The "Official" VSX-94TXH Thread...:0) - Page 167 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #4981 of 4997 Old 03-16-2016, 10:44 AM
Legairre's Avatar
Quoted: 627 Post(s)
Liked: 334
Originally Posted by sk1bum View Post
Thanks for that but apparently my post count is not high enough to send PM to you, I will try again as soon as I am able.
That's OK I'll pm you my emails address and you can just email me directly and I'll reply with the firmware and instructions.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #4982 of 4997 Old 03-16-2016, 10:44 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
My receiver is doing crazy things, was working fine until recently and then I lost the TV feed from my HDMI 1 port, I moved it to 3 and it was working fine for a little while, I then needed to move the receiver to another location and now it has gone crazy, I have the Directv PVR plugged into HDMI 3 but can only get it to respond if I set it to HDMI1 input. Tried to input set up several times and it always comes back to the same thing, thinking I may need to do a factory reset on the unit, opinions are welcome and appreciated.
The TV should be connected to the HDMI Out not HDMI 1
FMW is offline
post #4983 of 4997 Old 03-16-2016, 10:44 AM
Liked: 0
I have owned Pioneer elite gear for years and was only looking at the same whenever I went for a new piece of equipment. I was looking for a new receiver recently to upgrade to ATMOS, and decided to make a change, picked up the Marantz 6010, and have only gone through the initial set up, have not spent a lot of time with it but so far I find the set up and the Odyssey much easier and superior to the Pioneer Elite's MCACC, will update this post when I have spent more time listening to the sound etc.
sk1bum is offline
post #4984 of 4997 Old 03-16-2016, 10:47 AM
Liked: 0
I understand, I wasn't clear in my post, I have the output connected to the TV, I was speaking of the inputs.
sk1bum is offline
post #4985 of 4997 Old 03-16-2016, 11:28 AM
Legairre's Avatar
Quoted: 627 Post(s)
Liked: 334
How do I get to the V-parameter screen to enable video scaling?
I got rid of my 92TXH back in 2009 so I don't have one to outline the steps, but page 71 of the manual details how to get to the V.Parameter screen. This link will download a .pdf version of the manual. https://www.google.com/url?sa=t&rct=...OS8y7Q&cad=rja
post #4986 of 4997 Old 03-16-2016, 01:30 PM
Stechs01's Avatar
The first thing I would do is a reset to factory. Also, you should do a visual inspection of the HDMI ports themselves for any bent contacts or loose fitting connector. These jacks are very delicate, especially with heavy cables hanging out of them. Try making your HDMI connections using the default labels after the reset, before renaming any inputs. I would do all that before even worrying about the firmware updates.
Stechs01 is offline
post #4987 of 4997 Old 03-16-2016, 06:57 PM
Liked: 0
Ok, reset to factory settings and the crazy stuff seems resolved.
sk1bum is offline
post #4988 of 4997 Old 03-19-2016, 07:18 AM
Yornch's Avatar
Liked: 0
Originally Posted by Stechs01 View Post
Looking into updating the firmware on my 94TXH but it is several versions behind. Are there DIY options to get to 2.012 that include all the incremental updates?
Hi there, it doesn't matter what your current firmware version is. Follow the instructions and you will have the latest.
Thank you! So the update is cumulative and includes all of the updates between 2.0* and 2.013?
Yornch is offline
post #4989 of 4997 Old 03-19-2016, 09:28 AM
Stechs01's Avatar
Yes, Firmware is basically a set of instructions for the processor. When they come up with a fix for an issue, the are basically making a correction to the instructions. When you do the update, the firmware that's in there gets erased, and the the updated firmware is written into the memory to replace it. For anyone interested, I'll post the firmware change log from Pioneer. This is just for the DSP Flash.
Stechs01 is offline
post #4990 of 4997 Old 07-10-2016, 01:53 PM
brucegz's Avatar
Hi All, been awhile since I've stopped by. I've got additions to my setup that I can't figure out how to configure.
Before: Standard Pioneer VSX-94, used speaker pole wires out, normal inputs including HDMI (TV and DVD player).
Now: Added 2 amplifiers, 1 is a 3 channel Krell. I changed the speaker outputs from the speaker poles to the multi-channel outs and that part is working fine. I moved the sub there too.
The 2nd amplifier though I want to use for a separate zone outdoor speakers. I moved the speaker wires from the Pioneer Channel B pole outs to the Multi-Zone & Source outs but can't get any sounds from them. I also see from the manual that there are ridiculous limits on which inputs can be sent to the i.e. Zone 2, for example, no iPod, no Sirius or XM, no Home Media Gallery. It seems that setting up the 2nd amplifier with a 2nd outdoor speaker zone is oddly difficult for this Pioneer system.
Any help or suggestions on how to do this would be GREATLY appreciated!
Bruce
brucegz is offline
post #4991 of 4997 Old 07-19-2016, 08:12 PM
copene's Avatar
Quoted: 37 Post(s)
Liked: 69
Thank God for this place. I PM'd Legairre for the latest firmware but just in case he's not around if someone can PM me the zip that would be amazing. Thanks guys, I'm on 2.007 and everything else is current so I guess I only have to do the easy CD update.
copene is offline
post #4992 of 4997 Old 10-13-2016, 04:11 PM
mmountainbiker's Avatar
Quoted: 93 Post(s)
Liked: 42
can someone explain hdmi control and is it the same as arc?
mmountain biking fool who loves his home theater
Pioneer ElitE SC 87
Samsung UN65HU8550 Qs04 SEK 3500
Dual SVS pb12+/2 ultra's with drywall nails backing out
mmountainbiker is offline
post #4993 of 4997 Old 11-12-2016, 07:09 AM
robo1234's Avatar
Quoted: 12 Post(s)
Can anyone direct me or have a way to control my 94 from the ethernet port ? or any other way to set vol power etc or is the rs232 port the only way?
Many thanks in advance
robo1234 is offline
post #4994 of 4997 Old 03-05-2017, 06:01 PM
Liked: 0
what are you trying to control and with what? you want to control volume through the ethernet port?
rw417 is offline
post #4995 of 4997 Old 03-05-2017, 06:15 PM
Liked: 0
I know this thread is old and dead, and I'm not trying to revive it but I thought I would add in my 2 cents for the firmware upgrades I did today.
I had to update the main, HDMI, DSP and DSP 1.
I did this with an older Dell laptop with a dedicated serial port I use for this kind of stuff. Windows XP is great for that, I have always had trouble with USB to serial converters. I bought the cable suggested by the manual I downloaded from PioneerFAQ. The HDMI, main and DSP updates went off without a hitch.
I also made the CD rom with the wav file, but didn't need it. I followed another users advice and updated it with my macbook using the digital optical output into the receiver. Worked great.
I was very simple to do with the right equipment. I have everything required to do it and would be happy to help out other users if they need theirs updated as well. Bring it to me and it can be done in 30 mins or so. Shipping these units is not cost effective but I would be happy to do update them at your shipping expense.
It did immediately make a difference. I was having issues with a HTPC build I have with a 980 TI graphics card. The receiver was not working with the PC. It didn't detect video. First try after the firmware updates it was working as it should. Really happy I went through with this and I'm thankful for everyones help getting it done. I had to sift through 165 pages of info but it was worth it.
feel free to message me here if anyone would need help with firmware updates.
rw417 is offline
post #4996 of 4997 Old 03-06-2017, 12:04 AM
AJCxZ0's Avatar
Quoted: 41 Post(s)
Liked: 48
That's a most generous offer. To where would we be bringing them, geographically speaking, and what kind of beverage would you need to relax after a hard day's upgrading?
AJCxZ0 is offline
post #4997 of 4997 Old 03-08-2017, 01:38 PM
Liked: 0
No charge or beverage needed unless I had to dismantle and reset after failed updates . I'm located in the Binghamton, NY area.
It wouldn't take more than an hour, tops.
Also, If you wanted to ship it to me I could update and ship it back at the owners expense, but it's a heavy machine and I don't think people would be comfortable with that process. Anyway, feel free to message me through the forum if updates are needed
Ryan
rw417 is offline
