new marantz sr7002, sr8002 receivers - Page 172 - AVS Forum | Home Theater Discussions And Reviews
post #5131 of 5151 Old 11-22-2015, 04:23 PM
CkRtech's Avatar
Long shot here, but -
Have any of you used the SR8002 to pass analog audio through to a recording device? I am trying to use the CD in to push audio through (sounds fine on my system) and also record it on a separate component that has analog audio inputs.
Rather than split the signal at the source, I would prefer to go through the SR8002. However, it doesn't appear to pass the analog signal through the CD out - or at least I cannot hear it when monitoring.
The manual pretty much says "you are good to go!" by simply plugging in analog stereo to the OUT port, but I am not having any luck.
CkRtech is offline
post #5132 of 5151 Old 11-22-2015, 11:33 PM
EtheB's Avatar
I must not be understanding your question because I do that exact thing with my 7002.
CD analogue IN. Monitor OUT.
I can't image they reduced features on the 8002?
EtheB is offline
post #5133 of 5151 Old 11-23-2015, 02:20 AM
jdsmoothie's Avatar
Quoted: 13279 Post(s)
Liked: 6146
You should be able to use either the TAPE OUT or CD OUT for your use case. Try turning the volume of the recording device up much higher.
jdsmoothie is offline
post #5134 of 5151 Old 01-15-2016, 07:53 AM
DERG's Avatar
Quoted: 37 Post(s)
I've owned a Marantz SR8002 for nearly 8 yrs but seldom used it for just listening to music. While Dolby & DTS surround thunders in our man-cave, CDs do not. The audio is clear as a bell but to me it just sound flat (Maybe I miss the '70s loudness contour of my Marantz SR 2020b!).
Lately I've tried a few new tricks to cure that, namely some of the surround effects found under DD & DTS. They help a little but still missing something. Then I tried to use the 3. SURROUND SETUP to customize these settings. I assumed adjusting sub levels for TRUBASS, for example, would only be engaged when playback of PCM Stereo & selecting one of the surround simulators. Not true. After adding 5db to TRUBASS I checked 2. SPEAKER SETUP & found the Sub level had increased 5db also.
That can't be right, can it?
DERG is offline
post #5135 of 5151 Old 01-18-2016, 06:40 PM
Sittler27's Avatar
Quoted: 722 Post(s)
Liked: 63
Marantz SR7002 Issues to JVC X750R Projector
If I run any HDMI out of Marantz to the JVC projector, I get a green screen (with video viewable, but all greenish). However, if I run direct from my source components to the JVC projector it's fine (using Monoprice Cabernet 35' runs of HDMI).
I've tried multiple HDMI cables between source and Marantz.
Second issue, is that I cannot get the Marantz to play HDMI audio. It plays optical audio and RCA audio fine though.
I connect from either my Tivo box or Oppo 103D player and no HDMI audio.
Any ideas? I know the Marantz is getting long in the tooth, but I'm thinking it should work right?
Sittler27 is offline
post #5136 of 5151 Old 01-19-2016, 07:29 AM
Sittler27's Avatar
Quoted: 722 Post(s)
Liked: 63
Anyone have any ideas here on this? I just need to know if either something is broken on my Marantz, or if it isn't compatible with the new HDMI specs or something.
post #5137 of 5151 Old 01-19-2016, 05:47 PM
Sittler27's Avatar
Quoted: 722 Post(s)
Liked: 63
Ok, I sent an email to Marantz support. I'm going to assume that something must have broke on my Marantz and I should start looking for a new one.
post #5138 of 5151 Old 10-06-2016, 02:23 AM
Brian81's Avatar
Looking for help here. No subwoofer output from SW preout. I've tried everything that I can think of. I've tried the factory reset. I've tried unplugging. I've checked settings to verify everything is set properly. I've even tested the sub using the 7.1 outs of my BD player. Nothing works. However, when I go through the speaker testing under MENU, I do get sound to the sub with the test tone. Surprisingly, that actually works.
Brian81 is offline
post #5139 of 5151 Old 10-06-2016, 03:50 AM
jdsmoothie's Avatar
Liked: 6146
Are the FL/FR speakers reset to SMALL/80Hz as is suggested after running Audyssey?
post #5140 of 5151 Old 10-06-2016, 10:21 AM
Brian81's Avatar
I set speakers manually, not using Audyssey, as I am running 3.1 right now (no surrounds connected, they are still boxed up). For some clarification, the sub works when connected direct to the BD player, so the sub works. Also, I have had the sub working fine with this receiver in the past (have owned since 2010, but 'mileage' is low on it and sometimes months go between use). Last time I powered this on was back in February and everything worked fine at that time. I use it now and the sub is not getting sound like it did before.
In manual setup, I have had fronts set to LARGE in past with sub to YES and the setting to LFE at MIX. Crossover at 60Hz (changed to 80Hz during testing). I have used since my fronts are towers spec'ed down to 32Hz and I do music listening. During all of my testing in the past 36 hrs, I tried setting the fronts to small and there is no difference. I think there MAY be some sound going to the sub when the gain on the sub is maxed out, but it is VERY hard to notice. Like said, when I do the test tone to the sub, it rumbles pretty loud at my typical setting for sub gain setting, though I don't remember how loud it should be with the test tone.
All I know is that the sub has always worked fine in the past.
Brian81 is offline
post #5141 of 5151 Old 10-07-2016, 03:33 PM
EtheB's Avatar
Perhaps I'm missing something here but what happens when you use direct mode?
EtheB is offline
post #5142 of 5151 Old 10-07-2016, 11:18 PM
Brian81's Avatar
No sound from sub. Only sound going through was doing the test tones.
Some good news though. I did the two different resets before to no success, but I tried it again....four times in a row at that (doing just multi + spkr a/b)...followed by connecting and configuring from 2 channel, cycling power, adding/configuring center, cycling power...etc... and to my pleasant surprise, sound coming from sub again!
Brian81 is offline
post #5143 of 5151 Old 10-08-2016, 06:04 PM
EtheB's Avatar
What versions of firmware you running?
I wonder if there is a mismatch between CPU & DSP versions, a corrupted install (from factory or an update?), or perhaps the EEPROM is on the way out.
These units are around ten years old and I've seen similar EEPROMS go bad for no apparent reason. In theory their read/write spec in the millions.
EtheB is offline
post #5144 of 5151 Old 10-08-2016, 10:45 PM
Brian81's Avatar
Hi, I never had an update. I know when I purchased it, I checked the firmware version to see if it was with the one affected by the DTS error. It wasn't. I think it was 39? I purchased the receiver in 2010(?), and most of the time it hasn't been used. I only used it for stereo until last year.
Brian81 is offline
post #5145 of 5151 Old 03-12-2017, 04:57 AM
CkRtech's Avatar
Any of you guys running a device to the SR8002's SPDIF Coax input that does 176 kHz?
I built a circuit for digital audio output on a Sega Saturn, and I can't seem to get the receiver to pick it up. Power up of the Saturn puts the receiver on "digital" and the little box appears so it can light up the L & R speakers + the PCM light, but those never turn on.
CkRtech is offline
post #5146 of 5151 Old 04-24-2017, 05:39 AM
Joe Lighty's Avatar
New question that hopefully someone can shed some light on...
A few weeks ago, I got the dreaded blinking red standby light on my SR7002 - dead power supply
Tried a reset, no luck - took it to the local Australian importer who has a service department. They were very efficient and reasonably priced and "fixed it". But now that I've got it home and reconnected everything I note an annoying "hum" through all channels, from all inputs, that is directly relative to the set volume. Watching TV or movie is bearable, but listening to music (which used to sound wonderful!) is disappointing, particularly during quieter moments, when the hum is much more noticeable. I've returned it to the service department, suggested whatever resistors or diodes they replaced may be slightly off spec, but their first reaction was one of genuine surprise.
Any suggestions?
Joe Lighty is online now
post #5147 of 5151 Old 04-24-2017, 07:37 AM
jdsmoothie's Avatar
Liked: 6146
Any suggestions?
http://www.psaudio.com/ps_how/how-to-find-and-fix-hum/
post #5148 of 5151 Old 04-26-2017, 07:46 PM
Joe Lighty's Avatar
Thanks - looking forward to seeing what the service department says!
post #5149 of 5151 Old 04-27-2017, 01:25 AM
EtheB's Avatar
Any suggestions?
Did they say what what components were replaced?
Assuming it's not something strange with your external connections, hopefully the hum is something as simple as an internal connector not put back together quite right. Lots of interconnections for the signals & power rails between the various boards in that beast.
I had a similar issue with a CD player some years ago when I accidentally re-routed a single cable too close to another bundle which induced a low level hum in the signal output.
EtheB is offline
post #5150 of 5151 Old 04-30-2017, 03:13 PM
Joe Lighty's Avatar
No, they were not specific about which components were replaced - what was clear was that before it went in to them (granted, it was dead with the blinking red standby light) it had no hum - now it does! So yes, hopefully just a slightly wayward connector or similar... Expecting to hear from them soon - of course, it could be also be a case of "no hum noted here" in which case I will feel a bit silly and will have to recheck the routing of my cables - but I'm pretty sure that won't be the case. I do just hope it can be fixed - I love the SR7002 - terrific sound!
Thanks for everyone's input and suggestions.
post #5151 of 5151 Old Today, 08:37 PM
Joe Lighty's Avatar
10 points to MR EtheB - after much head scratching, they traced it to a faulty, poorly fitting connector on one of the components that was earthing poorly, which they admitted was most likely their doing when repairing the transformer. Returned, no hum, free of charge.
Thanks for the suggestions here.
Marantz Sr7002 Surround Receiver , Marantz Sr8002 Surround Receiver
