How to set-up Yamaha RX-V661 to get lossless 7.1 with my brand new blu-ray ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-30-2007, 05:19 PM - Thread Starter
E-A-G-L-E-S's Avatar
My question is besides choosing 'TrueHD' on the disc "what do I set on my Yamaha" ??
I finally picked up a blu-ray player and got my first rental disc. It is ghost rider which I'm not super excited about the movie but the audio and visual should be great on my 1080p dlp.
E-A-G-L-E-S is offline
post #2 of 5 Old 08-30-2007, 05:30 PM
Spylake's Avatar
Is it connecting with an HDMI cable?
Your receiver should be set to multi-channel PCM.
Spylake is offline
post #3 of 5 Old 08-30-2007, 06:14 PM - Thread Starter
Yes...HDMI from Blu-Ray to receiver then another from receiver to t.v.
Could you elaborate on how to set it to that? I only see MULTI CH IN on remote and that leaves me with no video or audio since I'm hooked up via HDMI.
Thanks so much Spylake.
post #4 of 5 Old 08-31-2007, 03:59 AM
phantom52's Avatar
Quoted: 232 Post(s)
Liked: 240
Make sure that the HDMI on the receiver is set to on. The Multi Ch IN is for using analog cables, such as those for using for SACD/DVD-A or the analog outputs from a another source. The HDMI cable alone will carry TRUE HD and all other sound formats. You will then see multi-channel pcm on the display on the receiver. Also have to make sure that player is set up properly. I don't have blu-ray so I don't know what settings it uses, but with my HD-DVD it needs to set up as PCM in the setup menu. Hope this helps.
phantom52 is offline
post #5 of 5 Old 08-31-2007, 07:43 AM - Thread Starter
So I watched last night and chose 'Striaght' on the remote for my receiver and 'TrueHD' on the blu-ray player. My receiver showed PCM on screen so I think it was true 7.1
All I know is it was damn loud and that disc is very cool looking in HD.
