Best receiver in the $500 range? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-29-2007, 04:43 PM - Thread Starter
jsimas1974's Avatar
Hey guys,
I'm looking to pick up a new receiver in the $500 or so range. Preferably, with a couple of HDMI inputs.
Any suggestions?
There's a Tweeter near where I work having a clearance sale on the PIONEE VSX80TXV and PIONEER VSX81TXV. Are these any good? If not, anything better in the same price range?
jsimas1974 is offline
post #2 of 8 Old 08-29-2007, 05:35 PM
Happy13178's Avatar
Ebay's got a couple Sony STR-DA3200ES receivers in that range...one for $489 right now, actually. Doesn't look that bad...
Specs:
Audio
Impedance: 8 Ohm
Channel Power Rating: 120 Watts X 7 Amplifier Power (8 ohms, 1Khz, 0.7% THD)
Sound Fields: Cinema - 4; Music - 8; Auto Format Decoding - 12; 2 Channel - 1
Zones: 2 Zone/2 Room
Tuner Type: Auto Tuning, Direct Tuning, Station Name, Presets 30/30/30 (XM/FM/AM)
Inputs and Outputs
S-Video Input(s): 4 (1 Front, 3 Rear)
S-Video Output(s): 1 (Rear)
Composite Video Input(s): 5 (1 Front, 4 Rear)
Composite Video Output(s): 3 (Rear-1 Monitor Output, 2 Video Outputs)
Optical Audio Input(s): 4 (1 Front, 3 Rear)
Optical Audio Output(s): 1 (Rear)
Coaxial Audio Digital Input(s): 3 (Rear)
RCA Audio Input(s): 4
RCA Audio Output(s): 2
Multi-Channel Input(s): 1 (Rear, 7.1 Channel)
Subwoofer Output(s): 1 (Rear)
AC Outlet: 2 (Rear) Switched
Antenna Terminal (AM Loop): 1 (Rear)
Antenna Terminal (FM 75 Ohm): 1 (Rear)
Headphone Output(s): Yes (Front- Gold)
Speaker Terminal Type: Screw Binding Posts (A & B)
HD Component Video Input(s): 2 (Rear)
HD Component Video Output(s): 1 (Rear)
HDMI Connection Input(s): 2 (Rear)
HDMI Connection Output(s): 1 (Rear) Repeater
Power
Power Requirements: AC 120V, 60 Hz
Power Consumption (in Operation): TBD
Power Consumption (in Standby): TBD
Audio Features
Digital Cinema Sound Technology: Yes
Dolby Digital Decoding: Yes
Dolby Pro Logic II Decoding: Yes
dts 96/24 Decoding: Yes
dts NEO:6 Decoding: Yes
Dolby Digital EX Decoding: Yes
Dolby Pro Logic IIX Decoding: Yes
Amplification Relocation: Yes
Dolby Pro Logic Decoding: Yes
dts-ES Decoding: Yes
Convenience
AM/FM Memory Presets: 30 FM - 30 AM
XM Connect and Play Compatible: Yes; Neural 5.1 Surround Sound Decoding
XM Memory Presets: 30
Convenience Features
Sound Fields: Yes
A/B Speaker Switch: A / B / A+B
On Screen Display: Yes
Digital Cinema Auto Calibration: Yes (Mic- Mono)
HDMI Technology: Intelligent A/V Selector
Hardware
Remote Control: Yes- Advanced Learning/Pre Programed
Speaker
Center Speaker Terminal: Yes
Video Features
Up Conversion: Yes (HDMI Up Conversion from Component, S-Video and composite to 1080i)
Supplied Accessories
Instruction Manual
FM Wire Antenna
AM Loop Antenna
Size AA Batteries: 2
1 Way LCD Pre Programmed Macro capable Remote Commander Remote Control
1 Remote Commander
Happy13178 is offline
post #3 of 8 Old 08-30-2007, 08:45 AM - Thread Starter
jsimas1974's Avatar
Thanks. I'll definitely look into that.
Any opinions on the Pioneer Elite receivers? Are they a good deal on clearance for that much?
post #4 of 8 Old 08-30-2007, 08:50 AM
krbailey's Avatar
I have been looking in the same price range and have been hearing good things about the Onkyo 605. May be worth taking a look.
krbailey is offline
post #5 of 8 Old 08-30-2007, 08:58 AM
andross77's Avatar
Originally Posted by jsimas1974 View Post
Hey guys,
Any suggestions?
i would recommend the onkyo 605. has 2 hdmi inputs and some very advanced audio features. it had an MSRP of $600 when it came out a few months ago, but if you go to techbargains.com and search for it, click through the link, and then put the silver one in your basket, it can be had for $386 + tax, free shipping and no financing till 2009 with a CC card. Hope you read this before the thread gets locked for my price talk. Just tryin to help ya out .
andross77 is offline
post #6 of 8 Old 08-30-2007, 09:28 AM
Pocket Aces's Avatar
I've been looking around too and I just ordered the Onkyo 605. The HDMI ports are 1.3 compliant and it does HDMI upconversion from other sources. The only downfall I heard was that it actually down converts component 1080i to 720p when if you use the HDMI as the final video output. 90W per channel isn't super powerful but it should be all you need. On top of that I think its the cheapest receiver that current has built-in Dolby Digital Plus, Dolby TrueHD and DTS-HD decoding.
Pocket Aces is offline
post #7 of 8 Old 08-30-2007, 09:30 AM
Can't you PM people on this site instead of getting there threads locked. Hopefully the mods have enough courtesy just to remove your post
post #8 of 8 Old 08-30-2007, 02:29 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
The Sony 3200ES or DG1000 on ebay is probably your best bet. The two models are nearly identical. I just bought the DG1000, and it exceeded my expectations. Very clean, tight, powerful sound and very easy to set-up and operate. A steal at $500 or less.
RWetmore is online now
