The "Official" Yamaha RX-V1800/RX-V3800 Thread - Page 294 - AVS Forum | Home Theater Discussions And Reviews
post #8791 of 8799 Old 07-22-2015, 09:27 PM
Rinke's Avatar
Thank you for all your replies.
Rinke is offline
post #8792 of 8799 Old 07-24-2015, 01:46 AM
Rinke's Avatar
Yamaha confirmed today that the trigger outs are indeed set to work for the main zone. Have ordered my 12v trigger switchbox!
Rinke is offline
post #8793 of 8799 Old 08-10-2015, 09:37 PM
Liked: 0
Question RXV-1800 / 3800 read data / receive data over rs232/serial question
Hi All,
I've been working with the RS-232/Serial port on my RXV1800 for the past couple days. There are a lot of threads on sending commands to it, which, I have successfully working (volume up, change input, etc). I even have a little web interface setup for changing the options, which are all working properly.
However, I have not found anything about reading, or receiving data from the receiver over rs232/serial.
What I would like to do is somehow tell what the receiver is spitting out. Ie: If i press volume UP, i want to know that the code I see over serial (######) is turning the volume up, to X from whatever the intial amount was.
I know that when I initially connect over RS232 (or send just a blank return/enter) a bunch of numbers are spit out all on one line, which I assume is a 'status' line, I'd somehow like to translate this so I have my base numbers to go from, and then I can make an app to display the data that is read back from the receiver.
I'm using Linux so I have a plethora of 'ways to do it', I am just not very familiar with RS232 working at all and this is all pretty new to me, so any help would be appreciated!
flewid is online now
post #8794 of 8799 Old 08-11-2015, 06:41 AM
kriktsemaj99's Avatar
Quoted: 423 Post(s)
Liked: 266
^ There is documentation out there for the RS-232 commands and the returned status info. Here's one for the V1900, but 99.9% will be the same for the V1800.
Look for the sections on Report Commands and Playback Status Reports.
kriktsemaj99 is offline
post #8795 of 8799 Old 08-11-2015, 05:22 PM
Liked: 0
Great thank you, not exactly sure what to do with this [yet] but it looks helpful and exactly what I was looking for
I do wonder if there's already a library or something made for *NIX that I could start with..
post #8796 of 8799 Old 08-11-2015, 05:59 PM
Quoted: 423 Post(s)
Liked: 266
^ If you've got some commands working, then interpreting the feedback from the receiver is not very different. If you have a question about a specific command, you can always ask here.
post #8797 of 8799 Old 08-11-2015, 10:44 PM
Liked: 0
Well, To start this is what I'd like to do;
1) Connect to the port
2) Issue a 'status' command on 'input' and 'volume'
3) Return the current volume, status, and possibly the 'sound mode' if applicable (or PCM if not)
4) when i press a button on remote to turn volume up, or down, or switch input, the app should show me that volume went up or down or input was changed.
I would need this to be on console some how, because i plan on making a daemon that will listen to the serial port, plus send commands to it, so i can hook up a remote device (a raspberry pi) for tinkering with this.
Main goal, is to get on the raspberry pi display (either console, web page, or xwindows) showing a realtime indication of the current input, sound mode, and volume level (and if i change anything, the screen updates in realtime).
thanks
post #8798 of 8799 Old Yesterday, 06:23 AM
Quoted: 423 Post(s)
Liked: 266
I can send more details later, but basically...
2) To request the current volume or input, use the system commands such as "main volume value text request" (see page 9 of the doc. I linked).
3) See the bottom of page 15 for the format of the response for this type of request (it's already formatted as a text string).
4) When you change a setting (volume etc.) with the remote, the receiver sends an "operation report". See page 27 of the doc. for the format.
These are not sent as formatted text strings, so you have to interpret the value returned to get the volume in dB, the input selected, etc.
Note that when the doc. says (for example) a return value of C7 means 0dB, it's not a single byte with hex value C7, it's two bytes with the ASCII characters "C" and "7".
post #8799 of 8799 Unread Today, 05:39 PM
Liked: 0
Okay, awesome thanks so much. I will muck around and post if i have any additional questions
Yamaha Rx V1800 Receiver , Yamaha Rx V3800bl Receiver
