Center speaker output not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-01-2007, 01:58 PM - Thread Starter
billwill's Avatar
Hello -
I have an Onkyo DS-777 and the center speaker is no longer working. Tested the speaker; it's fine. Connected a different speaker to the output, and no sound.
So-
Do I have to replace the whole thing because of this, or could I connect it to a power amplifier and then connect the speakers to that?
Or, is this just crazy talk?
Bill
billwill is offline
post #2 of 3 Old 09-01-2007, 04:39 PM
Sirquack's Avatar
Your idea of using the center preout to an external amp might be an option, but not sure I would spend a lot of money for an amp, just for the center channel. You might try checking the manual on how to perform a "reset" of the microprocessor maybe that will clear it up. not sure.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #3 of 3 Old 09-01-2007, 07:10 PM
whoaru99's Avatar
Liked: 69
Have you checked all the speaker setup/configuration settings?
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
