Official Pioneer Elite VSX-92TXH thread - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1861 of 2032 Old 11-11-2011, 10:15 AM
livingproof73's Avatar
Originally Posted by Legairre View Post
Not sure what the DSP update addresses. Wonder why they didn't update yours?
Yeah, Im not too impressed to say the least and it was a bitch to unhook everything to begin with and looks I may have to do it all again! I've been searching online to see what that DSP update addresses but no luck so far.
livingproof73 is offline
post #1862 of 2032 Old 11-11-2011, 10:17 AM
Legairre's Avatar
Quoted: 469 Post(s)
Liked: 270
Looks like this guy has a do it yourself upgrade. http://www.avsforum.com/avs-vb/showt...4#post21197604
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #1863 of 2032 Old 11-11-2011, 03:12 PM
StuBerger's Avatar
I was told by the service center that did my update that the DTS Bomb is caused by the DSP firmware.
Those are my principles, and if you don't like them... well, I have others.
StuBerger is offline
post #1864 of 2032 Old 12-01-2011, 07:07 PM
StuBerger's Avatar
Got a question, I had the firmware updated a while back and I started to notice a couple days ago while watching both Directv and a BluRay during night scenes, when a light bulb or other light source I notice a glare line going from left to right of the source and at times a light line noise I guess you can call it... Could this be the 92 or something going on with my Sony LCD?
Also, is it wise to reset the 92 after a firmware update?
Never mind, took the BluRay player and went directly into the TV and same thing!
post #1865 of 2032 Old 12-12-2011, 03:29 PM
HTguru3's Avatar
Does anyone know the difference between A. Delay (which is automatic) and Delay which is adjustable in the Audio Parameters menu? Do they accomplish the same thing and what is everyone using? When watching TV through my Comcast HD Cable box, occasionally a program will have their video out of sync with the dialogue, will the A. Delay take care of that?
HTguru3 is offline
post #1866 of 2032 Old 12-18-2011, 06:37 AM
jeffro-c's Avatar
Hello all
does anyone know the exact name of the four round feet on the bottom of the VSX 92TXH
one of mine broke and it has no part number on it and i have had no luck searching the web
any help i would really appreciate thanks
Pioneer Vsx 92-TXH Pioneer BDP 33FD
(2) HK Citation 7.1
Epson 8350
100" jamestown Fixed Screen
Triad Classic Glod Lcr's
Triad Classic Gold Satelites
Triad 18" in room Platinum Sub
panamax M5100pm
Lian-Li Htpc Case
intel i7-950 8gb-Ocz & 2tb Hd's
Gigabyte Ga-X58a & ceton infini tv 4
jeffro-c is offline
post #1867 of 2032 Old 12-18-2011, 08:42 PM
HTguru3's Avatar
Originally Posted by jeffro-c View Post
Hello all
Probably calling Pioneer might be your best bet or take one off and take it to a local repair shop and see if they have any that can match up with it.
HTguru3 is offline
post #1868 of 2032 Old 01-23-2012, 04:52 PM
StuBerger's Avatar
Question, I had the firmware updated a few months ago. I was wondering if it's smart or needed to do a reset on the 92 after a update?
post #1869 of 2032 Old 01-27-2012, 11:13 AM
StuBerger's Avatar
Hey, where did everyone go? LOL
Any answer to my question????
post #1870 of 2032 Old 01-27-2012, 03:48 PM
Legairre's Avatar
Quoted: 469 Post(s)
Liked: 270
Hi Stu, the first time I had mine updated it was already reset when I got it back. the second time some things were lost and some were still the same, but everything was updated. As long as the firmware was updated I'd just be happy it didn't get wiped and leave it alone.
post #1871 of 2032 Old 01-28-2012, 06:54 AM
sumavguy's Avatar
Would the update fix this issue? When I turn on my Panasonic st30 TV it turns on the 92 but not fully, and it makes it look like it might be trying to do pass through or something, but after about 20 seconds it shuts off. Although if I have my TV and 92 on and turn off my TV it turns off my 92. I can tell its trying to do some HDMI control, but not sure why its not doing t all. I have it on a 35' HDMI cable, and even put changed the receiver to input 2 on my tv as that isn't supposed to have pass through on it(which I though was the issue).
Also if I turn my 92 on and turn my TV on before that second click it mutes the sound.
Any help would greatly be appreciated.
sumavguy is offline
post #1872 of 2032 Old 01-28-2012, 09:27 AM
StuBerger's Avatar
Hey Legairre...long time no see, hope all is okay over at yours! That's good to know..since nothing was changed in my settings after the flash.
post #1873 of 2032 Old 01-28-2012, 09:28 AM
StuBerger's Avatar
Just turn off HDMI control and that should correct that.
post #1874 of 2032 Old 02-19-2012, 07:01 AM
romlife's Avatar
Just purchased a Panasonic GT30 and had the exact same problems that you have with shutoff, mute, off then-on but it was all cured instantly when I TURNED OFF Viera connect in the Panasonic's setup menu. You don't need it unless all your equipment is Panasonic brand.
romlife is offline
post #1875 of 2032 Old 03-02-2012, 05:01 PM
kjordan's Avatar
The remote control for my VSX-92 suddenly stopped working. I have been getting up to change the volume and inputs since then and trying to figure out what happened. I saw an old post from "mlfarris" with the same issue but never any real replies. My receiver won't respond to either the original remote or my harmony remote. Yes I did press the "receiver" button on the original remote. It just flat out won't respond to either remote. Has anyone else had this problem?
kjordan
kjordan is offline
post #1876 of 2032 Old 03-02-2012, 07:20 PM
Legairre's Avatar
Quoted: 469 Post(s)
Liked: 270
Someone in this thread said it was a cold solder joint on the board that they had fixed that solved the problem. http://www.avsforum.com/avs-vb/showthread.php?t=1039495
post #1877 of 2032 Old 03-03-2012, 07:23 PM
Fir_XYZ's Avatar
Hi, all!
Recently I have bought at ebay the european model of Elite 92THX - VSX-LX60.
It is brand new and i got it for 300 euros (~380 USD).
It looks and sounds great, i'm happy with it.
But i have read a lot of topics about freezing issue caused by cold solder joint.
There was a sensation that EVERY 92THX or 94THX (european LX60 and LX70) will get this issue soon or later...
Is it right or wrong?
Does anybody use this receiver a lot of time (2-3 years) and there is no problem with it?
P.S. Sorry for my English
Fir_XYZ is offline
post #1878 of 2032 Old 03-03-2012, 09:35 PM
StuBerger's Avatar
Okay, what's up with this cold soldier joint thing...first time I've heard of this. What does the problem cause?
post #1879 of 2032 Old 03-04-2012, 02:53 AM
Fir_XYZ's Avatar
As people say the receiver freezes time to time, controls stop working, etc.
Read here: avsforum.com/avs-vb/showthread.php?t=1039495
And here: curtpalme.com/forum/viewtopic.php?t=19315&postdays=0&postorder=asc&&start=0
Fir_XYZ is offline
post #1880 of 2032 Old 03-04-2012, 03:42 PM
jeffro-c's Avatar
Hello All !
I have been at this for some time with no solution and hope someone can help me out? I have my fios hd/dvr 7232-2 running into my 92 via hdmi and out from the 92 to my epson 8350 projector. the problem i have is when i change channels or fast forward tv i get this pop through my speakers. just one single pop whenever i change channels ff ect and can not figure this out for the life of me
i have done all the usual checked hdmi cable,changed override to off,changed the recomended settings in the stb hidden menu ect ect
at this point im starting to wonder if its the 92 but would love for it not to be
if anyone has had this problem please please let me know if you have solved it
or if there are any other setting in the 92 that might fix this issue
any and all suggestions or help would keep me from jumpin off the roof
thanks in advance for any input on this
(2) HK Citation 7.1
Epson 8350
panamax M5100pm
Lian-Li Htpc Case
jeffro-c is offline
post #1881 of 2032 Old 03-04-2012, 06:01 PM
Legairre's Avatar
Quoted: 469 Post(s)
Liked: 270
Hi Jeff my guess is that it's coming from the amps. Can you do me a favor and run the 92txh straight to the speakers without the citation amp connected? Also can you check which speakers the pop comes from and only disconnect those speakers connects from the amp to the 92. That way you don't have to disconnect everything.
I know it's a pain to do this but finding the culprit will be a process of elimination starting with the amp.
post #1882 of 2032 Old 06-20-2012, 11:54 AM
mridan's Avatar
I'm in the process of getting my 92 updated. I'm bring it to the service center in Arlington Heights IL which is a short drive from my home. I want to make sure they update the firmware and DSP flash due to DSP bomb. Has anyone on this thread brought their unit there for an update, and if so did they know to update DSP?
mridan is offline
post #1883 of 2032 Old 11-20-2012, 06:18 PM
mosfetman's Avatar
I have the service manual but it was not of any help to me...My MCACC red LED is now blinking and the unit does not respond to a factory reset. The service manual is available on ebay for $10...thats where I got it.
Mosfetman
mosfetman is offline
post #1884 of 2032 Old 11-20-2012, 06:34 PM
macgyver655's Avatar
Interesting user name. If you have the service manual it tells you how to reset from this error. It is not a factory reset. Did you buy it this way or did it happen while you were using it.
macgyver655 is offline
post #1885 of 2032 Old 11-20-2012, 07:34 PM
mosfetman's Avatar
Thanks Mac for the reply.
If you are referring to pages 64 to 66 that describe the protection circuit bypass and the power block failure, I do not believe that this is the case with mine. If I had an output section failure, I would never power up or operate properly. Additionally, I applied the two jumpers on the protection ICs that would circumvent a protection "failure" code.
I'm just fed up with this receiver...it's been a nightmare. Its on ebay for $150, shipped, and includes a free service manual!
Jerry
P.S. the "MosFetMan" user name stems from my love of MosFets for output transistors...second only to mass quantities of KT-88 tubes.
post #1886 of 2032 Old 11-20-2012, 08:19 PM
mosfetman's Avatar
If any of you guys want to mess with a once working 92txh in near perfect condition, I am selling mine for $150 including shipping to Continental U.S. on ebay:
http://www.ebay.com/itm/221156731306?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
MosFetMan
post #1887 of 2032 Old 11-21-2012, 09:01 AM
I could easily solve your problems but since it appears to be sold I wont comment. Oh, and your procedure of soldering the jumper wires was incorrect.
post #1888 of 2032 Old 11-21-2012, 09:05 AM
I see in your ebay ad you say you had the power up problem fixed once before. Was that the freezing problem?
post #1889 of 2032 Old 12-09-2012, 05:34 PM
Imageless83's Avatar
Thanks to Legairre I am the newest member in this club and hoping to stay for a longtime.
Imageless83 is offline
post #1890 of 2032 Old 01-09-2013, 11:42 PM
Rogozhin's Avatar
Nice, I just ordered a SC-1222-k to replace my amazing 92, I'm going to be sad to pull her out of the rack. frown.gif
GamerTag= Phaleronic
Rogozhin is offline
Vsx 92txh Elite Home Theater A V Receiver , Sony Bdp S1 1080p Blu Ray Disc Player , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Yamaha Rx V995 Surround Receiver With Dolby Digital And Dts Decoding , Pioneer Elite Bdp 94hd Blu Ray Disc Player
