Yamaha RX-Z11 - Page 88 - AVS Forum | Home Theater Discussions And Reviews
post #2611 of 2628 Old 04-10-2013, 07:36 PM
KJSmitty's Avatar
Liked: 34
Originally Posted by kriktsemaj99 View Post
That table is pretty cryptic, but I always assumed Front & Sub meant the sub gets: Front low frequencies ("low" meaning below the crossover) even when the fronts are set as Large, + LFE + low frequencies (below the crossover) of any other speakers set as small.
I hear ya on the cryptic comment. Definitely appreciate the exchange and explanations. I have a much better mental picture of what's taking place now.
Cheers
Love DIY
KJSmitty is offline
post #2612 of 2628 Old 07-01-2013, 08:07 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
Anyone else noticed that Yamaha has announced new flagship separates, CX-A5000 pre-amp and MX-A5000 power amp. Since I've been using my Z11 in pre-amp mode all along for almost 6 years now I bit the bullet and pre-ordered a CX-A5000 to replace it.
Bob
1) JVC DLA-X750, Yamaha CX-A5100, Outlaw Audio 7900 & 7700, Oppo UDP-203, Roku 4, Sony HAP-Z1ES
2) Sony XBR-75Z9D, Yamaha RX-A3070, 2xOutlaw Audio 2200s, Oppo UDP-203, Roku Ultra, Sony HAP-Z1ES
3) Sharp LC-70UH30U, Yamaha RX-A2050, Oppo BDP-103, Roku 4
bwillcox is offline
post #2613 of 2628 Old 07-01-2013, 09:36 AM
KJSmitty's Avatar
Liked: 34
Very nice. I had not seen that Bill,
Where did you Pre-order from Bill - any wiggle room from MSRP?
Can't wait for your review.. I'll be anxiously awaiting the "5000" owners thread... biggrin.gif
Cheers
Love DIY
KJSmitty is offline
post #2614 of 2628 Old 07-01-2013, 09:38 AM
Jim Parys's Avatar
I have one on pre-order also. Will be running it with Emotiva XPR-5s (x2) and XPR-1s (x2).
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is offline
post #2615 of 2628 Old 07-02-2013, 07:37 AM
bwillcox's Avatar
Quoted: 484 Post(s)
Liked: 270
Cheers
I ordered mine from A&B TV here in Austin (I've been dealing with them for about 20 years now). And yes, they did come off of MSRP for me. smile.gif
I will be driving Outlaw Audio amps: 7900 for the 7 main channels and 4 2200's for the 4 presence channels.
Bob
bwillcox is offline
post #2616 of 2628 Old 12-21-2013, 11:55 PM
cfelbab's Avatar
I'm trying to find the right settings to use for movies with my Yamaha Z11 so that I get sound from all four surround speakers (2 side and 2 back) and sound from my front presence speakers. When I put the amp in a DSP mode like Movie Spectacle I can clearly hear sound coming from the presence speakers but the surround is only coming from the side speakers (from a Dolby Digital 5.1 source like my Apple TV or most Blu-rays). If I put the amp in THX mode, the surround signal seems to come out both sets of rear speakers which sounds dramatically better in my room but there appears to be no sound at all from the presence speakers in that mode. All speakers are wired correctly and they work when I do the level test so the issue is not the hardware or connections but probably a settings issue.
So what I am looking for is specific guidance on the right settings for the amp so that all the speakers I have paid for are used and so that the amp will correctly output sound the surround channels when fed a 5.1 or a 7.1 signal. For the 5.1, I would expect it to send the same signal to all back channels (which is what the THX Cinema Ultra 2 appears to do) while still expanding the front sound stage via the presence speakers. For a 7.1 signal, I would expect to direct the signal to the side or rear surrounds as encoded on the disk again while still having the front presence speakers working.
Anybody know if the amp is capable of doing this and if so how? One other minor note, I do not have rear presence speakers just front presence.
cfelbab is offline
post #2617 of 2628 Old 12-22-2013, 03:13 AM
Dougofthenorth's Avatar
Liked: 44
In the owners Manual there is a chart that lists all the settings & what speakers they use - look there....
Dougofthenorth
www.turtleshelltortue.org RIP
Dougofthenorth is offline
post #2618 of 2628 Old 12-22-2013, 05:54 AM
KJSmitty's Avatar
Liked: 34
O, it's definitely capable of doing just that. I run all 11 channels religiously.. biggrin.gif
Hopefully it's just a settings issue - could be a hardware issue yet I doubt it. I don't have my manual handy yet dive back into the configuration pages on 7.1 and 3D audio. But remember, if your source isn't a 6 or 7 channel mix your "rear" surrounds won't function. Look on the front of your Z11 towards the right of the display where it depicts which channels are present- the little square blocks with L, C, R, etc. - if you don't see all 7 channels you aren't playing a 7 channel source.
Maybe tells us what is depicted on your Z11 display for both surround indications and channel presence.
Bottom line, the Z11 has all of the amps and processing to run all four presence speakers, 7 main channels and two subs simultaneously. That's why I own it as well - just need to figure out your settings. :-)
Cheers
Love DIY
KJSmitty is offline
post #2619 of 2628 Old 12-22-2013, 08:50 AM
cfelbab's Avatar
Thanks KJ. I think that the question I am asking is what should the settings be if you are listening to a 5.1 source (so not a source with the side and back channels) so that you can hear sounds from both the front presence speakers and the 4 surround speakers. I have tried to put the amp in Movie - Spectacle mode where I get sound from the presence speakers but only the two side surround speakers. If I put the amp into THX mode, I get sound from all four back channels but not from the front presence speakers in that mode. What am I doing wrong?
I am pretty sure that the movie spectacle mode will work fine with a 7.1 source (Dolby Digital EX?) but a lot of my devices (e.g. apple TV and most older dvds and blu-rays) do not export a signal for all channels.
cfelbab is offline
post #2620 of 2628 Old 12-22-2013, 01:07 PM
KJSmitty's Avatar
Liked: 34
Gotcha,
I didn't think you could matrix the rear/back channels of "non" 6 or 7 channel sources while in THX mode let alone presence channels - due to not meeting the THX specifications etc? Sounds like it will for the rears at least. Study the Cinema DSP modes and Cinema DSP HD3 modes. In order to play 5 channel or less sources back on all channels you need to have an applicable "decoder" selected and Cinema DSP HD3 activated. Having only front presence speakers will not prevent you from using the DSP HD3.
It's been quite awhile since I messed with those settings or looked at the manual myself. You have me curious now. biggrin.gif. Mine is set on Auto to where it decodes DTS or HD audio only for the source channels then adds in the Cinema DSP/HD3 presence channels/effects - I prefer Spectical, Sci-Fi and Adventure.
Cheers
Love DIY
KJSmitty is offline
post #2621 of 2628 Old 02-17-2014, 05:02 PM
zazzmaster's Avatar
KJSmitty had some questions about subwoofer outputs some time ago - last April. Better late than never.
The Z11 subwoofer crossover frequency is controlled by the front channel. If you change the fronts from small to large, the subwoofer output continues to use the most recent front crossover frequency from the small setting.
I recommend setting the sub configuration to stereo and using the 2 sub outputs for your 2 subs - the L sub gets L bass plus LFE, and the right sub gets R bass plus LFE.
I recommend setting Bass Out to SWFR. The fronts will roll off at the crossover frequency if they are set to small. If you set Bass Out to Front + SWFR, the fronts do not roll off when set to small.
It is best to set all speakers to small and use the same crossover frequency. Doing otherwise makes it impossible to get smooth bass response. I use the THX recommended 80 Hz for all speakers, even though my fronts are full range. I tried numerous settings and EQ approaches using the fronts as large and it always produced uneven bass response. I could get the sub response to look good, and I could get the front response to look good, but when I put it all together it would fall apart.
Part of my reason for using 80 Hz is that I EQ my subs to get a smooth bass response, and I want everything below 80 Hz to go through the EQ.
Room EQ Wizzard (REW) is excellent for measuring your room response, setting speaker levels, etc. You can purchase an inexpensive EQ box and use REW to EQ your subs to eliminate your room resonance modes (boomy bass). You can also EQ them to match a house curve which provides a rising bass output below the sub crossover point. This allows you to adjust the low bass level so that it is the same loudness as midrange in your room. Lots of info on their website.
If you use REW to EQ your subs, you can use the Z11 PEQ to EQ the other speakers to match the objective roll off curve in the bass region. To do this, you use the Bass Limited curve in REW and adjust the Z11 PEQ to match. You get 3 usable filter frequencies for each speaker/channel. This will help smooth out your bass response and prevent the other speakers from exciting a room resonance. They are still putting out a good bit of sound well below the crossover frequency.
The Z11 PEQ does not have sufficient resolution/filters/capability to EQ the subs.
zazzmaster is offline
post #2622 of 2628 Old 05-26-2014, 04:49 PM
awinterton's Avatar
Hi all,
I just picked up an RX-Z11 from surplus at work and I'm playing with its configuration.  I'm a little confused how the zone video works. Here's my setup:
Control:
Crestron X-Panel driven by Crestron MP2E
Sources (All HDMI):
Blu-Ray
ChromeCast
TiVo HD
Main Zone:
Epson 8700UB (HDMI)
7.1 Surround (using built in amplifiers)
Works flawlessly and awesomely.
Zone 2:
Panasonic PT-FW300 (HDMI or Component)
2 Ch Stereo.
Zone 3:
2 Ch Stereo Audio Only
No issues here.
Here's my issue.  The Z11 has 2 hdmi outputs, but the don't work simultaneously, right? I found a brochure that says they're supposed to (www.hi-def.ru/file_download/9).  I tried using Component out, but didn't get ANY video. Does it downscale HDMI signals to component?
I plugged in a composite source and tried that, but again, NOTHING. What gives? Zone 2 is on, and I've selected the source.
Also, the audio options stink! You can only select one digital source when using multi-zone and for it to work, Party Mode must be on.  When off, the digital audio input can only be used in the main zone.
I think I need a different receiver.
awinterton is offline
post #2623 of 2628 Old 08-20-2016, 06:52 AM
Liked: 0
I have a Yamaha DSP-Z11 with the latest firmware (0145, 14/10/2008).
Mediaplayer: Xtreamer Prodigy Silver, connected with a 1.4 hdmi cable.
Bluray player: Sony BDP-S550, connected with a hdmi 1.3.
No complaints about the Z11, only this problem:
When i bitstream DTS-HD-MA or DD TRU HD movies (2D) to the Z11 it handles the signal very well, until i manually pause the movie. Then a very loud popping sound appears, making me want to rush to lower the volume.
I only experience this problem when using Xtreamer, not when i play bluray's with the Sony BD-player!
I've searched Xtreamer forums, have the latest firmware, not a clear answer. I read on this forum that such problems could be caused by the Yamaha's chipset/decoder. Any experiences with this problem, solutions?
No problems with Dolby Digital/DTS.
Also when i play several different surround formats after eachother (dolby digital-trailer, dts hdma trailer, thx-trailer etc.) the Z11 suddenly produces a loud high-hissing sound. The only thing i can do then is turn the Z11 off and on again. It starts again when playing the trailers again. It looks like the Z11 has trouble changing decoders so fast? Any experiences with this too?
Catvision247 is offline
post #2624 of 2628 Old 08-26-2016, 05:47 AM
kriktsemaj99's Avatar
Quoted: 665 Post(s)
Liked: 383
^ It might or might not be the fault of the Z11, but since it won't be getting any more firmware updates I would just try setting the Xtreamer to output multi-channel PCM (assuming that's an option). Decoding to PCM in the source device will give you the exact same sound quality as bitstreaming to the receiver, and there's less chance of getting the problems you describe.
kriktsemaj99 is offline
post #2625 of 2628 Old 02-09-2017, 02:26 PM
billeickmann's Avatar
Yamaha Z11 upgrade ?
An old thread , but an awesome receiver. I am getting the upgrade bug so I am wondering if I should. Anybody upgrade to the newer 3050 or 3060 series? Much difference? Sound quality? Power?
billeickmann is offline
post #2626 of 2628 Old 02-09-2017, 10:11 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
I'm in the same predicament you are. Still running and 11.2 system with my Z11. Keep waiting for Yamaha to come out with a new flagship receiver, but for almost 10 years now they keep pumping out the less than stellar models and the CX-A5000/5100 pre-pro. Really getting the itch for Atmos!
StevenC56 is offline
post #2627 of 2628 Old 04-13-2017, 11:26 AM
rx-z11 with Dolby Atmos?
Can anyone tell me how a Z11 works with a dolby atmos movie? Just wondering if I need to upgrade and sell my wonderful Z11 or if I can squeeze a few more years out of it.
post #2628 of 2628 Old 04-13-2017, 01:18 PM
Quoted: 665 Post(s)
Liked: 383
Since it's not aware of Dolby Atmos it's supposed to just play the underlying Dolby TrueHD track (up to 7.1). In practice, and this may be partly dependent on the Blu-ray player, you might get a few brief audio dropouts if the player sends the Atmos bitstream.
I experienced this with my RX-V1800 (same vintage as the Z11), with an Oppo BDP-103D player. It didn't happen with all discs. It seemed like the dropouts should be caused by the player, but Oppo support claimed it was the receiver's fault. Having the player decode the bitstream and send as 7.1 PCM is a way to avoid the dropout problem.
So you can still keep using the Z11 even with Atmos sound tracks, you just might have to switch to decoding in the player if you have problems (and of course you won't get any benefit from the extra channels in the Atmos track).
