The NAD T775/T785 AVRs w/ HDMI 1.3 Thread! - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #4351 of 4365 Old 06-11-2015, 05:10 PM
nosferatu2xlc's Avatar
thank you victor for the ZIP file
~~~ wwhlimi UART is for ipod interface
nosferatu2xlc is offline
post #4352 of 4365 Old 06-13-2015, 09:30 PM
can any one post a picture of On Screen display from the new VM150 how is it different from the original VM100 ?
post #4353 of 4365 Old 06-27-2015, 04:15 AM
itdk's Avatar
Has anyone experienced their T785 randomly turning up and down the volume? I see nothing on the OSD or the display that indicates the volume being raised or lowered. It just happens.
I've only experienced this while listening to radio, using the built-in tuner. But 90% of my listening at the moment is Tuner, so it might happen with other sources as well.
I suspected the remote at some point, but since I'm not seeing the volume being raised in the display, I'm ruling that one out.
I just updated to the latest firmware on all 4 components. I'll report how it goes now.
T785 w/ AM200 + VM150
EDIT: It just happened again, now I see the text "Check DSP board" in the display. Any pointers?
EDIT2: What is the DSP board? Is it one of the MDC modules?
Best regards
Jim
itdk is offline
post #4354 of 4365 Old 07-07-2015, 12:25 PM
itdk's Avatar
Best regards
Jim
On addition to above post:
I sent it off for repair and they have returned with a suggestion that my house electrical outlet could be varying in voltage.
They have tested the unit by lowering the voltage to between 210-220volts, where the error can be reproduced.
After testing my outlets with a voltmeter, I have a steady 227volts of outlet output (europe is ~230volts).
They can't find other problems with the receiver and I'm lost for what the next step should be
I have the latest NAD firmware and the reciever has been sitting in the exact same spot, with the same speakers, cables and electrical outlet. Nothing has changed in the last 4-5 years.
itdk is offline
post #4355 of 4365 Old 07-08-2015, 02:06 PM
roadrunnerdk's Avatar
Hej Jim.
I have a T175 with the same boards. Recently I experienced the volume going down. No one was touching the remote - but I could see on the display, that volume was going down. I then hid the remote under a pillow, and volume was still going down. I could turn up the volume with the remote, but again - no one touching it the volume again went down. Then I removed the batteries from the remote - and reinstalled the same batteries and problem was gone. Batteries are not used up so that cannot be the cause.
roadrunnerdk is offline
post #4356 of 4365 Old 07-28-2015, 09:17 AM
samsung84's Avatar
I am also having the problem of volume ramping up and down on its own with my T775. I had this problem as well as a dead amp channel 2 years ago and by looking at the repair receipt the only thing that was changed was the amp board. I would love to know what causes this as well before my speakers are damaged.
samsung84 is offline
post #4357 of 4365 Old 08-10-2015, 09:20 AM
arrush's Avatar
I was hoping someone that knows more about these might be able to help me out. I am looking to buy a used T775 but can not figure out what I am looking at exactly.
From what I gather there are a few variations, the original T775 that could not decode DTS Master, an upgraded T775 with the VM100/AM200 that could decode DTS Master, and also an T775HD and T775HD2.
Are there any differences between these units other than the VM/AM modules where the latter HD/HD2 allow for HDMI 1.4 and 3D?
ID:	879106   Click image for larger version
arrush is offline
post #4358 of 4365 Old 08-10-2015, 09:48 AM
cctvtech's Avatar
Quoted: 64 Post(s)
Liked: 64
It's all in the modules. As I recall, the original T775/T785 came with VM100 and AM200 modules. My t785HD came with VM200 and AM200 modules. Here's a link to NAD's module upgrade matrix: http://www.nadelectronics.com/img/static/MDC-Matrix.pdf
Be seeing you!
cctvtech is offline
post #4359 of 4365 Old 08-19-2015, 10:46 PM
Typhoon1611's Avatar
The early 775/785 had no MDC, it came later.
Only Sweden, Norway and Denmark had HD and HD2 I think. (HiFi-klubben)
Typhoon1611 is online now
post #4360 of 4365 Old 08-19-2015, 11:26 PM
Best regards
Jim
One time a few weeks ago my T785HD2 lowered the volume all the way and I saw it on the OSD.
Earlier in this thread writes user that their volume raised by itself.
post #4361 of 4365 Old 08-20-2015, 10:24 AM
NCCaniac's Avatar
Quoted: 29 Post(s)
Liked: 45
I have a T775 here in the U.S. and I think the T775/785 HD and HD2 were also available here. An earlier post had a link to an NAD web site that says what audio and video modules are supported in the different models.
NCCaniac is offline
post #4362 of 4365 Old 08-20-2015, 10:00 PM
My bad, someone at this board told me long time ago there was no HD and HD2 in US.
post #4363 of 4365 Old Yesterday, 04:02 AM
Can someone be kind to tell me how to open the NAD HTRC 1 remote without breaking or scratch it? My volume up is not working.
post #4364 of 4365 Old Yesterday, 10:30 AM
NCCaniac's Avatar
Quoted: 29 Post(s)
Liked: 45
It is a little tricky to open without the right tools. If you don't have them already, I would suggest getting some plastic "pry tools" as are designed for doing repairs on cell phones, smartphones. You can get a set at Radio Shack or online (Amazon, etc.). They have a small curved flat blades that you can wiggle to get into the seams on the side the of the remote and gently pry upward to separate the two halves of the remote case. There are several "tabs" along each side that snap into place when the halves go together and what you have to do is use the pry tools to lift up around the edges, find the places where the tabs are and then use the tool to push in on those while prying up and each tab will pop loose. Take your time and work around the long edges and it should eventually come apart when you have all the tabs released.
When I did this with my HTRC 1 remote, I did not have the pry tools and tried doing it with very small, flat blade screwdrivers. I got the remote case apart, but gouged it up a bit around the seam.
NCCaniac is offline
post #4365 of 4365 Unread Today, 03:59 AM
Thank You, I will get some plastic pry tool.
