The "Official" Yamaha RX-V1800/RX-V3800 Thread - Page 293 - AVS Forum | Home Theater Discussions And Reviews
post #8761 of 8780 Old 06-09-2015, 02:45 AM
Rinke's Avatar
Hi all. I have just got a 3800.I am trying to get the volume control to show on the screen. By that I mean when I use the volume control on the remote that it will also show on the tv screen. I did have it going but now can't seem to find the setting. Can anyone help me please?
Rinke is offline
post #8762 of 8780 Old 06-09-2015, 02:54 AM
Bond 007's Avatar
Quoted: 772 Post(s)
Liked: 1087
Turn Short Message on.
Bond 007 is offline
post #8763 of 8780 Old 06-09-2015, 03:04 AM
Rinke's Avatar
Where is "turn short message on" in the menu please?
Rinke is offline
post #8764 of 8780 Old 06-09-2015, 03:13 AM
toby10's Avatar
Quoted: 12 Post(s)
page 90 of your user manual (section Manual Setup video)
toby10 is offline
post #8765 of 8780 Old 06-09-2015, 03:14 AM
Rinke's Avatar
Ok I found and turned on short message and it still doesn't show the volume control on the tv screen???
Rinke is offline
post #8766 of 8780 Old 06-09-2015, 03:37 AM
Bond 007's Avatar
Quoted: 772 Post(s)
Liked: 1087
If you have video processing makes rue it's turned off.
Bond 007 is offline
post #8767 of 8780 Old 06-09-2015, 03:53 AM
Rinke's Avatar
Video processing???
Rinke is offline
post #8768 of 8780 Old 06-09-2015, 03:57 AM
Bond 007's Avatar
Quoted: 772 Post(s)
Liked: 1087
Video processing???
I assume that's not an option on your receiver then.
Is your source an HDMI connection?
Bond 007 is offline
post #8769 of 8780 Old 06-09-2015, 04:05 AM
Rinke's Avatar
Yes. But even when playing back an analogue source still doesnt show volume on tv screen.
Rinke is offline
post #8770 of 8780 Old 06-09-2015, 05:58 AM
kriktsemaj99's Avatar
Quoted: 388 Post(s)
Liked: 247
^ The 3800 does not support short messages (including on-screen volume) for HDMI inputs, or for HD analog inputs (720p and above). It only works for 480-line SD analog video input. In other words there really is no useful on-screen volume on that model. It was only on the 3900 and later that it was supported on all input resolutions.
kriktsemaj99 is offline
post #8771 of 8780 Old 06-09-2015, 01:07 PM
Rinke's Avatar
Ok thanks. The only thing is at one point when i first got the amp it was definitely working??
Rinke is offline
post #8772 of 8780 Old 06-09-2015, 02:37 PM
Quoted: 388 Post(s)
Liked: 247
^ maybe you tried a 480i or 480p analog input, which will work.
post #8773 of 8780 Old 06-09-2015, 07:42 PM
Rinke's Avatar
No. Its all HDMI except one analogue input for a DAB tuner.
Rinke is offline
post #8774 of 8780 Old 06-11-2015, 04:33 AM
Rinke's Avatar
Hi again. Does the 3800 work with the Yamaha wifi adaptor?
Rinke is offline
post #8775 of 8780 Old 06-12-2015, 06:18 AM
toby10's Avatar
Quoted: 12 Post(s)
Can't see why not (but being Yamaha who knows).
But why not just buy a generic WiFi adapter instead for less $$$? All these devices do is take a wired (RJ45 ethernet) connection and make it a WiFi connection. Many different mfrs to choose from.
toby10 is offline
post #8776 of 8780 Old 06-29-2015, 04:41 PM
classicrecording's Avatar
Quoted: 17 Post(s)
Liked: 48
I just got a mint condition HTR-6190, which, from what I understand is the badged down version of the 1800.
My first question is; should I do a factory re-set. Is there any advantage to it other than removing the previous owners settings?
classicrecording is offline
post #8777 of 8780 Old 06-29-2015, 05:05 PM
jpco's Avatar
Quoted: 195 Post(s)
Liked: 72
I do not think so. I've had an 1800 since release and never did a reset.
jpco is online now
post #8778 of 8780 Old 06-30-2015, 05:29 AM
Quoted: 388 Post(s)
Liked: 247
No need to reset, but you'll want to go through all the menus to check the settings. No harm in doing a reset either.
If the firmware isn't up to date it will clip video to levels 16-235, and may still have the famous DTS-MA bitstream bomb bug. If you do update it will reset everything anyhow.
This recent post discusses firmware versions.
post #8779 of 8780 Old Yesterday, 05:34 AM
Quoted: 17 Post(s)
Liked: 48
Thanks for the replies.
I did a system re-set with no problems. I have got it back to where I had the receiver set to before, and now I am working on learning its features.
Is there any way to tell what firmware is installed?
post #8780 of 8780 Old Yesterday, 08:44 AM
Quoted: 388 Post(s)
Liked: 247
The document describing the firmware update procedure (attached) also tells you how to check the firmware version.
Turn the receiver off with the MASTER ON/OFF button and then start at step 9. Let us know what version you have.
Yamaha Rx V1800 Receiver , Yamaha Rx V3800bl Receiver
