Official Pioneer Elite VSX-92TXH thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #631 of 2046 Old 04-27-2008, 03:32 PM
scoxnc's Avatar
How can you get a line level out of zone 2 with fixed volume? As I would like to use the AVR's Tuner in another room, and still have available the main zone. Need line level out of the AVR to a Russound C-68 controller which controls the volume in eight more zones.
scoxnc is offline
post #632 of 2046 Old 04-28-2008, 05:54 AM
boltonic's Avatar
Quoted: 125 Post(s)
How do you get the lastest firmware installed on your VSX-81TXV?
boltonic is online now
post #633 of 2046 Old 04-28-2008, 11:53 AM
micromatikal's Avatar
Quick question about component pass-through to HDMI
Does this receiver allow a 1080p component signal to pass through it to the HDMI out untouched (or at least still at 1080p)?
I sure hope so, I want to hook my Xbox 360 up to it and output it at 1080p as I have been doing, but want to have just the single output from my receiver and input on my TV in use. Also, yes it is the Xbox 360 that does not have the HDMI out.
Thanks for any and all help
Tim
micromatikal is offline
post #634 of 2046 Old 04-28-2008, 12:08 PM
crOwcaine's Avatar
Originally Posted by pddr1 View Post
need help with my 92txh and ps3 hook up. i'm getting a "not Support" error message when hooking up via hdmi. i tried switching the ps3 to another hdmi input on the reciever, with no luck. still getting the not support error message. i tried cycling the power on and off on both the reciever and the ps3, also with no luck.
any thoughts out there?
All you have to do is go into the system menu in the PS3 and switch the display mode to "automatic". It will use the highest resolution possible. "Custom" doesn't handshake with the PS3 too well.
crOwcaine is offline
post #635 of 2046 Old 04-28-2008, 12:16 PM
crOwcaine's Avatar
Originally Posted by mlfarris View Post
Just got a 92 and am new to all its features. What is the best mode to listen to heavy metal music on the 92? And, how can I make manual adjustments to the EQ while listening to the music at the same time?
I WISH. They only let you EQ to that fu%&in stupid noise, like that's gonna help anyone who isn't pro. I suggest turning the "sound retriever" function ON, it adds a certain umphhh to the sound IMO. Use the auto MCACC function with the mic then turn the "sound retriever" on and see if you like it better. It's supposed to enhance uncompressed audio files (impossible) and it adds a certain process to the sound that I dig.
post #636 of 2046 Old 04-28-2008, 08:36 PM
mlfarris's Avatar
Yeah, I tried to go into the EQ while listening to music, but I keep getting "cannot select". That's unbelievable that it doesn't give you the ability to EQ your music by ear. How do you turn the "sound retriever" function on?
mlfarris is offline
post #637 of 2046 Old 04-28-2008, 09:55 PM
alrha's Avatar
I have speakers in my kitchen connected to the rear surround inputs and set as B speakers to play in the kitchen whatever is on in the living room. Problem is that the sound is much louder in my kitchen. I am having trouble trying to figure out how to lower the volume of the B speakers compared to my A speakers. Can anyone help me out on this? Thanks.
Pioneer Elite SC-57
Playstation3 (Slim 320GB)
Samsung SMT-C5320 (Cablevision box)
4x Mirage OMD-5
1x Mirage OMD-C1
1x Martin Logan Dynamo 500 SW
2x Mirage OmniSat V2 (Kitchen)
alrha is offline
post #638 of 2046 Old 04-30-2008, 08:47 AM
cpharper's Avatar
Hey everybody, 2 questions.
Can the 92 play music from a USB drive like the 94? I can't find any pictures of the 92 with the front cover down to even know if it has a USB input.
Also, if I use a 5.1 setup do I connect the rear speakers to the Surround or Surround Back posts?
cpharper is offline
post #639 of 2046 Old 04-30-2008, 09:26 AM
alrha's Avatar
the 92 does not have a USB drive - but you can connect an iPod to it.
In a 5.1 setup, the surrounds connect to the surrounds (surround back posts can be used for speakers to a different room or to bi-amp the front speakers)
Pioneer Elite SC-57
4x Mirage OMD-5
1x Mirage OMD-C1
alrha is offline
post #640 of 2046 Old 05-01-2008, 06:26 AM
cpharper's Avatar
Thanks alrha!
Also, can you connect an iPod directly with the included cable or do you need a dock? I read the manual but it was unclear if the dock was optional or req'd.
cpharper is offline
post #641 of 2046 Old 05-01-2008, 06:58 AM
TDI Driver's Avatar
The included cable is all you need to connect your iPod to the 92
"What's better? A great 2D movie or the worst 3D movie?" - Stephen Colbert
TDI Driver is offline
post #642 of 2046 Old 05-01-2008, 07:07 AM
cpharper's Avatar
Thanks again. My 92 is scheduled for delivery on Monday!
Are there any tips, tricks, or pitfalls you guys know of with the 92?
cpharper is offline
post #643 of 2046 Old 05-02-2008, 01:37 PM
cpharper's Avatar
Does the 92 have RDS for FM radio stations?
cpharper is offline
post #644 of 2046 Old 05-02-2008, 10:10 PM
jtaka1's Avatar
Will there be a problem running my 4ohm totem dreamcatchers with this receiver? Only the frontl l/r are 4ohms. Also, can I bi-amp them with the extra two channels I won't use since I have 5.1? Because if this is the case I may just get the 91. I don't need the upscaling, won't your tv or player do that? Just want the video to pass through. Thanks
jtaka1 is offline
post #645 of 2046 Old 05-05-2008, 04:10 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Hey guys, looking at a receiver for a buddy of mine. Tried on the Pioneer website but couldn't figure this out. Is the MCACC on this receiver a multi-position one or does it just take measurements from one seating position?
Tx
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #646 of 2046 Old 05-05-2008, 06:27 AM
mmountainbiker's Avatar
Quoted: 93 Post(s)
Liked: 42
Every since I was a teenager, I have had a pioneer receiver. I had surround sound before there was prologic. As a older adult, I got my first Elite receiver.
And I am on my third. So I am now subscribing to this video because I have found a authorized pioneer elite vendor (as long as order it from phone)that has the vsx 92 txh at a well below sugested price. These receiver are sure pleasing to the eye. My latest receiver is the 53 tx which still rocks. I have been wanting to upgrade for a while now. but untill now thier havent been a reason to . With hdmi 1.3a possible being the final standard in connectivity
(for a while at least even though Ive heard of 1.3b) I feel comfortable buying something relitivly futureproof. Glad I didnt get the vsx 84. So Im getting ready to piss of my wife my third major home theater purchase of the year.
She hates my b.u.f.f. svs pb12+/2. but you know my motto about W.A.F.
mmountain biking fool who loves his home theater
Pioneer ElitE SC 87
Samsung UN65HU8550 Qs04 SEK 3500
Dual SVS pb12+/2 ultra's with drywall nails backing out
mmountainbiker is offline
post #647 of 2046 Old 05-05-2008, 12:54 PM
Legairre's Avatar
Quoted: 712 Post(s)
Liked: 360
Originally Posted by pbc View Post
Hey guys, looking at a receiver for a buddy of mine. Tried on the Pioneer website but couldn't figure this out. Is the MCACC on this receiver a multi-position one or does it just take measurements from one seating position?Tx
Both you can choose either a single or up to 3 positions. Page 37 of the manual describes it in detail.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #648 of 2046 Old 05-05-2008, 12:56 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Thanks ...
pbc is offline
post #649 of 2046 Old 05-06-2008, 08:58 AM
Hey everyone, I just sent back my Onkyo 805 and replaced it with the Pioneer 92 TXH. The main reason I did that was the fact that the lip sync issue with the 805 was driving me crazy. Well it seems that I am having a hard time fine tuning this Pioneer so that it doesn't have the same problem. There is a noticeable lag between the on-screen mouth movement and the audio. I have set my speaker distance down to 00' 01" for the front channels (and center) and that seems to help quite a bit. Is that what I should be doing to eliminate this problem? I originally ran the MCAAC (or whatever the acronym is) automatic setup with the microphone and it set the speaker distance accurately as far as actual physical distance, but the lip sync lag was pretty noticeable...
Any help would be greatly appreciated.
Tim
post #650 of 2046 Old 05-07-2008, 11:42 AM
gollumis's Avatar
hello,
just purchased the 92. it sounds great so far!! i have not used macc since i am currently a 2 channel setup. i have a basic question, i am going to be using my 92 in a 5.1 setup, my question is where do the surrounds go? do i put them in the surround back or just put them as surrounds? i am currently in the process of building my HT. thanks in advance.
gollumis is offline
post #651 of 2046 Old 05-07-2008, 11:44 AM
You want to put them in just the surrounds slot if you are doing 5.1 and not 7.1 =). The surrounds back is for the verrrrrry rear channel for 7.1 systems.
post #652 of 2046 Old 05-07-2008, 12:20 PM
gollumis's Avatar
good to know! what happens if you put them in the surround backs? does that mess with the sound field. Do you still hear all of the effects with the speakers in the surround slots. thanks
gollumis is offline
post #653 of 2046 Old 05-07-2008, 12:28 PM
Surround back / rear has it's only set of "effects", you could try putting them in that slot if you wanted to see what exactly you were missing, but there is much more data coming from the regular surrounds =)
post #654 of 2046 Old 05-07-2008, 12:53 PM
Legairre's Avatar
Quoted: 712 Post(s)
Liked: 360
You can try it, but you'll only hear the rear effects and will not get any of the side effects.
Legairre is offline
post #655 of 2046 Old 05-07-2008, 02:15 PM
gollumis's Avatar
ok, that makes sense. My speakers are going to be on side and not the back anyways, since i dont have a back wall. is that a good thing or do you really need them behind you? they will be in line with the seating area, they are polk FXI A4s
gollumis is offline
post #656 of 2046 Old 05-07-2008, 02:30 PM
Legairre's Avatar
Quoted: 712 Post(s)
Liked: 360
Here's the Dolby 5.1 and 7.1 seating charts.
Attachment 109748
Attachment 109749
Sorry try it now
Legairre is offline
post #657 of 2046 Old 05-07-2008, 02:51 PM
gollumis's Avatar
i can't see your images. Can you see them? i am using Safari.
gollumis is offline
post #658 of 2046 Old 05-07-2008, 04:23 PM
The pictures look fine to me, but essentially you need to just hook them up to the SURROUND outputs.
post #659 of 2046 Old 05-07-2008, 07:53 PM
gollumis's Avatar
i can see them now. cool, will do. i might be back with more questions in the future. so far this receiver is worth the money!!
gollumis is offline
post #660 of 2046 Old 05-08-2008, 06:45 AM
cpharper's Avatar
Hey guys, can the Pio Elite 92/94 take a component input and output it via HDMI? Is this called transcoding? Thanks!
cpharper is offline
Vsx 92txh Elite Home Theater A V Receiver , Sony Bdp S1 1080p Blu Ray Disc Player , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Yamaha Rx V995 Surround Receiver With Dolby Digital And Dts Decoding , Pioneer Elite Bdp 94hd Blu Ray Disc Player
