Official Pioneer Elite VSX-92TXH thread - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2011 of 2025 Old 07-05-2015, 04:10 PM
racecar383's Avatar
Liked: 0
Originally Posted by repairtech View Post
Did the receiver have sound output when you tested it with nothing in the HDMI out?
If it did have sound what happens with the receiver after you plug into the HDMI out?
Repairtech, I am having the same issue. After a nearby lightning strike, my HDMI out no longer works. I have removed the HDMI board, but don't think I have the skills to replace the chip.
How can I contact you as I am unable to PM at this point.
racecar383 is offline
post #2012 of 2025 Old 08-19-2015, 12:32 PM
eng-399's Avatar
Quoted: 1123 Post(s)
Liked: 1332
Hi guys I'm wondering if someone can help me with my hdmi problem...
1st HDMI out is going into my oppo 103d
2nd HDMI out is going into my cable box (Comcast)
3rd HDMI out is a HDMI cable I have laying on top of my surge protector waiting to be used for my laptop for rew.
The problem I'm having is the 3rd port won't give me any audio or video through this. HOW can I change this on the avr is there a button or menu screen where this can be set to being on....or should it just work when I plug my laptop into the HDMI wire.
Thanks in advance
Mike
eng-399 is online now
post #2013 of 2025 Old 08-19-2015, 01:53 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1675
If it helps, I recently replaced my 92 and I'm happy to sell it. It works perfectly and looks like new.
FMW is offline
post #2014 of 2025 Old 08-19-2015, 01:57 PM
eng-399's Avatar
Liked: 1332
Thanks but I'm trying to hold off a little longer and get an Atmos AVR with 7.2.4 and DTS.x on it. I'm hoping this avr will get me through to the end of the year. Thanks for the offer though. What did you end up buying in place of the Pioneer.
post #2015 of 2025 Old 08-20-2015, 03:11 PM
piketech's Avatar
Just out of curiosity, have you swapped any of those inputs, to see if the other items work on that 3rd port? Main reason I ask is on mine, after buying new HDMI cables and fiddling around with things . . . I eventually figured out that HDMI 2 was fried on the receiver itself, which lead to me buying a new receiver, but that's another story.
Beyond that, do you have the HDMI 3 assigned in the input setup? So that if you for example push the button for "TV" it goes to that input you assigned to it . . . whether it's HDMI 1 or HDMI 2, etc.. If you have the remote, you can get to the input setup by pressing the receiver button, and then pressing the setup button after that . . . the system setup screen should come up, and then option 7 is Input Setup. Otherwise in a pinch, if you haven't assigned it or aren't sure . . . cycle through the input select button at the top of the remote, or on the receiver itself, and if it's working, you'll find out which input HDMI 3 is assigned to if it displays for you.
eng-399 likes this.
piketech is offline
post #2016 of 2025 Old 08-20-2015, 03:35 PM
eng-399's Avatar
Liked: 1332
I haven't swapped any inputs yet but 1 and 2 work... Well 1 does I just tried input 2 that's going into my cable box and it doesn't work now. I want to pull the rack out but it's a pain in the butt because it's on carpet and the rack is full of gear see picture below.
And the updated pic of the rack.
I hope the 2nd and 3rd input isn't fried and I'm going to try what your saying on how to change the input through the remote... Thank you!!! Btw
I ended up being able to pass through my Oppo bluray player for me to use REW in my room. I had all 3 inputs going before the rack was slid back in place.
I just added 4 more subs (nearfield bass) And have 8 total in the room. Trying to eq all the subs is pain but I'm getting there. Thanks for your help on this I'll try what your saying.
Mike
post #2017 of 2025 Old 08-20-2015, 03:56 PM
piketech's Avatar
That's a full rack!! That looks awesome, but yeah . . . I can see why you don't want to pull the rack out if you don't need to.
I have a pretty simple setup, and I'm already cringing thinking about unhooking everything from the old receiver . . . and then hooking it all back up to the new. That's supposed to be the fun part of the new purchase, ha!
piketech is offline
post #2018 of 2025 Old 08-20-2015, 04:03 PM
eng-399's Avatar
Liked: 1332
Thanks! I wish I had a new AVR I'm waiting for the prices to come for Atmos/DTS-X Avr. All in time if I buy one more thing my wife will have a fit!!! Half of the rack was all bought on ebay. The rack its self I paid 200$ through ebay with a local pick up. I got pretty lucky on everything I bought used. The PIoneer Avr was also a refurbished one that still works great besides my little HDMI problem. I'm with you on unplugging everything and redoing it again it a pain and takes some time to. Good luck with your new AVR and enjoy it!!!
post #2019 of 2025 Old 12-16-2015, 06:25 PM
captmobley's Avatar
Pioneer 92THX Remote
Does anyone have a spare AXD7501 remote lying around. Mine just went crazy! The volume control now changes other functions. Any ideas?
captmobley is offline
post #2020 of 2025 Old 01-11-2016, 06:26 PM
Liked: 0
Smile I also need the firmware upgrade for the vsx-92txh
I have M1 & f2 004 and no Dolby truehd disks decode properly.
Can you still help.
Charliebearm is offline
post #2021 of 2025 Old 01-11-2016, 06:38 PM
Liked: 0
Originally Posted by Legairre View Post
<div class="quote-container" data-huddler-embed="/t/909450/official-pioneer-elite-vsx-92txh-thread/1900_50#post_22855552" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>rjardine</strong> <a href="/t/909450/official-pioneer-elite-vsx-92txh-thread/1900_50#post_22855552"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Legairre - Noting your offer of a zipped-up firmware update to 2.013 could I request a copy please. Instruction will probably tell me all I need. but would appreciate confirmation if it must be written to a DVR-R or is CD-R satisfactory.</div>
</div>
Hi Ross I just sent you the firmware. The instructions say to burn it to a CD so I would not use a DVD. If you need any help just give me a shout.
I would like a copy of the vsx-92txh firmware upgrade. I can't decode Dolby truehd disks. Sorry to duplicate the request. Love this monster in front of my Parasound amps.
post #2022 of 2025 Old 01-12-2016, 07:38 AM
Legairre's Avatar
Quoted: 356 Post(s)
Liked: 199
Sure no problem, can you pm me your email address. The file is too large to attach in AVS.
Legairre
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #2023 of 2025 Old 01-12-2016, 09:00 AM
Legairre's Avatar
Quoted: 356 Post(s)
Liked: 199
Thanks Charlie, I emailed the firmware.
Legairre is offline
post #2024 of 2025 Old 01-12-2016, 06:32 PM
Liked: 0
Legairee to the rescue again
Outstanding. Great help worked first time.
Can enjoy Mad MaxFury Road
post #2025 of 2025 Old 08-24-2016, 04:53 PM
Liked: 0
I have a vsx-92txh that wont power up. No lights or anything. Are there buttons i could hold while powering it up? Anyone know how i could fix it?
bloodwraith is offline
Vsx 92txh Elite Home Theater A V Receiver , Sony Bdp S1 1080p Blu Ray Disc Player , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Yamaha Rx V995 Surround Receiver With Dolby Digital And Dts Decoding , Pioneer Elite Bdp 94hd Blu Ray Disc Player
