadsp-9072
Hi, I'm new on sait I have a question, where can I find a NADSP - 9072 boards for ONKYO TX- nr905 ? Thanks.
felix33 is offline
post #8824 of 8849 Old 03-22-2015, 02:26 PM
originalsnuffy's Avatar
For those of us still using this receiver I have a question. Is it common for the photo inputs on this receiver to get "funky"? Specifically the left phono input seems to have a bad connection. If I jiggle the cord I can get it to work for a bit then it goes out again. It is the receiver not the connecting cable. I am using a rca extender cable and I did replace the cable and had the exact same problem.
I suppose I could just get a phono preamp and come in via another input as a workaround. Open to some thoughts.
originalsnuffy is offline
post #8825 of 8849 Old 03-28-2015, 05:47 AM
sdlehman's Avatar
It almost sounds like a build up of dust? I haven't had any issues with the phono inputs on my 905. Since you posted this did you get a chance to try the work around?
Stace
sdlehman is offline
post #8826 of 8849 Old 03-30-2015, 08:05 AM
I have not tried the workaround. I do not currently have a phono preamp unit.
If the problem is dust, is there a way to clean it out without opening the unit? Otherwise are there any suggestions for opening the unit without hurting the unit or myself?
post #8827 of 8849 Old 04-23-2015, 10:43 AM
Wisiwyg's Avatar
Hi All,
Lurker - several years the owner of a second-hand TX-NR905 and very happy with it. I've read through much of this thread and have noted the issue with the HDMI board and the 85 deg caps going out and causing problems. There is mention of a thread that provides instruction on how to change them. I'v found the thread on "how-to for dummys", but it is for a different model and the images of the HDMI board look different from what I have.
Is there another thread that walks through this cap replacement? I have searched for the last 30 min for this information both here and the web, maybe not keying the right key words. I'd appreciate if anyone knows the pertinent thread, hopefully with pics, and can point me at the specific caps that need replacing.
Thanks again..
110" homemade Spandex grey-screen, Pan AE8000U, Onkyo TX-NR905
edit: Going back through threads one post at a time, I think I've found what I need in a post by Jon S number 663 in the "How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?)" found here: How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?)
Wisiwyg is offline
post #8828 of 8849 Old 05-19-2015, 10:12 AM
Albator's Avatar
Hello guys, i am pretty sure it has been talked about but this thread is so HUGE!!!! Here is my problem...
For the last week when i turn it on i hear the sound but no pictures!! I've tried with dvd player, blue ray or cable provider and i hear the sound pefectly but no pictures at all!!! I did try a factory reset and it didnt work out... Has my receiver's life already over?
If you could tell me if it's normal after 8 years....i'm kinda upset of not being able to watch tv anymore...
thanks
Albator is offline
post #8829 of 8849 Old 06-01-2015, 08:29 AM
Liked: 0
thanks
Exact same thing happen for me yesterday when I started it! If I press the setup button I see the ONKYO logo but nothing else so it doesn't go into the setup menu. After doing everything (had it unplugged for a awhile also) it worked again! Today after I started it it also worked but after about 2 hours the screen froze but sound continue. I unplugged it and after about 20 minutes it started working again. So seems like some overheating..
I did find some things to try, replacing resistors from the small board in the front from post 17338 in the "The" Onkyo TX-SR805 Thread" and the thing linked just 2 posts up from my post in this thread. (Sorry can't post links to few posts) and just replacing the HDMI board.
So what should we do!? The first thing seems like simplest (even though I suck at soldering) but don't seem like its the right place (far from hdmi ports). I have opened it hoping to find lots of dust but where very little, used some compressed air anyway but very little hope of that.
manderlore is offline
post #8830 of 8849 Old 06-01-2015, 11:18 AM
Liked: 0
*update to above*
Everything was working fine, and then I put the Onkyo in standby a shot while, and after that I got no signal = no video and no sound. Try on off several times but the same. So I pulled the power cord and after that I got sound but still no picture. So it might not be overheating but some handshake or other issue I guess.
post #8831 of 8849 Old 06-01-2015, 11:24 AM - Thread Starter
Jon S's Avatar
Quoted: 926 Post(s)
Liked: 303
thanks
Chances are the capacitors on the HDMI board have gone bad due to heat failure. This is a known issue with Onkyos because they used low rated parts on the board. You can try and replace the caps on the HDMI board, but with its age, I would consider buying a new (non-Onkyo IMHO) receiver with the latest tech.
I had three Onkyos and all three had failed due to one reason or another after a year or two. I would not recommend staying with Onkyo because their reliability is pretty bad...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #8832 of 8849 Old 06-01-2015, 11:41 AM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3557
I agree with the poster just above (Jon S). ...If shopping for a new receiver, look @ the flagship from Yamaha (RX-A3040*), and/or Denon (AVR-X7200W).
...For a pre/pro; look @ Marantz top gun, the AV8802A.
* The Yamaha A3040 will not get a DTS:X firmware update/upgrade. ...Then wait for its replacement this Summer/Fall.
NorthSky is offline
post #8833 of 8849 Old 02-20-2016, 09:58 AM
Dano_1's Avatar
Recently it seems my 905 is not consistently sending a signal to my TV through HDMI, thought maybe it was my TV but hooked up different receiver and it has worked fine for about a month. Is there a fix for this issue? I read something about a faulty board with these receivers. I baught this new years ago and am hoping to get more life out it. Any help would be appreciated.
Dano_1 is offline
post #8834 of 8849 Old 02-20-2016, 10:09 AM
isisyodin's Avatar
Quoted: 36 Post(s)
Take your losses and get a new AVR. My 905 is still working like a champ, but I decommissioned from my main home theater and it is now my second AVR relocated to my bedroom. I did it because I relocated my gear to an AV rack in a closet space. The 905 wouldn't have survived am sure.
Indeed the HDMI board is probably going bad or has gone bad. The problem is not the board itself but the overall design IMHO. If the 905 is a toaster oven and if it doesn't get enough ventilation, it will damage the HDMI circuit board and possibly other circuitry.
Mine has always been on a shelf on its on with plenty of air flow. It still gets hot to the touch but I suppose within the designed limits.
You can get a pretty good AVR with non-active amps (cooler operational temp) for less than $500.
I wish I had more time to enjoy my gear
isisyodin is offline
post #8835 of 8849 Old 02-20-2016, 11:04 AM
Dano_1's Avatar
Any suggestions on a new pre? I have an Emotiva 5 channel amp at 200watts a channel. Think I would want to upgrade to Atmos if I buy again but want something with better quality then the Onkyo as I think I am done with their products. I can always pick up extra amps if needed.
Dano_1 is offline
post #8836 of 8849 Old 02-22-2016, 08:53 AM - Thread Starter
Jon S's Avatar
Quoted: 926 Post(s)
Liked: 303
Marantz's pre-amp processor is very highly rated...
Jon S is offline
post #8837 of 8849 Old 02-22-2016, 09:06 AM
isisyodin's Avatar
Quoted: 36 Post(s)
I also went with separates. A Marantz AV8001 and 2x5 channel Emotivas. My current setup is a 9.2, and I couldn't be happier.
post #8838 of 8849 Old 03-30-2016, 01:02 PM
Liked: 0
I just today acquired a used 905 for $175 and its firmware is ver 1.07 looking to get to 1.09 .....Anyone have have the files and or any advice?
Rick
HemiRick is offline
post #8839 of 8849 Old 03-31-2016, 08:26 AM - Thread Starter
Jon S's Avatar
Quoted: 926 Post(s)
Liked: 303
I hope you checked it before you bought it... This model is plagued by the faulty caps issue on the HDMI board....
Finding firmware for this is nigh impossible now... All the links are dead...
Jon S is offline
post #8840 of 8849 Old 03-31-2016, 10:00 AM
Liked: 0
It works GREAT
It works GREAT, someone has to have a copy of the firmware files........PLEASE ! And besides caps are easy to replace.
Rick
HemiRick is offline
post #8841 of 8849 Old 04-01-2016, 09:05 PM
JimProuty's Avatar
Lightbulb Firmware Download
Rick
Check my signature for a link to the latest firmware. The 100MB .zip file contains instructions and firmware.
It was a long time ago when I used these, I'm no expert.
Go easy on my server, please.
JimProuty is offline
post #8842 of 8849 Old 04-01-2016, 10:07 PM
NorthSky's Avatar
Liked: 3557
Anthem AVM 60, Marantz AV7702MKII, Marantz AV8802A, Yamaha CX-A5100.
Emotiva XMC-1 (no Atmos, no DTS:X, but Dirac Live system EQ for 7.1-channel).
Rick
I don't know if it can help: http://www.lecombatdupeuple.com/imag...pdate-109.html
NorthSky is offline
post #8843 of 8849 Old 04-03-2016, 10:56 PM
Liked: 0
Thank you Jim I knew someone had to have these files.
Now to gather up the courage to use them. LOL
Rick
HemiRick is offline
post #8844 of 8849 Old 06-29-2016, 10:05 AM
Liked: 0
Onkyo TX-NR905 issues
Hi,
I downloaded the attached ISO files with the firmwares. Thank you very much to Jim Prouty. When I open the TX-NR905 directory I see 2 subdirectories there - App Updater 905 and Setup Updater8.8E. It seems that there are some firmwares in each directory. Can someone specify what exactly each directory contains please? I own an european model of Onkyo TX-NR905. I decided to upgrade because my AVReceiver does not recognize the playing format DTS-MA correctly. My AVR is connect with the Oppo BDP-93 (set to bitstream) via HDMI cable. On my display appears wrong information PCM 5.1 or PCM 7.1 instead of DTS-MA 5.1/7.1. Some movies are recognized properly other movies dont like PCM. I tried different HDMI cables and the same results all the time. Other problem are pop-nois issues with playing DTS-MA sources like Taken 1 US version (unrated cut 1:20:17) or Taken 2 US version (unrated cut 1:20:??) and european releases of Jurassic Park 1 (1:20:56/1:57:24), Jurassic Park 2 (1:53:10). These pop-noises ar not so big as I have red on this forum called as DTS HD-MA "bomb" but it bothers me. I am going to upgrade DSP too.
My AV receiver has these versions of FWs:
Main: 9 1.05/07927A
DSP 1st: SR8051 07601A
DSP 2nd: SR8052 07518A
DSP 3rd: SR8053 07820B
Net ipl: 070723/123459
Net krn: 070723/145423
Net rfs: 070731/095118
Net usr: 070731/095118
Net: 1.01/070731z
Video: 07606E00924
HDMI: 1.01/07706A
Can I upgrade directly from 1.05 to 1.09 or I have to upgrade gradually from 1.05 to 1.08 and from 1.08 to 1.09?
Thank you.
Rabanik is offline
post #8845 of 8849 Old 10-24-2016, 06:18 PM
Video out via HDMI has died
So my 905 has a new issue. Like some others, the HDMI video out no longer works. I can still use this as a speaker amp, but no video. There is no Onkyo logo out to the TV when the receiver powers on.
I have done enough troubleshooting to prove the problem is not HDMI cables, the TV, or the source outputs. So it must be the receiver.
Does this look like a symptom of the dreaded HDMI board failure?
As I understand it, this unit is not part of the factory warranty extension program. Has anybody been able to get Onkyo to repair a 905 under the program, and if so are there any code words to use?
post #8846 of 8849 Old 10-25-2016, 07:39 AM
PeterTHX's Avatar
Quoted: 476 Post(s)
Liked: 341
Did you check the other video outputs (composite, S-Video, component)? If those work then it's definitely the HDMI board.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #8847 of 8849 Old 10-26-2016, 07:57 AM
obwizards's Avatar
Same thing happened with my TX875. It useless no sound nothing until I repaired it. You need a new HDMI board or if you repair it yourself you need to replace all the capacitors on the HDMI board
obwizards is offline
post #8848 of 8849 Old 02-16-2017, 08:13 AM
speed6's Avatar
4 ceiling speakers to the Zone 2
Dear all i would like to connect four ceiling speakers to the Zone 2 of the 905.
The ceiling speakers are a Micca M-8C and have the following specifications:
  • Crossover: 6dB/Octave
  • Frequency Response: 40Hz-20kHz
  • Impedance: 8 Ohms
  • Sensitivity: 90dB 1W/1M
  • Power Handling: 100 Watts (Each)
If yes i will be connecting a Sonos Connect to the 905 and will play music through the Zone 2 and ideally through the 5.1 setup, would it be possible?
speed6 is offline
post #8849 of 8849 Old 10-01-2017, 02:26 PM
LukieDog's Avatar
Audyssey Microphone for TX-NR905
Is there a model number on the proper microphone for this unit that I could use to find a replacement? Is it perhaps shared with another model in case I can't find one advertised as for my unit? Are there other manufacturer's (ie Denon, Marantz) receivers that might have the same microphone? A lot of questions, I know, but inquiring minds want to know!
LukieDog is offline
